Old 08-08-2013, 12:22 AM   #101
unclefreddy
unclefreddy's Avatar
Re: Show me your 4x4 Suburbans!
I like it ...........
unclefreddy is offline   Reply With Quote
Old 08-20-2013, 08:11 PM   #102
BennettGM
BennettGM's Avatar
Here's mine - 72 2wd sitting on an 86 3/4 4x4 suburban frame
72 Suburban 3/4 ton 4X4
BennettGM is offline   Reply With Quote
Old 08-25-2013, 12:01 PM   #103
bullington
All around good guy
bullington's Avatar
Here is another.
bullington is offline   Reply With Quote
Old 08-25-2013, 01:41 PM   #104
Bigdav160
Bigdav160's Avatar
Here's mine. It's missing a little clear coat. Hopefully I can get that corrected by next year.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-31-2013, 10:10 PM   #105
rjsdad
rjsdad's Avatar
I like that Bigdav. Love that green.
Jeff
rjsdad is offline   Reply With Quote
Old 08-31-2013, 11:37 PM   #106
nbrfd007
nbrfd007's Avatar
How was the fit on the 86 frame? Much fab work?
nbrfd007 is offline   Reply With Quote
Old 09-01-2013, 03:47 PM   #107
briank
Looks like the rear tire sits forward a bit
briank is offline   Reply With Quote
Old 09-06-2013, 09:23 PM   #108
gumbys10
I've had that problem before when swapping chassis, I just take it to the local spring shop and the redrill the center locating pin and move the axle back. Then you just adjust line fitment and shock fitment and check driveshaft length.
gumbys10 is offline   Reply With Quote
Old 09-17-2013, 09:17 PM   #109
ac/bc
no pics yet, just got back on after about an 8 or 10?? year hiatus. I'm passing on the 71 original 4x4 burban (bad rust, were probably gonna turn it into a rat/beach ride)to my stepson to make room for the new 1970 burban ambulance that's getting swapped to 4x4. I got lucky on that one. super clean 51k original Oregon miles.
hopefully have pics of both SOON
ac/bc is offline   Reply With Quote
Old 09-18-2013, 03:32 AM   #110
In The Ten Ring
I have driven a couple 1972 Suburbans, all 3 speed manuals in the floor, diesels. Very slow off the starting line! This was at a govt facility where speed wasn't a priority.
Ever since then, I've wanted one. My dream would be a factory 3/4 ton, 4x4, 4 speed manual 327, 396, or 402, with front and rear AC, power steering, and power assisted brakes. I like a bench seat up front. 3 row seating. I'm not sure which type of rear doors I like as I like them both.
I'm a single guy so I'm not sure what use I'd have for it, but I do have a big driveway! And a love for the body style.
Maybe next year!
In The Ten Ring is offline   Reply With Quote
Old 09-19-2013, 10:54 AM   #111
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Man you guys are making me get and 'Burb!
Great pictures and stories, keep them coming.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 11-12-2013, 05:36 PM   #112
BK72BURB_3/4Ton4x4
BK72BURB_3/4Ton4x4's Avatar
1972 K20 454 bored and stroked to 496-TH400-NP205-8600 GVW locker in rear. Just got it back from the bodyshop after new windshield + seal turned into $600 of new metal rust-o-ration around the pinch. All sealed up now and saving nickels and dimes for Vintage Air project next.
BK72BURB_3/4Ton4x4 is offline   Reply With Quote
Old 11-12-2013, 05:47 PM   #113
unclefreddy
Awesome burb you got there BK72BurB. What color is that burb ? Is that a 4 inch lift with 35's ?
Old 11-12-2013, 07:01 PM   #114
BK72BURB_3/4Ton4x4
Yes, it's a 4" lift with 35x12.5x18. The color is White/Ochre/White according to the label in the glovebox
Old 11-13-2013, 05:01 PM   #115
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Very cool Burb, and that is my favorite color combo on this body style. Love the later generation 454’s too. Being your Burb doesn’t have A/C you can remove the compressor if you want. The A/C delete idler pulley is Napa NBH 38008 and the belt would be a PBH 6K984. That doesn’t look like the correct alternator for those particular brackets so the belt number above may not fit and you might have to go a few sizes bigger or smaller.
This is how the A/C delete belt configuration looks on an 8.1L. The L29 7.4L bracket belt routing is essentially the same.
DirtyLarry is offline   Reply With Quote
Old 11-13-2013, 07:32 PM   #116
BK72BURB_3/4Ton4x4
Great info, thank you! I plan on installing a Vintage Air Gen IV system in the not so distant future so likely letting the compressor spin until then.
BTW - I also have a '91 V2500 Suburban and totally dug reading the flickr build up on your '89. But, when I bought the '72 I made a deal with my wife to let the '91 go. So after 13 years of great service, it's looking for a new home
Old 11-14-2013, 12:49 AM   #117
DirtyLarry
DirtyLarry's Avatar
Good deal, if you’re going the vintage air route the compressor you have now (HT6) is the best A/C compressor GM ever used in my opinion. The HT6 will work great with the vintage air goodies as it is just as good, if not better, than the Sanden used in aftermarket A/C systems.
You’re selling a clean ’91 to build up a ’72? Ouch… I love the 67-72’s as much as the next guy but don’t think I could sacrifice a clean ’91 for one. Today’s 1991 is tomorrow’s classic Burb as the ’71 is now. Although, in CA there are lots of reasons to want to go with an older pre-emissions rig.…I get that. Either way you go, you will have a sweet burb!
Old 11-14-2013, 05:23 PM   #118
BK72BURB_3/4Ton4x4
Yeah, to own two "end of an era" Suburban's is pretty cool but one big car too many in my driveway. The CA smog law factor is definately the reason I decided to make the switch. Latest CA laws now require I smog my 7.3 diesel Excursion...$50 every other year disappears from my wallet; smog tech starts it, performs a visual, checks my gas cap, revs it up, hands me an invoice...what a scam.
Old 11-16-2013, 12:29 AM   #119
60sIron
60sIron's Avatar
Was thinking of selling my K20 Burb. that I've had for 20 years. But on doing research on the value, I'm getting excited about it again. Thinking on keeping her.
60sIron is offline   Reply With Quote
Old 11-16-2013, 12:32 PM   #120
BK72BURB_3/4Ton4x4
Wow, great clean example. Go with your gut...keep it!
Old 11-24-2013, 03:24 PM   #121
1 MPG
Originally Posted by dougo View Post
here's a couple of mine...
What's your wheel and tire package? The stock custom look is what I'm after.
1 MPG is offline   Reply With Quote
Old 11-26-2013, 02:08 AM   #122
60sIron
60sIron's Avatar
Sorry for the delay but I don't remember off hand. Wheels are 16.5, I'll measure offset and width as close as I can after Thanksgiving.
Old 12-12-2013, 05:15 PM   #123
6600DURAMAX
6600DURAMAX's Avatar
I've been looking for a clean 4x4 suburban for a while now if anyone knows of one please let me know, need more room than the truck has for the family.
Great looking rides on here!!!
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 12-12-2013, 06:09 PM   #124
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
There one in one in the For sale section right now that doesn't look to bad.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-21-2013, 11:01 PM   #125
PHAT TONY
PHAT TONY's Avatar
I think it looks better than "not bad"; not sure if I'm trying to convince myself to buy it or NOT to buy it.....wishy-washy for sure.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
