Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-24-2010, 04:03 PM   #101
mcbassin
Still Learning
mcbassin's Avatar
Re: 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Build
Originally Posted by 72truckman View Post
.... Im having problems too. Mine runs at idle but 0 throttle response. Its showing codes that its not getting a signal from the pedal. Ive now read that all the pedals work and are wired differently... Now i need an '06 pedal. Since the 2006 is plastic and unalterable, I have an idea for how to mount it. If i make a plate that mounts where the original pedal mounts and extend that plate over to the left say, 4 inches. That will provide a solid mount for the new pedal and have no interference from the brake pedal. There is alot more room under the dash than i previously thought.
Cant believe i spent all the time modifying this pedal and getting it to fit perfectly only to throw it out...
This is alsmost the exact same result that Glock had on his swap. He ended up buying and modifying one of the plastic ones like pictured above. I will try to find the link to it.....okay I found it,
HERE
HERE
Good luck!
mcbassin is offline   Reply With Quote
Old 01-24-2010, 04:55 PM   #102
72truckman
72truckman's Avatar
HERE
HERE
Good luck!
Thank you McBassin! I was pissed that i wasn't going to be able to run a pedal with the matching trim but now wiith this idea i will be able to! THANKS
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 02-22-2010, 01:30 AM   #103
72truckman
72truckman's Avatar
Radiator in and installed
Got the seats installed
On the way to exhaust shop
These Magnaflow's sound incredible
Work in Progress
Old 02-22-2010, 01:32 AM   #104
72truckman
72truckman's Avatar
Started final paint work on tailgate, doors etc
Work in Progress
Old 02-22-2010, 12:13 PM   #105
mcbassin
Still Learning
mcbassin's Avatar
That truck is looking GREAT! Keep it up and keep the pics coming!
Old 02-22-2010, 07:50 PM   #106
SeventyOne
Nice looking build! Just read through it all - pretty impressive stuff. I'm local too (Castro Valley) and am looking for a good media blaster. What was the company called in Livermore that did your frame?
I like the wheels too - bought the same set a couple weeks ago ...while reading through your thread I thought "Wait a minute...he's got the same wheels I do!" Great minds thing alike
Anyways, hope to see you around the east bay sometime.
SeventyOne is offline   Reply With Quote
Old 02-22-2010, 09:32 PM   #107
72jimmy4x4
What are the seats out of? They look killer and the fit looks good.
72jimmy4x4 is offline   Reply With Quote
Old 02-22-2010, 09:37 PM   #108
packers05
I am thinking that your birthday is coming up, 16 I believe, what a ride!!!! What a deal, I am jealous
packers05 is offline   Reply With Quote
Old 02-22-2010, 10:23 PM   #109
Critter
Future TOTM Winner
Critter's Avatar
So what did you end up doing with the pedal?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 02-23-2010, 03:00 AM   #110
72truckman
72truckman's Avatar
I wish i had been drivin it at 16.. im turning 18 next month haha
Long story short: Hooked the electronics up to a gm code reader and found out that while my engine is 2006, all electronics are 2004. i guess the guy i bought the setup from did this so i could utilize the steel petal.
So once i found the year discrepancy out, i was able to diagnose the problem more specifically.
The crazy part is that one day after a good long charge and a trouble code clearing, all problems went away and everything started working perfectly
2004 Chevy Silverado, but i modified the frame by cutting off the back about 2.5" off the sliding track in order to make them go back farther in the truck. im 6'4" and they are perfect w/o a tilt column... yet
The company is MAAS BROTHERS POWDER COATING. They do excellent work.
I just saw your build thread the other day and when i saw the wheels i had to double take- the same wheels, on the same truck, from the same model year, being built at the same time, probably 10 miles away from eachother? Trying to show when Pleasanton rolls around or what?
Work in Progress
Old 02-23-2010, 10:05 AM   #111
Dave_S
Do those front seats fold forward?
Dave_S is offline   Reply With Quote
Old 02-23-2010, 02:02 PM   #112
72truckman
72truckman's Avatar
Very Slowwwwwwwly haha they are power seats- and it leaves enough room for someone really small to get by. the easiest way for people to get in back is to go between my front seats or jump up on the tire and over the bedsides.
Work in Progress
Old 02-23-2010, 04:02 PM   #113
Calitruckgrl1
Calitruckgrl1's Avatar
Looking great Max! Can't wait to hear the exhaust roar!
My 1965 GMC 4x4
http://67-72chevytrucks.com/vboard/s...22#post2754022
My brother's 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
Calitruckgrl1 is offline   Reply With Quote
Old 02-23-2010, 06:03 PM   #114
SeventyOne
Cool, I'll have to check them out and get a quote. Not sure when the Pleasanton Good Guys is but I will be shooting for a 2011 completion date.
