Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 11-30-2009, 10:57 PM   #101
scotts62
One day...
scotts62's Avatar
Re: My 93 Crewcab Build
Well you see future plans are to shorten the frame and make into a short bed and to convert to 5 lug with a mild drop
454 or 350??
Scott
93 crew cab build
Project 62
Old 11-30-2009, 11:22 PM   #102
highperf4x4
454 or 350??
350 and Joe is not interested in the 454?
highperf4x4 is offline   Reply With Quote
Old 11-30-2009, 11:27 PM   #103
scotts62
One day...
scotts62's Avatar
looking at it as i have to rebuild either one i use and the 454 is a bunch more to build and i could build a stout 350 for what the 454 will cost to build stock... thats all.
Scott
93 crew cab build
Project 62
Old 11-30-2009, 11:48 PM   #104
highperf4x4
yup, that's true pimp.
Old 11-30-2009, 11:58 PM   #105
scotts62
One day...
scotts62's Avatar
Cough cough maybe a lil 350 with 454 throttle body
Scott
93 crew cab build
Project 62
Old 12-01-2009, 12:00 AM   #106
joe231
joe231's Avatar
did you find anything out about that?
mmmm?..................454?.......................ahhhhhh?
CHEVY ONLY
Old 12-01-2009, 12:11 AM   #107
highperf4x4
Old 12-01-2009, 08:14 AM   #108
scotts62
One day...
scotts62's Avatar
No but will today
Scott
93 crew cab build
Project 62
Old 12-04-2009, 12:13 AM   #109
scotts62
One day...
scotts62's Avatar
Anyone have any info on shortening a frame on a 88-98? Found one here on the site but where they cut it, it looks as if it raises the rear of truck when your done.
Scott
93 crew cab build
Project 62
Old 12-04-2009, 12:39 AM   #110
eke82
ten -15 years ago a kid i knew built his own1/2 ton using a extended cab long box frame he slid the rear cab mounts back and cut them to fit was the only mod he had to do he said. he built 3/4 a couple of years later and he discovered the rear mounts from a short box extended cab fit perfectly
eke82 is offline   Reply With Quote
Old 12-04-2009, 12:42 AM   #111
highperf4x4
So, he made a shortbed crew from a king cab longbed?
Scott's truck is already a crew cab longbed.
Old 12-04-2009, 08:40 AM   #112
scotts62
One day...
scotts62's Avatar
Yeah i may have to cut under the cab and shorten the rear of frame too, under the cab would suck but oh well...
Scott
93 crew cab build
Project 62
Old 12-04-2009, 08:14 PM   #113
scotts62
One day...
scotts62's Avatar
Got the crew out to parents shop to get away from the theivin mofos! and got the rear end yanked out and some measuring done so i can get a game plan on where in going to cut the frame
Scott
93 crew cab build
Project 62
Old 12-04-2009, 09:25 PM   #114
joe231
joe231's Avatar
http://www.fullsizechevy.com/forums/...sion-info.html
man the info is pretty scarce.....
yeah that seems to be the way most people are doing it......
CHEVY ONLY
Old 12-05-2009, 12:30 AM   #115
eke82
yes that is correct. He built them before chevy offered them from the factory in 99
Old 12-05-2009, 01:02 AM   #116
highperf4x4
So then why didn't Mr Scott find a king cab longbed instead?
He's been spending too much time around them warp drives..............
Old 12-05-2009, 09:59 AM   #117
scotts62
One day...
scotts62's Avatar
Then i would have had to buy (2) Two-Two trucks.....
Warp drives?
Scott
93 crew cab build
Project 62
Old 12-05-2009, 01:08 PM   #118
highperf4x4
yeah, warp drives.............. Mr Scott, the engineer on Star Trek. I'll be Captain Kirk............
Old 12-06-2009, 12:44 AM   #119
scotts62
One day...
scotts62's Avatar
kin to beam me up Scotty..?
Scott
93 crew cab build
Project 62
Old 12-06-2009, 01:13 AM   #120
highperf4x4
you was supposed to say "aye cappin, I'm givin er all she's got!!!"
So anyway, did you figure out yet where you need to cut the frame?
Old 12-06-2009, 11:59 AM   #121
scotts62
One day...
scotts62's Avatar
Um, im thinking im going to cut it under the cab, i think it will look a whole lot better that way.
Scott
93 crew cab build
Project 62
Old 12-10-2009, 12:33 AM   #122
wildmanaaron
Any one have any info of anyone cutting the frame for a swb? No biggie i just want to see how others have done it.
I havent done any measurements but I am in the same boat as you on this. I already have a Truck. I have read that you can move the leaf spring and axle assembly forward to the shortwheelbase locations but I am not for sure.
With that method I wondered a few things:
If you move the axle forward will that mess with centering the wheel in the wheelwell?
I figured the leaf springs would have to be the same length between a long and short but I am not 100% for sure. Wouldnt make sense if they different but...
What happens since you would be moving the hanger it would be moved down towards the ground and forward since the frame dips down when you move towards underneath the cab forward.
wildmanaaron is offline   Reply With Quote
Old 12-10-2009, 08:46 AM   #123
scotts62
One day...
scotts62's Avatar
I think im going to cut it under the cab, it seems like it will be more of a pain in the arse but will look better and be easier, that way you dont have to mess with any of the leaf spring perches and just cut some off the back of the frame also. Will have to cut the rear cab mount off and the front bed mount and move them.
Scott
93 crew cab build
Project 62
Old 12-10-2009, 09:17 AM   #124
JohnC
JohnC's Avatar
Are these trucks different than the 73-87 trucks as far as where they get cut? The 73-87 trucks are usually just cut right behind the cab, and then just welded back up.
JohnC is offline   Reply With Quote
Old 12-10-2009, 12:03 PM   #125
wildmanaaron
Is that even possible? The frame bends upward behind the cab I believe. Then it levels out from there to the end of the frame rail.
