Old 07-08-2011, 11:07 PM   #101
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Thanks Dave
It's been awhile... A long while...
Have been working a lot and remodeling the house after a water leak in the attic.
I got a new aluminum radiator for fathers day and installed it last week. I'll post pics and details this weekend. I'm also cleaning up my M/T valve covers and will install them this weekend. They look killer IMO
I'll post more soon
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 07-10-2011, 04:19 PM   #102
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
I got one valve cover done and installed today. Here are a few pics of it and the new aluminum radiator that I got for Father's Day
Tony
Tony
66 GMC LWB
Old 07-10-2011, 05:35 PM   #103
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: My 66 GMC LWB
Those valve covers are timeless.
What's the specifics on that radiator? Who made it, how much, etc...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 07-10-2011, 07:35 PM   #104
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Hey Shaky, I forgot that part in the post...
I got it from eBay (engineered products) it was $230 shipped
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_3321wt_948
It was not a direct drop-in. The top and bottom tank are squared off more than the stocker so I had to spread the radiator tabs open more to get it to fit... Other than that, it was a decent fit. It's a two row, but with 1" tubes like the top of the line BeCool and others.
I dropped about 23 degrees in temp with the swap
So far it's a good swap for me. Time will tell on how long it will last...
Tony
Tony
66 GMC LWB
Old 07-11-2011, 01:34 AM   #105
Dinos63
chevy only
Dinos63's Avatar
Re: My 66 GMC LWB
looks cool! nice call on m/t covers
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 07-14-2011, 10:44 PM   #106
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Thanks Dino
I was looking for you last Sunday at the GCC swap meet. Thinking that I might run into you
Tony
Tony
66 GMC LWB
Old 07-14-2011, 11:27 PM   #107
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Re: My 66 GMC LWB
CRAP! I thought the GCC thing was this coming weekend... Rats!
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 07-16-2011, 01:40 AM   #108
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Ya, the next one is August 7th. I found a left lower patch panel for the front fender for $5 Also got me a TCI deep 700r4 tranny pan for $10. There was actually quit a few parts for our trucks there last weekend.
Tony
Tony
66 GMC LWB
Old 12-30-2011, 04:24 PM   #109
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Hey, guess what???
I finally finished my valve cover install... Only took 5 months...
Tony
66 GMC LWB
Old 12-30-2011, 11:09 PM   #110
allaboutchevelles
allaboutchevelles's Avatar
Re: My 66 GMC LWB
What year truck did that brake booster and master cylinder come off of? How hard was it to install beside getting the mounting bracket?
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 12-31-2011, 07:23 AM   #111
Shaky
Shaky's Avatar
Re: My 66 GMC LWB
Originally Posted by AZ66GMC View Post
Hey, guess what???
Nice and tidy. Looking good!
Old 12-31-2011, 11:21 AM   #112
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
I got them from the local "pick-n-pull" from a 83 Chevy 4x4. I grabbed the brake lines and proportioning valve along with the pedal rod. I went on a 50% off sale and paid $30 for everything.
It bolted up to the 2 factory M/C holes with out any additional brackets. I drilled out the firewall for the bottom 2 holes on the newer M/C. You can see the top 2 holes were not used (has a total of 6 mounting holes).
I used my original pedal rod and cut/welded it to the new rod which kept the adjustability by retaining the original threaded part.
It took about 4 hours to install it and then a couple more reworking the brake lines.
BIG difference compared to the original single pot M/C... It will put you into the dash if your not wearing the seat belt when you slam on the brakes... Takes some get'n used too...
Tony
66 GMC LWB
Old 12-31-2011, 11:22 AM   #113
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Thanks Shaky
Tony
66 GMC LWB
Old 12-31-2011, 12:41 PM   #114
Zane M
Re: My 66 GMC LWB
Great truck. Thanks for sharing your updates.
Zane M is offline   Reply With Quote
Old 01-02-2012, 09:38 PM   #115
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Thanks Zane
I installed my rubber bed mat that I got for Xmas. It's for a '73-86 long bed Chevy/GMC. It's not exact, but it covers 99% of the wood
Tony
66 GMC LWB
Old 01-02-2012, 09:43 PM   #116
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
I also filled my dash so that I can install my Vintage Air controls and A/C vents. Since the PO butchered the radio slot, I figured that I might as well cut it all out and fill it solid, then go back and cut out what I need...
Before;
Cut, cut away....
Tony
66 GMC LWB
Old 01-02-2012, 10:42 PM   #117
allaboutchevelles
Re: My 66 GMC LWB
Very clean nice looking patch repair on the dash. Thanks for the info on the brake booster. I went to LKQ this past weekend and they had the 50% off sale going on. I couldnt find a decent looking booster to get. Everything was already about stripped to the bones.
Old 01-03-2012, 12:00 AM   #118
Dinos63
chevy only
Dinos63's Avatar
Re: My 66 GMC LWB
nice work!!
Old 01-03-2012, 02:40 AM   #119
Captainfab
60-66 Nut
Re: My 66 GMC LWB
Nice work on the dash
Old 01-03-2012, 10:23 AM   #120
McMurphy
McMurphy's Avatar
Re: My 66 GMC LWB
You are far more brave than I. Not sure I am confident enough to cut my dash like that !! Nicely done though.
What are those silver clamps with the wingnuts holding your patch on? I think this is the first time I have seen those....
I just looked at your Sonoma over on CarDomain, very nice there too!
I have an 03 stepside for a daily driver and I love it!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 01-03-2012, 07:23 PM   #121
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Thanks man! Sorry you couldn't find anything at LKQ... Those 50% off sales clean them out. I got to our sale first thing and almost had to fight for my parts... two other guys were all over the truck while I took my parts off alone... Was worried about missing tools
nice work!!
Thanks Dino! I gotta get ready for the next Dino's shing ding
Thanks Captainfab
LOL, thanks man I've seen your project progress and you are there, just take your time and you can do it all
The clamps are from Eastwood. I got (8) for $17 shipped on their last sale before Xmas. They work awesome Kindof a pain in the butt to get the first one on by yourself, but once on, they hold well.
You can find them here http://www.eastwood.com/intergrip-pa...-set-of-4.html
I'm working on a photoshop project that I will request everyone's input for my dash layout. Hope to have it done tonight and will post it on the 60-66 main board for your input.
Tony
66 GMC LWB
Old 01-03-2012, 10:06 PM   #122
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: My 66 GMC LWB
Checking in on you. Nice work. You did a nice job on the dash.
Alan's Classic is offline   Reply With Quote
Old 01-04-2012, 11:17 PM   #123
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
Thanks Alan
I posted a new thread requesting everyone's opinion on a few dash layouts. Please check it out and give me some feedback
http://67-72chevytrucks.com/vboard/s...83#post5102483
Thank you!
Tony
66 GMC LWB
Old 01-04-2012, 11:35 PM   #124
McMurphy
McMurphy's Avatar
Re: My 66 GMC LWB
Oh yeah, thanks for the linky !!
and thank you for taking a look at my rig. It is what it is... fat and grey like me
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 01-05-2012, 12:46 AM   #125
C@rnut001
Re: My 66 GMC LWB
Great truck and you have done some awesome upgrades on it...Keep it up and thanks for sharing your work and updates with us.
C@rnut001 is offline   Reply With Quote
