10-27-2012, 02:10 PM | #101 |
Re: Sun Tachometer Retrospective
what is thats clock out of???
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
06-14-2013, 09:54 PM | #102 |
Moderator
06-14-2013, 10:01 PM | #103 |
Are the terminals marked with anything?
Posted via Mobile Device |
06-14-2013, 10:16 PM | #104 |
Moderator
Don't have it yet. Those pics are it for now. I'm hoping the back is enough to identify it.
06-15-2013, 02:16 AM | #105 |
Senior Enthusiast
That is a “two piece” tach that does require a transmitter. The later transistorized tach that doesn’t need a separate transmitter (FZ series) has a separate can bolted to the back of what you see in the photos. There should have been a data plate under the retaining clamp that identifies what type transmitter, cylinders, and voltage the tach is designed to serve. Hopefully the information may be painted on under the clamp.
This is what the data tag normally looks like:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 06-15-2013 at 02:22 AM. |
06-16-2013, 12:17 PM | #106 |
Do the factory tachs require the sending unit? The one I have is from a '66 3 ton truck.
Thanks for any info, Brian Posted via Mobile Device
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600 |
06-16-2013, 12:26 PM | #107 | |
Senior Enthusiast
The first Sun tach to not require the separate transmitter was the FZ series, and to the best of my knowledge these were never factory installed. If it's a Chevy tach, hopefully someone with Chevy instrument experience will respond as I don't know what pieces they used. I would imagine they used Delco tachs (or some brand aligned with GM) and would likely be engineered to not require a transmitter.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
06-16-2013, 12:46 PM | #108 |
Ya, mine is a Chevy cluster. I'll have to dig out the assembly manual and see if there is any info in there.
06-16-2013, 12:52 PM | #109 | |
1972 Chevrolet C/20 LWB, BB 402, Tach, Bedside Toolbox, Posi, Factory AC, Factory AM/FM, cruise, Dana 60 |
06-16-2013, 02:04 PM | #110 |
Moderator
Here's the auction for the pics that I posted (not mine!). Thought someone else might get a deal:
5000k Sun Tach on ebay |
06-22-2013, 12:43 PM | #111 |
With the repro dash tachs where does a person set the red markers? What is the red line or power band for the various engines? Mine is a '66 with a 327 and TH400.
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
06-22-2013, 01:16 PM | #112 |
depends upon your power curve and modifications to your eng. if your 327 is a stock eng use the stock marker positions
ron |
06-22-2013, 01:18 PM | #113 |
Yes, mine's all stock. What are the stock positions for a 327/TH400 setup? Thanks.
08-16-2013, 06:25 PM | #114 |
But Found Her 25yrs Later!
Jegs has it on special for $109.99 plus free shipping.
http://www.jegs.com/i/Sunpro/885/FZ8...FbCDQgodZykANw
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
08-19-2013, 03:18 PM | #115 | |
http://kieth.smugmug.com/Trucks/66-G...5848&k=FM9gWk5 I SENT MINE TO A GUY OVER IN HOT SPRINGS ARKANSAS AND HAD IT CONVERTED TO NEW ELECTRONICS, SINCE WE DID NOT HAVE THE EXTERNAL BOX. COST ABOUT $195.00 BUT IT WORKS GREAT AND LOOKS NICE IN THE GMC DASH......KIETH AFTER REWORKING THE DASH AND INSTALLING A BATOMETER AND THE SUN TACH.....ALL ORIGINAL INSTRUMENTS..... http://kieth.smugmug.com/Trucks/66-G...8658&k=X8WmmMg |
08-20-2013, 11:39 AM | #116 |
Never did find out what the "stock" positions are for the red needles. Anyone know?
08-22-2013, 08:12 PM | #117 |
I have a 66 C20 with a 327 and TH400. Anyone know where the red line arrows were set from the factory? Someone?
08-23-2013, 02:57 PM | #118 | |
Senior Enthusiast
For example – assuming you have a 4 barrel 275 HP 327, maximum torque would be obtained at 2800 rpm and max rpm would be 4800. And this table may not be accurate for trucks as I don’t believe many of these engines were offered yet in the standard passenger trucks. http://www.carnut.com/specs/gen/chv66.html
08-24-2013, 01:07 PM | #119 |
Yeah, I've wondered the same thing about the 2 arrows. Thanks for the chart. Like you, I'm not sure if it applies to the trucks. I'm kinda shocked nobody here knows the answer. Very few questions are stumpers around here.
02-28-2015, 12:53 PM | #120 |
04-10-2017, 07:11 PM | #121 |
Going with the repo Sun Tach II on my 64 C10/283/TH350 with HEI. I know the green wire will connect on the - side (Brown Wire) of the distributor cap. But where should I connect my red (power) wire to? What about the ground (Black) and light (White) wires too? Is there a particular place to connect them too?
Thanks, Mark |
04-10-2017, 08:14 PM | #122 |
Moderator
Red: battery power (check fuse panel for BATT terminal)
Black: chassis ground (any metal) White: dash illumination (off headlight switch) |
04-11-2017, 05:05 PM | #123 | |
Gotta remember this was the era "Before" stutter boxes! People were still running Mallory & Sanderson Mags back then! |
06-17-2017, 08:24 PM | #124 | ||
This might not be germaine but I started it back when the weather was cold to let the car run some and the tach went to about 1/2 of what it should be reading. I replaced the batteries today as described above and that didn't do it. I'm going to make sure the "new" batteries are not dead and after that I'm out of ideas. Any suggestions? Thanks in advance - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-17-2017 at 08:38 PM. |
06-17-2017, 09:46 PM | #125 |
Moderator
Try cheap rechargeable AAs. They are 1.2V...
