Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 12-29-2009, 06:31 PM   #101
lks dcvn
lks dcvn's Avatar
Re: 1972 Blazer - 'Bullet' Project
Firebird - if you see any solid Blazer/Jimmy tubs - shoot me a PM since the 2wd I bought will need similar surgery down the road.
More progress today - I only take off Fridays in the 'nice weather months' here [June-Sept] to do work on my trucks - I am getting more done in the cold than I did over the summer...oh well.
Mario - the part you are referring to is the outer floor extension piece - it is the inner rocker and about 4 inches into the floor [no more front and rear parts to weld together - this covers the whole length of the truck rocker and floor - where the rust usually is.
I could not get mine to line up enough (on the drain channel and seat bump) so I cut the floor at the edge to butt weld on the original floor. I got it from a FS thread on the board here it has an outback truck parts sticker on it from your neck of the woods - but several vendors have them [TriPlus, Wes, GMCPauls] - run about $60. Here is a link to a pic of them:
http://www.gmcpauls.com/pictures/677...nnerrocker.jpg
I got everything lined up and I think tomorrow will begin my B-Pillar project to see how much I am missing and what I will need to build.
I stopped by my local hardware store and did find a few brass fittings that will be me up and running for welding.
I was going to paint the insides of the rocker boxes to protect them from any more rusting - but when I checked the can from www.nomorerust.com it mentioned not to use it below 35 degrees - I don't even think it hit that as a high today.
Well - nonetheless - here are my pix from today. I didn't get a shot of the trimming I did on the outer floor extension patch - but you can see it in the shot of the top of the floor/support...
After checking out the B-pillar I will bolt/tack weld everything in place then put on the door and fender to check for alignment to make sure that I am on track still.
Then take it all back off and adjust, if necessary, and then start my welding.
I think the other side should go a lot faster once I do one side - so I know what I am working with.
I have a new appreciation for people who do this stuff for a living and I hate anybody who lives in areas where this stuff isn't an issue.
lks dcvn is offline   Reply With Quote
Old 12-29-2009, 06:43 PM   #102
Firebirdjones
I always have my eyes peeled and hit all the swap meets around Arizona, I'll keep in touch.
Firebirdjones is offline   Reply With Quote
Old 12-29-2009, 06:45 PM   #103
Firebirdjones
Easier to understand why a good body man gets $60+ an hour for that stuff, sure is fun eh??
Guess I better not post anymore pictures of rust free stuff out here if I want to stay on your good side.
Old 12-29-2009, 09:50 PM   #104
1956cameo
1956cameo's Avatar
It's looking good!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 12-30-2009, 01:31 PM   #105
Jtrux
I'm a poor spectator
Jtrux's Avatar
Hate is such a strong word.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-31-2009, 01:21 AM   #106
BLUE THUNDER
BLUE THUNDER's Avatar
Thanks dude. It's really looking good.
BLUE THUNDER is offline   Reply With Quote
Old 01-03-2010, 02:49 PM   #107
lks dcvn
lks dcvn's Avatar
B Pillar Work...some before and then after fitting the patch panels together...
still no tack welding - I want to be sure that this stuff all fits before doing one weld.
I will need to create some of the floor and 'step up' area on the psgr side...
Cutting out the rocker box reinforcement plate was a good time let me tell you - 4 1/2" angle grinder on my back to get the remnants of that plate out was a PITA for the past few days.
Old 01-03-2010, 02:50 PM   #108
lks dcvn
lks dcvn's Avatar
few more pix...taking a break to thaw out and grab some lunch.
high of 23 today and I have been outside for 3+ hours already...brrrr
Old 01-03-2010, 02:54 PM   #109
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Way to go...nice work.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 01-03-2010, 06:31 PM   #110
Firebirdjones
Looks good, it's coming along.
Holy moly it was a high of 23 and you're doing this outside???
We had a high of about 58 here in Prescott Valley today. My body has adjusted quite nicely since we moved out here from cold country
Old 01-03-2010, 06:53 PM   #111
lks dcvn
lks dcvn's Avatar
Thanks Tim [ChevyMan]
I did about 2 more hours of work out there and then I was too tired of the cold to continue any longer...my knees and back are shot.
I am now working on the B pillar patch and the rear front quarter patch - more fun to follow as I am off work tomorrow as well.
I am working in a non-heated garage with a propane heater next to me and a 500 watt halogen light assisting with the crappy lighting in my garage.
