Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 03-21-2017, 07:04 PM   #101
docrock
docrock's Avatar
Re: My 42 Project
I have been looking for about a year and have not won any on ebay or seen any good ones on craigslist. I still think the ford ones if you cut the square part at the running board it might work. You are doing great to have that many sets.
I heard that the 37-8 fenders are wider because of the narrower bed.
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 03-21-2017, 09:27 PM   #102
docrock
docrock's Avatar
Re: My 42 Project
Tail lights installed
Old 03-21-2017, 10:19 PM   #103
joedoh
joedoh's Avatar
Re: My 42 Project
I think the 37-8 fenders have a style line around the wheel opening, but are the same width as 41-46, I believe its the 39-40 that are wider, you can usually spot them by the tiny little tailgates with the script chevrolet on them. I know where a 39-40 bed is with fenders but its on a different truck and cant be separated, well, by the owner anyway. I could buy the whole thing and split it I guess.
I have three cabs, three extra doors, four front clips, four beds (including what I think is a 1940 gmc steel floor bed), three sets of running boards but only 2.5 sets of fenders. I can go buy this truck with the 40 fenders, but really all I need is the fenders, not trying to be the illuminated collector.
funny story about your ford fender idea, I bought the single passenger fender I have from a guy who I saw in a craigslist ad that had a bunch of fenders hanging from the rafters, I asked if he had any 41-46 and he said "dunno, come look". this is the complete 41 he had, it was actually an older (40?) cab with the 46 front clip and a 46 long bed on a 50 chassis. you can see some of the fenders hanging that I spotted in the ad
I went and looked and I thought I found a pair but the drivers side had a spare dimple in it and on closer inspection was a 40 ford, so it fooled me. I took a picture of the running board attaching area because I had no idea what it was till I got home and looked up what it was.
I bet you are right, only the truly cognoscenti would spot it.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 03-30-2017, 01:08 AM   #104
docrock
docrock's Avatar
Re: My 42 Project
I have noticed that when the engine is running it smells a little rich. I checked the carb and did not realize I had put a 1407 Edelbrock which is a 750 cfm. Way too much for a 305. So did a little research and found out that the holley 1850 600 cfm car has vacuum secondary's so it will only use the fuel it needs. I also found that my carb gasket was leaking air so that made it hard starting. It sure starts nice now. So much smoother idle too. I also noticed that it is not cooling well enough so I think I will look for an auxiliary fan.
Old 03-30-2017, 09:26 AM   #105
solidaxel
solidaxel's Avatar
Re: My 42 Project
What is wrong with using fiberglass fenders on the rear
After they were painted I even forget they are fiberglass
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-30-2017, 06:39 PM   #106
joedoh
joedoh's Avatar
Re: My 42 Project
thats a good looking truck solidaxel!
Old 03-30-2017, 10:17 PM   #107
docrock
docrock's Avatar
Re: My 42 Project
That looks so cool. I am having my fiberglass fenders delivered tomorrow. I can hardly wait to paint them. I wonder if the holes are pre drilled
Old 03-31-2017, 11:38 AM   #108
solidaxel
solidaxel's Avatar
Re: My 42 Project
The ones on here were NOT drilled, and we had to add a brace on the bottom rear to stiffen them up a bit
Thanks Joedoh, it is a fun driver!
LS 3 4L70E
Old 04-01-2017, 07:57 PM   #109
docrock
docrock's Avatar
Re: My 42 Project
Got the fenders. Now where do they go? Can someone measure from the bottom of the rear fender to the bottom of the bed?