Old 03-16-2010, 05:36 PM   #115
barnold
barnold's Avatar
Do you have any pictures as to how you mounted the rear seats? Did you use the stock brackets?
barnold is offline   Reply With Quote
Old 03-16-2010, 10:07 PM   #116
BLUE THUNDER
BLUE THUNDER's Avatar
I am liking the progress. Can't wait to see more pics.
BLUE THUNDER is offline   Reply With Quote
Old 03-18-2010, 01:18 PM   #117
amcgeh01
amcgeh01's Avatar
[QUOTE=72truckman;3406082]Havent updated in foreverrrr....
Engine mounts
Hi Truckman,
I wanted to thank you for putting alot of pics and info online as I am doing the same build for a 72' GMC Jimmy 4x4 but came across a challenge that you seem to have already conquered regarding the motor mounts.. As I was procuring parts last year and following others advice along the way, I purchased a set of CPP LS1 conversion brackets as shown here.. http://www.classicperform.com/Store/...cks/CPLS1K.htm However, after closer inspection there is no way to attach them to the frame as there are no mounts on the frame side. IN THE pic you have some kind of bracket coming off of the frame and I was just curious to know where you may have found it or did you make it..?
I have seen several different setups in the last 24 hours as I have been frantically trying to find the best solution as we just discovered this yesterday when my mechanic friend came by to assess what needed to be done... I also noticed CPP also carries a conversion bar that runs from side to side and some weld-on brackets like those that you have but which is the best for our 4x4's since we sometimes drive quite differently than street driven rides. That conversion bar looks like it might get caught on something. (Edited: Found out the conversion bar they sell and everything else is only for 2WD only - though not really outlined)..
Also, my 2nd request is where did you get your gas tank from that had the in-tank pump already in it..? I have seen several different ones but anything custom made seems to be over $500 dollars and out of my range right now…
Nice choice on the Champion Rad as I picked one up last month from their headquarters here in C.M. BTW, Do you remember which hoses you bought that fit..?
Thanks in advance..
-A.J.
In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks..
amcgeh01 is offline   Reply With Quote
Old 03-19-2010, 01:51 AM   #118
72truckman
72truckman's Avatar
[quote=amcgeh01;3867873]
Engine mounts
Hi Truckman,
Thanks in advance..
-A.J.
Amcgeh01,
The brackets that mount in the frame are actually what i had left over from a DIY4X crossmember, but are simply a piece of channel about 5 inches long (something you can buy from any steel yard). I decided that with the block being built from the factory as a structural piece, i would use it as one. It really gives my front axle a lot of room and full access to the oil pan.
As far as the gas tank goes, its not a bolt in kit... I bought an in tank pump from Tanks Co., a 1981 tank and sending unit from Rock Auto, cut a big hole in a brand new tank, and ended up with a very nice piece (though not an easy job to say the least)
The hoses are from a 2006 Chevy Silverado. The top hose fits perfectly.. The bottom hose is from the same year truck, and its a tight fir, ill probably swap it out. That aluminum radiator is badass, its the first one ive ever used and all that ill be using in the future..
GOOD LUCK!
Work in Progress
Old 03-19-2010, 02:14 AM   #119
72truckman
72truckman's Avatar
Its getting close when final bodywork is happening
Started building lockable storage boxes
Lost a good truck last week. It was my dads bought brand new in 1995. Put 225000 miles on it before the tranny blew. it died gracefully as a parts car for my 1999 suburban. RIP 1995 GMC Yukon
Work in Progress
Old 03-19-2010, 08:41 AM   #120
lks dcvn
lks dcvn's Avatar
Looks great! Nice work on the progress you are making.
lks dcvn is offline   Reply With Quote
Old 03-19-2010, 11:31 AM   #121
SeventyOne
Getting close for sure - I'm going to have to have you come out and help me with my body work as I have no idea what I'm getting into there!
You plan on putting and speakers inside those storage boxes?
Old 04-20-2010, 01:36 AM   #122
Broncoviejo
Nice Job! Question? what is the parts for the fuel assembly? I also have a 1972 chevy truck and just picked up a 03 5.3 LS1. thanks ...
Broncoviejo is offline   Reply With Quote
Old 04-20-2010, 02:45 PM   #123
Broncoviejo
Hello,
where did you get the pump setup from? Manufacture..
Old 04-21-2010, 02:23 AM   #124
72truckman
72truckman's Avatar
Originally Posted by Broncoviejo View Post
Hello,
Tanks Incorporated. http://www.tanksinc.com/index.cfm/pa...=cat/cat61.htm
Work in Progress
Old 04-29-2010, 03:25 PM   #125
Brandoneh
Build looks great! Can't wait to see it assembled!
71 K5 In progress!
Brandoneh is offline   Reply With Quote