I plan to build a well illuminated, heated multi-bay shop in 2011. I am heading to Alaska in 2010 so that will soak up my garage fund - but it should be worth it -
Old 01-03-2010, 11:11 PM   #112
Wasted Income
Boosted Member
Wasted Income's Avatar
Nice work! Thanks for the pics...they will help me when it's time for me to start on that section of my truck.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-03-2010, 11:14 PM   #113
BLUE THUNDER
Alaska, you can't get enough of the cold can you? I'm sure that is gonna be a great vacation Tom. I'm digging the progress on the Blazer. Can't wait to see more pics. Mario.
Old 01-03-2010, 11:16 PM   #114
Firebirdjones
Wow that's dedicated.
Are you hand fabbing those floor pans?? Doesn't anyone repop the floor pans for these trucks??
Old 01-04-2010, 10:45 AM   #115
lks dcvn
lks dcvn's Avatar
hand fabbing floors - not yet. I have used all the patch panels I can so far...
I did some more work on the b pillar yesterday and neglected to get pix before I came back in the house.
I got it back to solid metal so I could see what I needed to do. Today is my last day of vacation so I would like to get some more done.
Old 01-04-2010, 06:00 PM   #116
lks dcvn
lks dcvn's Avatar
Today's progress - more bone chilling time in the garage - high of 28 today -
I ordered a set of the floor supports from GMCPaul today [Pic 1] - hopefully they show up by the weekend so I can see how they look mocked up in position - they support the floor area under the corner of the floor where my rust hole is.
I also need to pick up some weld through primer tomorrow/this week since the paint place was closed today by the time I thought of it.
Pix of the progress.
[Pix 2 & 3]
I cut out the floor to test fit the inner rocker patch - came out pretty close. I then mocked up the B Pillar patch and got it cut down close enough
[Pix 4 & 5]
I then wanted to see how the outer rocker looked mocked up so I put it on and got a few pix to show it on the truck...
Old 01-04-2010, 06:07 PM   #117
lks dcvn
lks dcvn's Avatar
I also needed to see how bad the rear quarter was so I did some trimming on that to resolve a crappy fix from one of the previous owners [old pix from late fall are the first 2] - interesting fix that they did here [pic of inside of quarter included] - looks like they never even ground the welds down afterward on the outside - just slapped on some filler and then painted it.
I went out to clean, unbent, non-rusted metal and cut from there...
Old 01-04-2010, 06:12 PM   #118
lks dcvn
lks dcvn's Avatar
Then I did some hanging of the rear quarter - I haven't trimmed it down yet...
and then a picture from when it was warmer out before I started this project...
I hate cold weather -
Old 01-04-2010, 08:42 PM   #119
VA72C10
VA72C10
VA72C10's Avatar
looking good. Keep at it.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-07-2010, 01:16 PM   #120
lks dcvn
lks dcvn's Avatar
Got my patch panels last night from GMCPaul - I got dinged on the shipping [$17 and it shows up in a $5 small flat rate box] - - oh well.
They seemed smaller than I had imagined - but I bolted one up to see how it looked. I didn't take a picture - I was too cold to stay out there too long.
One of my buddies let me borrow his propane heater for the winter - and the thing is terrible - don't get me wrong - it can warm you up if you are standing next to it, but for me to put on the rust paint and the weld through primer I need some warmer temps in the garage.
I just picked up a 125k forced air heater that is propane driven so that should put a bit more heat into the garage for me to work in. I should have that this weekend.
I will give by buddy his heater back with a 12 pack of beer for the 'rental fee' -
One day [hopefully before retirement] - I am moving just to be warm year round...I wish my job were portable.
Old 01-07-2010, 01:26 PM   #121
Firebirdjones
I hear ya. That's one reason we left too.
Can't wait to see more pics. It's starting to look like a Blazer again.
Old 01-07-2010, 03:48 PM   #122
1949gmc
Is there anyplace in this country now that's warm? Hell, it's only 58 in Key West today! Then there's the snow that we have to put up with, too. You're probably getting hit pretty hard today. Ours started about 12 hours ago.
Hey, I was wondering what you're thinking about doing for doors for your truck. I've got two new repops (one Blazer and one truck door that I cut down) that I got from GMCPauls that I'm not going to use. Any interest? Wouldn't be sure how to get them to you- one of the boxes got ruined.
1949gmc is offline   Reply With Quote
Old 01-07-2010, 04:54 PM   #123
lks dcvn
lks dcvn's Avatar
Weather here - 3-5" of snow today/tonight - with snow in the forecast for the next few days as well -
Not sure on the doors yet - the set on there isn't too bad - some rust here and there.
I also have a set of truck doors that I might use - haven't got that far yet though.
When I get there and I have a need - I will be in touch. Thanks.
Old 01-07-2010, 05:26 PM   #124
Firebirdjones
Arizona
Old 01-07-2010, 05:28 PM   #125
Firebirdjones
I hear ya, saw the forcast out there and it looked like quite a bit coming your way on radar.
