Old 09-23-2010, 11:36 PM   #101
68 short step
Re: project " Blue-Ray"
they are weather pack connectors, casper electronics is the manifacture, and summit is where i get them....ill look up the P/N of the ezact kit i get.
68 short step is offline   Reply With Quote
Old 09-24-2010, 08:36 AM   #102
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Not sure on pricing , But Oreillys sells weatherpak connectors and so does chevrolet.....$$$$ . It would be a local source if a guy was in a pinch , you need a special crimper for the wire ends and dont forget the weather seals. I love em , I use em every time I am wiring something up . Best thing since sliced bread
ksbrktracer is offline   Reply With Quote
Old 09-25-2010, 06:58 AM   #103
v502
v502's Avatar
Wow very nice build man.
v502 is offline   Reply With Quote
Old 09-25-2010, 11:46 AM   #104
rodstored-72
chevy truck fan
rodstored-72's Avatar
68 short step,
thank you, i appreciate the time.....
again great build!
rodstored-72 is offline   Reply With Quote
Old 09-30-2010, 03:09 PM   #105
68 short step
part number from summit on the connectors 103009
Old 10-10-2010, 06:33 PM   #106
68 short step
more progress to report, got the new aluminum be cool radiator...the mounting blocks were a bit to long for the factory style rad. hold downs...after looking at the big, ugly, 'plate style mount' i chose to shorten the blocks on the radiator and use the better looking hold downs...once it was trimmed down to fit, i put the electric fans on, and upper/lower rad hoses...ran my heater hoses (added a nice heater hose clamp), hooked up the steam line with a 'T', and the cooling system was complete..also put the hood on...then it was off to get tuned...the tune turned into a complicated matter, the computer i ordered was a e38 PCM from schram, and a t42 TCM....i received them both, and installed them... little did i know that that particalular PCM was outta a 06 v6 impala... so what we had to do was buy the HP tuner lience for that yr impala, and once we had that, we did a entire rewright of the PCM, for a 08 silverado with a 5.3 and DOD...once the PCM had the right software installed, then we could begin the actual 'tune' process....Glen worked his computer vu-do magic on it, and it came alive....once it was running i headed back home, only to get get 3 miles from the house, and run outta gas on the off ramp of the highway ( its kinda my friends fault, he talked me into passing the gas station in favor of trying to get to one closer to my house)... so once the truck was stopped, and not starting, we had to Mcguyver it... i had a old anti-freeze jug, behind the seat, and some plyers under the seat....so i disconnected the fuel line off blue-ray, and jumpered the fuel pump relay to fill the jug... once it was filled, i had my friend pour it into old red, while i took pics....it was a long trip.....but here are a few videos of the beast...(first vid, the sound isnt great, but the second video says it all)
Old 10-10-2010, 06:39 PM   #107
68 short step
click to watch the videos. no brakes were applied during the video either
Old 10-10-2010, 06:44 PM   #108
menace121978
menace121978's Avatar
! bad @ss buddy!!! sounds sik!!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 10-10-2010, 06:56 PM   #109
palposity
palposity's Avatar
Very impressive!!!!!
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 10-10-2010, 08:10 PM   #110
VA72C10
VA72C10
VA72C10's Avatar
nice!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-10-2010, 09:38 PM   #111
signgod2
signgod2's Avatar
I think i watched that video 13 times. Man that was cool. Was #'s did it put up on dyna tune? and did it sound good on those exhaust pipes or not?
signgod2 is offline   Reply With Quote
Old 10-10-2010, 10:15 PM   #112
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Awesome! Love the smoke show.
--Josh
Old 10-10-2010, 10:52 PM   #113
lnwlfbsktbll
lnwlfbsktbll's Avatar
yep, i'm definitely jealous
'87 SWB GMC LY6/6L90E
'70 JEEP CJ5... My new toy
'06 Hyundai Accent... DD
Build thread located at http://67-72chevytrucks.com/vboard/s...5708&posted=1#
lnwlfbsktbll is offline   Reply With Quote
Old 10-10-2010, 11:04 PM   #114
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress!
mcbassin is offline   Reply With Quote
Old 10-29-2010, 01:46 AM   #115
cagodinez
cagodinez's Avatar
Awesome build Don.
cagodinez is offline   Reply With Quote
Old 10-30-2010, 01:19 AM   #116
Gordonr1973
Home Built '87
Gordonr1973's Avatar
subscribing...
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 10-31-2010, 05:44 PM   #117
68 short step
on the home stretch now, got the A/C lines made up, vacuumed, and charged the system...the A/C blows cold, but the small electric fans arnt cutting it when the A/C is on, the high side pressure is higher then where i wanna see it at idel...so new fans are going in...also im going to retro fit a cruise control to work with this engine setup, more on that later....and here are some pics of everything so far...
Old 10-31-2010, 09:29 PM   #118
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress! that engine looks like it came in there from the factory.
Old 10-31-2010, 09:47 PM   #119
joe231
joe231's Avatar
Wow!!
Very nice!!!
CHEVY ONLY
Old 11-01-2010, 10:38 AM   #120
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice work Don.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-01-2010, 10:28 PM   #121
Gordonr1973
Home Built '87
Just a question for you...I've seen a few posts regarding custom rads that are bought from a certain guy (forgot his name) on ebay where he can do custom sizes, input / output etc etc and I'm wondering if you know if its possible to have that water hose come in the top passenger side of the rad instead of crossing the front of the motor?
I'm not sure if it has to be the way it is due to the circulation flow of the coolant through the rad and it's exit point?
I'm just getting ready for my motor swap (LQ9) and trying to get some planning done ahead of time for it.
Gordon
Old 11-02-2010, 02:14 PM   #122
inovermyhead
Gordon, Flex-A-Lite will make custom rads also. You can have one made w/in/out on pass side.
Don, fantastic work man. Just wish I could find me a body/paint guy to work on mine now. hummmm
inovermyhead is offline   Reply With Quote
Old 11-02-2010, 04:16 PM   #123
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by Gordonr1973 View Post
Just a question for you...and I'm wondering if you know if its possible to have that water hose come in the top passenger side of the rad instead of crossing the front of the motor?
I've always wondered about this too? It seems like the lower hose would have to cross to the other side of the engine too? Unless, you could have the fins placed in the proper orientation. Good question.
Old 11-02-2010, 05:32 PM   #124
68 short step
you can have both the in/out on the pass side, or both on the dr. side, or anything in-between....what i like about this setup is you can go into any parts store and tell them you need a rad hose for a chevy truck, instead of trying to remember the part number of the hose that fits with the outlet on the pass side..
Old 11-02-2010, 06:55 PM   #125
menace121978
entropy technologies is the company on Ebay that i got mine custom made from. awesome welds, price, product and service guys name is Tony. i'd post a pic but don't want to clog up Don's build. lots of pics in my build thread
"Dennis the Menace"
