Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 12-22-2010, 02:20 AM   #101
shaved87
Re: Impala SS Rear Disc Brake Brackets
do you think that there is any possible way that you could give instructions on how to install?? including pics of the different steps. does the axles have to be removed or will the center circle simply slide over the lugs once you remove the rotors
shaved87 is offline   Reply With Quote
Old 12-23-2010, 12:39 AM   #102
Captainfab
60-66 Nut
I replied to your PM regarding this. Is there still something that you need help with?
Old 03-10-2011, 08:44 PM   #103
67chevy1series
67chevy1series's Avatar
i assume thses will fit a 67 72 axle so i am going to ask will edelrado calipers fit on those brackets? i want to use the edelrado calipers because of the e brake so will these brackets work for my axle and those caddilac calipers?
67chevy1series is offline   Reply With Quote
Old 03-11-2011, 12:20 AM   #104
Captainfab
60-66 Nut
These will work on all the '64-'82 truck 12 bolts as long as you have the 5x5" wheel bolt pattern. If you need a set for 6 lug wheels, I have those as well.
What year Eldorado calipers do you have? These Impala SS caliper brackets will only work with the '94-'96 Impala SS/Caprice rear calipers. If you have a set of the '76-'79 Eldorado calipers, those will work with the D52 brackets. Have you looked at the Camaro brackets? Those are designed for the '93-'97 F-body calipers which have a built in e-brake.
Old 03-14-2011, 12:48 AM   #105
67chevy1series
i want to do this cheapo stlye haha, can i go to a junk yard and get a bracket that will work on my axle and work for calipers with e brake cables? if so what vehicle do i rob the brackets off of?
Old 03-14-2011, 12:58 AM   #106
Captainfab
60-66 Nut
No there isn't any factory bracket that you can just bolt on to a truck 12 bolt and have disc brakes.....that's whay I'm making these brackets
Old 04-11-2011, 02:00 PM   #107
faribran
Captain Fab,
i rec'd my brake booster bracket Saturday... i must say the design and workmanship is top notch... dont know what you cut these with.. but it does a fine job... also know that you got compliments on your welds too.
the bolt pattern on the Astro van booster fit like a glove... (just note that once the bolts are tightened to the firewall, the braket tends to flex inward, i guess due to the uneveness of the firewall, but this is no problem). i plan to shorten the booster bolts. they are a bit long. shortening will allow better access to tightening...
thanks again.
Rich
faribran is offline   Reply With Quote
Old 08-29-2011, 10:52 PM   #108
progrudge
do u still have these brackets? will they also work on a 10 bolt in a 72 caprice 5x5 bolt patern? thanks
progrudge is offline   Reply With Quote
Old 08-29-2011, 11:39 PM   #109
Captainfab
60-66 Nut
Yes these brackets are still available. You know I'm not sure about the 10 bolts. The Impala/Caprice 12 bolts are supposer to be the same housing as the truck 12 bolts, but I just don't know about the 10 bolts. If the backing plate bolt pattern is 2-5/8" vertically, and 3-3/8" horizontally, these will probably work.
Old 12-14-2011, 09:47 PM   #110
sgaylord
Project collector
sgaylord's Avatar
Sent you a PM. Still have any of these brackets?
Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 12-14-2011, 11:54 PM   #111
Captainfab
60-66 Nut
I replied to your PM Steve.
Yes I do still have these for sale. If I do run out, I just order more parts laser cut.
Steve
Old 12-31-2011, 05:05 PM   #112
jwalk
What was I thinking?
jwalk's Avatar
I just sent PayPal your way for a set of these impala brackets! Let me know if you received it. Thanks!
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 01-01-2012, 12:08 AM   #113
Captainfab
60-66 Nut
PM coming your way.....
Old 02-05-2012, 07:30 PM   #114
pockets
pockets's Avatar
Do I need a new master cylinder or just a proportioning valve? I have an 87 if that makes a difference.
Project Bad Karma
pockets is offline   Reply With Quote
Old 02-05-2012, 10:56 PM   #115
Captainfab
60-66 Nut
Some guys get away with the original disc/drum master and an adjustable proportioning valve in the rear line, but others don't. I always recommend switching to a disc/disc master cylinder, and either a disc/disc fixed proportioning valve, or an adjustable valve in the rear line.
Old 02-06-2012, 09:55 AM   #116
pockets
pockets's Avatar
Ok, any suggestions or recommendations for a master cylinder?
Project Bad Karma
Old 02-07-2012, 12:03 AM   #117
Captainfab
60-66 Nut
The Corvette master cylinder is very popular when converting to 4 wheel disc brakes. The A1 Cardone part number for the '67-'76 rebuilt master is 101423. The number for the '77-'82 rebuilt master is 101749 and a new one is 131749. I don't remember just what the difference is between the '67-'76 and the '77-'82 is. They are both 1.125" bore......I'll have to check on that.
Old 02-07-2012, 10:26 AM   #118
pockets
pockets's Avatar
Cool, thanks. Would that apply to any of swaps you have kits for? I read on another post where you compared the costs of all three swaps, so I'm trying to decide which route to go.
Come to think of it, perhaps I should just go all out and do a hydroboost swap as well...
Project Bad Karma
Old 02-08-2012, 12:23 AM   #119
Captainfab
60-66 Nut
Yes, that applies to any 4 wheel disc brake conversion.
Another option for a master cylinder I forgot to mention is, you can also use the Impala SS/Caprice master with those calipers, or a Camaro/Firebird master with the F-body calipers. I don't always think of suggesting those as most guys don't like the looks of the plastic reserviors on those masters.
Old 02-10-2012, 11:42 PM   #120
68 TT
Still plays with trucks
68 TT's Avatar
There is also a manual brake version of the early C3 Vette master cylinder for those wanting 4-wheel disc but don't have enough vacuum for a power booster to work properly. If I remember right is has a 1" bore.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-10-2012, 11:43 PM   #121
68 TT
68 TT's Avatar
There is also a manual brake version of the early C3 Vette master cylinder for those wanting 4-wheel disc but don't have enough vacuum for a power booster to work properly. If I remember right it has a 1" bore.
Old 02-22-2012, 03:41 PM   #122
storm9c1
*** That's interesting ***
storm9c1's Avatar
One thing to note: the '94-96 B-Body (Caprice/Impala SS) setup is very conservative, dang near a 95%-5% split, which is terrible. If you want the rear calipers to come alive with the B-Body master and prop/combo valve setup, you should also consider doing the "stealth bolt" mod (an adjustable prop valve is also an option).
http://www.impalassforum.com/vBullet...d.php?t=231718
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 02-22-2012, 11:45 PM   #123
Captainfab
60-66 Nut
Thank you for that information. This is good to know
Old 03-21-2012, 11:22 AM   #124
bgood70
bgood70's Avatar
Just sent Paypal!!
70 C-10 SWB 350/700r4 Good 70 SWB Build
72 GMC Sprint SP Custom 350/Turbo300
bgood70 is offline   Reply With Quote
Old 03-22-2012, 12:24 AM   #125
Captainfab
60-66 Nut
Payment received. Your brackets will ship out tomorrow. Thanks