Old 04-05-2017, 02:52 PM   #110
hewittca
hewittca's Avatar
Re: My 42 Project
I wandered over here from the 67-72 message board and I'm glad I did. You've got a beautiful truck! I wish I could help you on the rear fender positioning, but I'm just here for the ride. Good luck!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 04-06-2017, 09:58 AM   #111
solidaxel
solidaxel's Avatar
Re: My 42 Project
I don't have the truck over here anymore......... but the running board attachment at the front of the fender will say a lot about how high (level) or low they will mount
I did add a third brace for the running boards at the "step" area, just a fyi to support the plastic fenders
LS 3 4L70E
Old 04-06-2017, 03:03 PM   #112
solidaxel
solidaxel's Avatar
Re: My 42 Project
I was with the truck this AM and took a measurement from the bottom of the Mar-K to the bottom of the rear fender looked like 8 3/4" how does that sound!
LS 3 4L70E
Old 04-06-2017, 04:47 PM   #113
docrock
docrock's Avatar
Re: My 42 Project
Thanks hewittca for checking out my project. Thanks solidaxle that looks very close. It lines up the front and rear of the fender thru the center of the wheel
Old 04-06-2017, 04:50 PM   #114
docrock
docrock's Avatar
Re: My 42 Project
Solidaxle, those fenders you put on your truck are much nicer then mine. Mine are pretty flat on the outer curve and not much lip at the fender edge. Where did you get them?
Old 04-07-2017, 11:15 AM   #115
solidaxel
solidaxel's Avatar
Re: My 42 Project
I will look and see if I can find the receipt.............. hold your breath !!
LS 3 4L70E
Old 01-17-2018, 07:04 PM   #116
docrock
docrock's Avatar
Re: My 42 Project
Finally painted the fenders and tailgate
Old 01-17-2018, 07:08 PM   #117
docrock
docrock's Avatar
Re: My 42 Project
Installed
Old 01-17-2018, 07:10 PM   #118
docrock
docrock's Avatar
Re: My 42 Project
I am digging the green even more
Old 01-17-2018, 07:20 PM   #119
docrock
docrock's Avatar
Re: My 42 Project
So besides getting the body done, I finished the brake and directional.
Added a cooling fan to assist the water pump fan blade.
I had a holley 600 on it and it was having problems. Swaped an Edelbrock 600 and runs fine. has good vacuum with the luminati cam. I has a lot of exceleration. I was doing my timing and had no marks. Found out it was behind the waterpump. Short pump doesn't work for that. Took the front apart cut a new TDC on the dampener. Put it all back together done. Running about 8 degrees of timing. Might go a little more after a road trip or two.
Still need to hook up a wire to my 700r4 for lockout.
Old 01-17-2018, 11:52 PM   #120
joedoh
joedoh's Avatar
Re: My 42 Project
gorgeous work! those fiberglass fenders sure turned out nice!
Old 01-18-2018, 10:58 AM   #121
solidaxel
solidaxel's Avatar
Re: My 42 Project
Glad you made a decision on the fenders they look great
Well we are having some water leaks in the "milliondollar radiator" and I don't remember how much trouble it is to remove the front end, I have slept too many times since mock-up.
Fenders to running boards, hood, core support, cooling lines and rad hoses what am I forgetting?
LS 3 4L70E
Old 01-18-2018, 03:07 PM   #122
docrock
docrock's Avatar
Re: My 42 Project
I know the pain. If you don't pull it all apart, you will scratch the paint on something. yeah trans lines, radiator hoses, cooling fan, wire harness, front fenders, hood. Wow that is some work.
Thanks Joedoh
Old 01-18-2018, 03:13 PM   #123
docrock
docrock's Avatar
Re: My 42 Project
Took the truck out for a ride. Very soft ride with stock suspension. Brakes work nice. That motor may have way too much horse power for the stock front end. I may have to change the steering to a rack or vega box or mustang 2.
The steering is tight but its almost like the wheels are off the ground. Maybe a steering dampener might do the trick
Old 01-18-2018, 11:20 PM   #124
solidaxel
solidaxel's Avatar
Re: My 42 Project
Can you dial in a few more degrees of castor?
LS 3 4L70E
Old 01-21-2018, 06:45 PM   #125
docrock
docrock's Avatar
Re: My 42 Project
@solidaxle, I will check that out. It makes perfect sense, that could be it.
