Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-24-2013, 11:51 AM   #101
exploderjim
exploderjim's Avatar
Re: Hydroboost Mounting Plates
Now I have found a 08 and a 2012 Master cylinder from a Silverado HD running 4 wheel disc brakes. would that work and two i would still need to run my CPP porportioning valve as well right? Here is my issue I just want to confirm that I'm understanding this correctly and that it will bolt to the master cylinder. The 2012 is a hydroboost set up as well. Anyways any help would be appreciated/
exploderjim is offline   Reply With Quote
Old 05-24-2013, 12:53 PM   #102
wheel1968
Talking Re: Hydroboost Mounting Plates
Hey Capt'n i have a 78 chev mini home hydro that'll work right it was a 1 ton looks like it would ?
wheel1968 is offline   Reply With Quote
Old 05-24-2013, 11:31 PM   #103
Captainfab
60-66 Nut
I do not know if either of those masters will bolt up to your '97 Astro hydroboost. As I said earlier, I do not have much experience with the newer masters as what you are looking for. Some of the newer masters bolt up differently. If you want to go with a master cylinder as new as one of those, I would suggest purchasing the master and hydroboost as a unit. If your CPP proportioning valve is for a disc/disc system, then yes you should run that one.
Old 05-24-2013, 11:33 PM   #104
Captainfab
60-66 Nut
Yes, that will work. Once you remove the factory mounting plate, the hydroboost units themselves are all the same. That master cylinder might be a little large if you are going to run it on a C10. I would just bolt on an appropriate C10 master cylinder.
Old 08-08-2013, 01:12 AM   #105
Roush
Sir,
I would like to order a bracket and plate. I have a Cardone 52-7251 Remanufactured Hydroboost. Looks like its from a '90 or '91 Astro Van. Please pm for details. Thank you.
Erin
Roush is offline   Reply With Quote
Old 08-08-2013, 01:31 AM   #106
Captainfab
60-66 Nut
Pm coming your way.....
Originally Posted by Roush View Post
Sir,
Erin
Old 10-11-2013, 07:02 PM   #107
1972Shorty
hey CaptainFab, I'm using your Impala disc brake conversion for the rear and was really impressed with the workmanship...I need both the hydroboost plate and the firewall mounting bracket for a 72 cab, raw steel is fine...
PM me with the $$$...thanks
1972Shorty is offline   Reply With Quote
Old 10-11-2013, 11:27 PM   #108
Captainfab
60-66 Nut
PM sent
Old 10-21-2013, 09:16 PM   #109
JRSTI
Hi captainfab I sent you a PM.
JRSTI is offline   Reply With Quote
Old 10-21-2013, 11:02 PM   #110
Captainfab
60-66 Nut
I replied to your PM
Old 02-13-2014, 09:47 PM   #111
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I might be doing some business soon. Once I get my donor brake parts I will be in touch as soon as I figure things out. The donor is a 83 P30 hydro boost for my 68 C30.
Alan's Classic is offline   Reply With Quote
Old 02-14-2014, 12:09 AM   #112
Captainfab
60-66 Nut
I can set you up Alan. Just let me know when you're ready.
Old 11-13-2014, 08:52 AM   #113
earl84
Got my Brake booster adapter bracket and Hydroboost mounting plate yesterday. Ordered Sunday, on my doorstep early Wednesday, that's fast.
They're all painted up and ready to mount today, if I can brave the cold. Extremely nice qualtiy, and the best customer service of any transactions I have ever done. Cannot recommend your stuff highly enough.
Maybe you should start having it stamped or engraved like Porterbuilt does. Just a thought. I'd have Captainfab stuff on my PS adapter, 14 bolt saddles, and brake booster mounts. Thanks again.
earl84 is offline   Reply With Quote
Old 11-13-2014, 03:55 PM   #114
earl84
Got it all mounted, pushrod shortened and welded up, brake lines connected. Next is to run the pressure and return lines, but it was too cold to continue, so I called it a day. Sorry for the blurry cell phone pic. Your bracket and HB mounting plate sure did make this a whole lot easier. Thanks again.
Old 11-14-2014, 12:27 AM   #115
Captainfab
60-66 Nut
Looks good
Thanks for posting a pic.
Old 11-14-2014, 10:46 AM   #116
Greywolf200
That looks really slick. Good work.
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 12-18-2014, 12:27 AM   #117
Aaronpetty82
Aaronpetty82's Avatar
So to clarify I need a booster braket for 67-72, and a hydroboost adaptor?
A Rod
Aaronpetty82 is offline   Reply With Quote
Old 12-18-2014, 01:49 AM   #118
Captainfab
60-66 Nut
If you are working on a '67-'72, then yes you will need either booster bracket that I make for the '67-'72's and this hydroboost mounting plate. Then everything will bolt up without drilling any more holes in your firewall.
Old 12-18-2014, 10:31 AM   #119
Dsuper5
Dsuper5's Avatar
Good Morning
A little feedback, it sits on a 64 Sub 4x4.
Dsuper5 is offline   Reply With Quote
Old 01-14-2015, 01:56 AM   #120
Captainfab
60-66 Nut
Due to it being a PITA to get the socket back and the fact that the last guy refuses to return it, I have changed how I 'rent' the hydroboost nut socket. Basically what I am doing now is you will have to purchase the socket for $52.50 plus shipping and if you wish to return it to me after you are done I will refund $26.25 to you. Sorry to be that way, but I have lost too much time and money with the way I was doing it before.
Old 03-24-2015, 08:35 PM   #121
205harleyman
205harleyman's Avatar
1972 blazer 2 wheel drive, what brackets do I need to go Hydro boost? running 5.3 engine out of 2003 tahoe
205harleyman
1972 K5 Blazer
2002 5.3 ltr engine and transmission
Vintage Air
1999 tan leather bucket seats and console w/1999 back seat
20inch Torque Thrust Wheels
Corvette Madrid Red with Tan Top
Hope to be driving soon!!!
205harleyman is offline   Reply With Quote
Old 03-24-2015, 11:16 PM   #122
Captainfab
60-66 Nut
You will need a '67-'72 booster bracket in addition to the hydroboost mounting plate. Do you need the standard booster bracket or the one with the hydraulic clutch conversion? And in bare steel or satin black powder coat?
Old 03-25-2015, 10:24 AM   #123
205harleyman
no clutch
205harleyman
1972 K5 Blazer
Vintage Air
Old 03-25-2015, 10:50 AM   #124
205harleyman
also, will the power steering pump from 5.3 2003 Tahoe work? do not think it had hydro boost brakes.
205harleyman
1972 K5 Blazer
Vintage Air
Old 03-25-2015, 11:43 PM   #125
Captainfab
60-66 Nut
With a hydroboost I recommend using a power steering pump with 2 return line ports as is used with the factory hydroboost system. Not being familiar with your particular power steering pump, I do not know if another return port can be added to that pump reservoir or not.
