Old 11-27-2013, 05:33 AM   #101
Steve-W
Steve-W's Avatar
Re: 1969 Custom/10 clean up
Originally Posted by litew8 View Post
Cool, you have a steering wheel similar to mine (I don't see them around). I didn't sandblast mine though, just sanded down the wood. Any idea what brand/model? I've enjoyed reading your build thread. I like seeing how it's done overseas. Keep up the good work.
I can see the similarity, I'll check if there is any brand on it..I haven't seen anything that cought my eye, but I'll check and thanks for the support!
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 11-27-2013, 12:02 PM   #102
TchncnDen
Originally Posted by Steve-W View Post
Then I got busy with my HEI ignition.. because I was smart enough to remove all the spark plug wires, assuming that there would be a mark on the distributor showing cylinder 1 .... But unfortunately I was wrong
So after some contemplating I realized that if the engine is at TDC ( top dead center ) that the rotor of the ignition should point to the first spark plug .. TDC can be seen on the harmonic balancer when the line Lines up with the 0 degrees mark.
1 cylinder must then be on the compression stroke , this I checked by taking off the valve cover and checking whether the rockers of cylinder 1 both had clearance .
the annoying part is that when the engine is at tdc , the rotor of the ignition is directly between two points on the distributor ... so I assume I take the one before the rotor as cylinder 1?, or after .. suggestions are welcome
Since timing is set as degrees before TDC, the #1 cylinder would be before the rotor. This is assuming you have the distributor marked as to where it was when you took it out. This should get you going, then set the timing with a light once running.
TchncnDen is offline   Reply With Quote
Old 11-27-2013, 07:24 PM   #103
Steve-W
Steve-W's Avatar
I didn't take out the whole distributor, only the cover, so the position of the rotor vs the timing on the balancer hasn't changed.
projects:
1969 Chevy C10
1950 GMC 100
Old 11-27-2013, 10:11 PM   #104
TchncnDen
Cool, I didn't get that part. Wire it up and you will be fine. #1 is just before the rotor.
Old 12-04-2013, 08:40 PM   #105
Steve-W
Steve-W's Avatar
I trust your expertise, it's just that if I turn the engine counter clockwise until the balancer reads 12 degrees ignition advance, the rotor is still not at the sparkplug before the rotor, so how much degrees advance would a 350 normally have?
projects:
1969 Chevy C10
1950 GMC 100
Old 12-05-2013, 03:35 AM   #106
litew8
litew8's Avatar
Can you post a picture of TDC and the rotor showing where it is sitting, or at 0, and where #1 is on the dist. housing? It might help.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 12-05-2013, 09:28 AM   #107
FrankieD
FrankieD's Avatar
Steve hope all is good Figured I would chime in here I would imagine you got most of your questions answered but headers are a real pain if you don't get the right ones and keeping the bolts tight are another thing also. Do you ever go to Summitracing.com, they have a few choices for the header bolts, the alien head s are good but they also sell bolts with a 12 point head and other locking type bolts. Hope this helps.
http://www.summitracing.com/search?S...header%20bolts
The stock headers are also a pain on my 95 K2500 we had to use a pry bar to get the holes to align.
Here are a couple of pix of the cermac coated headers I bought from Summit
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 12-05-2013, 09:45 AM   #108
JointTech
JointTech's Avatar
Your timing mark may not be accurate. Mine was way off. I could never find TDC using all the tricks on the forums like a piece of cotton or finger or a chop stick.
so I got one of these.
Amazon.com: Innovative Products of America 7880... Amazon.com: Innovative Products of America 7880...
makes it so easy I could do it!!
Cool build!
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 12-05-2013, 04:09 PM   #109
Steve-W
Steve-W's Avatar
HI Frankie, thanks and actually no, I haven't looked around on summitracing. My most frequent visits are to LMC or Tuckers, but I'll check it out for sure!
Originally Posted by JointTech
Your timing mark may not be accurate. Mine was way off. I could never find TDC using all the tricks on the forums like a piece of cotton or finger or a chop stick. So I got one of these.
thats a great piece of kit, I'm going to order one for sure
projects:
1969 Chevy C10
1950 GMC 100
Old 12-05-2013, 04:26 PM   #110
Steve-W
Steve-W's Avatar
Just googled "Header Bouten" (Bouten are Bolts in Dutch) and look what I found
So we do sell them in the Netherlands, but for now I'll stick with the allen bolts
and TDC (which is called BDP in Dutch...Bovenste Dode Punt) finders we have as well! never occurred to me to look for that:
projects:
1969 Chevy C10
1950 GMC 100
Old 12-08-2013, 07:06 PM   #111
Steve-W
Steve-W's Avatar
I was back working on the wiring and discovered that my 3 year old son helped me with color coding the wiring diagram
and can anybody tell me the purpose of the 8 black wire in the middle?
last question; does anybody agree that the position of my indicator arm looks odd?
projects:
1969 Chevy C10
1950 GMC 100
Old 12-09-2013, 01:08 AM   #112
Edmond
Edmond's Avatar
I believe that's the converter for if you put in a later style steering column.
And it looks like that is the case with yours.
