Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Closed Thread
Old 10-25-2010, 09:37 AM   #101
70BLAZERX2
Re: Project 4.3 SS
Originally Posted by og350 View Post
wheels look nice! i wish the ss wheels were 8" wide! so when does the drop go in?
as soon as i get the $$ to get the drop kit..and a trailer hitch...and i also have a sir micheals rear roll pan i got on here to put on also.
Cant fix it while you drive it..It will get done soon enough.
70BLAZERX2 is offline
Old 10-27-2010, 01:53 AM   #102
SS Delux
SS Delux's Avatar
Re: Project 4.3 SS
Mine is O/D in fourth, is the 5 speed double overdrive ? how well do you think it would fit into an 87 square ?
SS Delux is offline
Old 02-16-2011, 08:26 PM   #103
70BLAZERX2
Re: Project 4.3 SS
I have my vortec intake,spyder injector,ecm,S10 wire harness and fuel pump for CPI
I will be swapping it over in the next few weeks.
93 S10 blazer vortec wire harness..93 S10 ecm..CPI intake.
Old 02-23-2011, 09:00 AM   #104
BigBlocksRule
Re: Project 4.3 SS
Great project, lots and lots of work but it sure looks like it's worth it.
I have bought two nice, straight short beds, both are the same green color you bought. I wonder what it is with folks with green trucks wrecking the front ends???
BigBlocksRule is offline
Old 05-06-2011, 11:24 PM   #105
jared.landis
jared.landis's Avatar
Re: Project 4.3 SS
Originally Posted by jb1016 View Post
I'm using the same LED parking lights...are they flashing fast, or not working at all? I had to use resistors with mine; they use so little power that the system thinks you have a bulb burnt out, and triggers the fast flashing.
I'm not the brightest caryon in the box when it comes to wiring and electronics. Could you explain where to install and what kind of resistors you are referring to. I am having the same problem and would like to fix it if it is that easy.
jared.landis is offline
Old 05-07-2011, 01:59 PM   #106
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Re: Project 4.3 SS
Here is a link to a pair on Amazon; you can find them a lot of places. You want 6ohm, 50watt resistors. I only know because Chevloray said they worked for him. And I had somebody put them in for me, because I'm useless with electrical stuff. But I think they come with instructions.
Edit: It won't let me post the link, maybe because it's too long...not sure. Anyway, just search google for "LED resistor 6ohm 50watt."
jb1016 is offline
Old 07-02-2011, 03:47 PM   #107
70BLAZERX2
Re: Project 4.3 SS
Intake swap coming soon and i am putting a 14 bolt 3.73 posi 454SS rear under it too...
Old 11-17-2011, 11:53 AM   #108
70BLAZERX2
Re: Project 4.3 SS
just turned 147,000 miles ...
Closed Thread