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
Capelle a/d IJssel,
The Netherlands
Edmond is offline   Reply With Quote
Old 12-09-2013, 07:31 AM   #113
Steve-W
Steve-W's Avatar
Ah, ok, so since I'm putting in a complete new 12 circuit mini EZ wiring set, I can loose the converter?
projects:
1969 Chevy C10
1950 GMC 100
Old 12-11-2013, 09:23 AM   #114
FrankieD
FrankieD's Avatar
Steve I just got this today in my Summit email it might help you out on shipping
http://www.summitracing.com/customer...faqs/?aid=4265
Old 12-11-2013, 09:54 PM   #115
Steve-W
Steve-W's Avatar
Superb! thanks. While you're in the helping mode I posted a new thread regarding my wiring headache:http://67-72chevytrucks.com/vboard/s...d.php?t=607688
projects:
1969 Chevy C10
1950 GMC 100
Old 12-13-2013, 08:08 AM   #116
Steve-W
Steve-W's Avatar
Yeah!! got my new front window in today (sorry for the lousy picture)
and thanks to all your help I'm and going to attack the wiring this weekend and finally make some progress
I'll be off for two weeks with no reason to come online so:
I'm signing off, Happy holidays and don't drink and drive. see y'all in January!
projects:
1969 Chevy C10
1950 GMC 100
Old 01-03-2014, 06:47 PM   #117
Steve-W
Steve-W's Avatar
So back from the holiday's, hope y'all had great days with family and friends.
Poland had no snow, so no white xmas this year but driving back from Wroclaw to Berlin the roads where empty, so I could do 450 miles in just under 5 hours. (yes indeed almost a 100MPH average, thanks to lack of police in Poland and no speedlimit on the German Interstate)
went to work on the truck yesterday and didn't feel like attacking the wiring, so I decided to change the ignition lock cylinder.
I discovered that the previous owner had bought new door and ignition locks going through a box with miscelanious parts.
having no idea how to change it I turned to google and ended up at this great movie on Youtube:you gotta love youtube!
didn't get much more done, my mate was there working on his '69 Charger, so it was all talk and no show
projects:
1969 Chevy C10
1950 GMC 100
Old 01-11-2014, 04:44 PM   #118
Steve-W
Steve-W's Avatar
I have another thread going only for the wiring stuff: http://67-72chevytrucks.com/vboard/s...82#post6465482
and as I describe there, we got the wiring figured out! I didn't get everything hooked up yet, but atleast I now know where everything should go.
(I couldn't figure out the ignition switch and gauge cluster wiring)
hopefully I'll have some time tomorrow to get is mocked up and see if everything works, the I'll cust the wires to length and tidy them up.
and then...I'll still have plenty to do
projects:
1969 Chevy C10
1950 GMC 100
Old 02-17-2014, 08:21 PM   #119
Steve-W
Steve-W's Avatar
Another month has passed since I posted in this thread. I got some good tips in my other one regarding the wiring, so thats'all figured out!
I also had a thread regarding the wiring of the propane tanks and the mixer and although I didn't get any responds I worked it out, so I felt it was about time to test it!
filled up the engine and tranny with oil, put some water in it and guess what?
check the video!!
https://vimeo.com/86941619
projects:
1969 Chevy C10
1950 GMC 100
Old 02-20-2014, 04:49 PM   #120
Steve-W
Steve-W's Avatar
*Happiness bump*
check the video of me firing up the engine first test run after 2 years
projects:
1969 Chevy C10
1950 GMC 100
Old 02-24-2014, 07:19 PM   #121
Steve-W
Steve-W's Avatar
Got some more work done on the wiring, put in the wires for the dome and cargi light. I also bought some electrical plugs so I can shorten some of the EZ wires and a power splitter. it looks small, but is 5"s long, so I have see where it will fit. But I'll use it as a central point from where I can draw either battery power or ignition power.
Then I tried to splice a wire. I found a how-to in youtube which looked easy enough..but as you can tell from the pictures, I had a hard time and need more practice
first attempt:
second attempt:
Gawd..I can't look at these pictures without laughing, I need help to my defence, the solder wasn't clean, so it sputtered to much (don't know if that's the correct term?)
But I must say, besides the way it looks..it sure is strong. I'm here on the next picture pulling at the wire with my full 175 pounds
projects:
1969 Chevy C10
1950 GMC 100
Old 02-25-2014, 06:35 PM   #122
Steve-W
Steve-W's Avatar
wanted a change from the wiring, so I took my heater apart. Now I can't remember whether it was working in the first place, but if I put a feed to the connector and a ground to the body, the damn thing should start spinning right?
Also my top waterhose started leaking after I had fired up the engine last weekend, so I took it off; *Shock and Awe*
what is that?
projects:
1969 Chevy C10
1950 GMC 100
Old 02-26-2014, 08:38 AM   #123
FrankieD
FrankieD's Avatar
Steve that looks like some kind of corrosion did you flush your radiator?
Old 02-26-2014, 10:28 AM   #124
Steve-W
Steve-W's Avatar
you're talking about the white chunks right?
OMG..I can't believe I forgot to do that...you're right because I just unbolted it, disconnected the hoses, emptied it and that was it. is there a special fluid you should flush it with?
(hope that's not a dumb question)
now the cooling lines in the engine can get clogged right..
projects:
1969 Chevy C10
1950 GMC 100
Old 03-10-2014, 06:40 PM   #125
Steve-W
Steve-W's Avatar
Checked with a local repairshop that specializes in US classics and they have some stuff from JB to flush the cooling system, so I'll use that.
but something's come up, something I had to check before I dumped the old cabine at the scrapper.. the cabines are different.
the old one was non AC, the new one had AC, so the heatercore doesn't fit!!
the cab is painted and mounted, I can't possibly weld in a piece..or can and should I. the average temperature here in Netherlands is 62F, so I can do without an AC
if anybody knows a solution I'd like to hear it!
Also in my headlight there is a small bulb, I guess you call it the park light right? it's being held by a small clip..but it's empty on the right side, what do you call the bulb holding thingy? I can't find it on lmc
projects:
1969 Chevy C10
1950 GMC 100
c10, europe, netherlands, rebuild, swapped
