Old 03-10-2011, 08:37 PM   #101
Normy71
Re: Mieser's 71 Short Wide Project
Looks good
Do you have to drill holes for the shock relocators ?
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 03-10-2011, 08:40 PM   #102
VA72C10
VA72C10
VA72C10's Avatar
frame looks good!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-10-2011, 08:53 PM   #103
Mieser3
Mieser3's Avatar
Originally Posted by Normy71 View Post
Looks good
Yes, you have to drill 3 holes in the frame to mount the shock relocators.
Jay
1956 Chevy 210 Sedan
1970 Camaro Z-28/RS
1970 Chevelle SS 396 (numbers matching L34 car)
1971 Chevy SWB Fleetside with 1967 front clip - in progress
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438156
Mieser3 is offline   Reply With Quote
Old 03-10-2011, 08:54 PM   #104
Mieser3
Mieser3's Avatar
Originally Posted by VA72C10 View Post
frame looks good!
Thanks! And thank you for the PB hood hinges!
Jay
1970 Camaro Z-28/RS
Old 03-11-2011, 01:50 AM   #105
CheyenneShop
CheyenneShop's Avatar
Looking sweeeeeeet!
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 03-11-2011, 04:46 PM   #106
bmfpeterson
bmfpeterson's Avatar
looking good buddy did you get your gas tank yet? im still waiting for mine...... but it will be worth it im sure!
I like the look of those rear trailing arms! I built mine out of 2x3 tubing should have just used round looks nicer!
bmfpeterson is offline   Reply With Quote
Old 03-11-2011, 06:40 PM   #107
Mieser3
Mieser3's Avatar
Thanks!
Haven't received the gas tank yet. Tracking info says it should be here on Monday......definitely ready for it to arrive so I can get some more things accomplished on the truck.
Jay
1970 Camaro Z-28/RS
Old 03-11-2011, 06:48 PM   #108
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Just found your build thread very nice...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-16-2011, 08:23 PM   #109
Mieser3
Mieser3's Avatar
Gas tank is now installed. It's a Boyd Welding tank......highly recommended!
Jay
1970 Camaro Z-28/RS
Old 03-16-2011, 08:28 PM   #110
Mieser3
Mieser3's Avatar
A few more pics of the tank.....
Jay
1970 Camaro Z-28/RS
Old 03-16-2011, 08:29 PM   #111
heymoe
heymoe's Avatar
Very nice!!
My build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=371235
heymoe is offline   Reply With Quote
Old 03-16-2011, 08:31 PM   #112
72k5zl1
72k5zl1's Avatar
looks goood!
72k5zl1 is offline   Reply With Quote
Old 03-16-2011, 08:32 PM   #113
Mieser3
Mieser3's Avatar
Originally Posted by 72k5zl1 View Post
looks goood!
Thanks!
Jay
1970 Camaro Z-28/RS
Old 03-16-2011, 10:51 PM   #114
CheyenneShop
me likes!!!
72 3/4 long 4X4
69 SWB "Prospector"
Old 03-17-2011, 02:00 AM   #115
Captainfab
60-66 Nut
Yes Mr. Boyd does some nice work.
Your truck is looking good
Old 03-17-2011, 11:33 AM   #116
bmfpeterson
looks good! still have no tracking info its killing me! good progress!
Old 03-17-2011, 12:14 PM   #117
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Great project and eh, you're shop's alright too, I guess...
Thanks for the pictures of the detailed progress!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 03-17-2011, 12:46 PM   #118
67_ShortFleet
67_ShortFleet's Avatar
I wonder if that brown primer would wipe off with lacquer thinner? Then you would have a patina. Are the spindles cpp modular? Keep up the good work!
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 03-17-2011, 02:25 PM   #119
Mieser3
Mieser3's Avatar
Thanks for the comments everyone.
I never even thought about using lacquer thinner to see if the primer would wipe off......might have to give that a try. Yes, the spindles are CPP modulars but they are 73-87 spindles.
Jay
1970 Camaro Z-28/RS
Old 03-17-2011, 02:30 PM   #120
Mieser3
Mieser3's Avatar
I did have a question regarding the routing of the fuel line. The new tank hangs down quite a bit and the inlet for the fuel line is on the bottom right front corner. Will I have any problems with fuel flow seeing as how I'll have to route my fuel line up vertically several inches to be able to tie it to the frame? I was planning on running a 90 degree bend up from the inlet with the fuel line and then running another 90 degree bend to the right to get the fuel line to the frame. Any problems with running that many bends or should I minimize the number of 90's I'm running? At this point I don't plan on running an electric fuel pump.....but will if I need to I guess.
Jay
1970 Camaro Z-28/RS
Old 03-17-2011, 02:43 PM   #121
bmfpeterson
I'm not too sure on the bends but I am planning on the same routing method but i have an electric pump??? I would think that the mechanical pump should be enough to handle the few 90's that you plan on doing????
Old 03-17-2011, 02:47 PM   #122
Mieser3
Mieser3's Avatar
That's what I'm hoping too. I just want to make sure the the fuel flow will not be restricted by that many bends and that there will be no issues getting the fuel to flow up vertically from the inlet on the tank.
Jay
1970 Camaro Z-28/RS
Old 03-17-2011, 02:54 PM   #123
67_ShortFleet
I have VW's also. This guy wet sanded primer off.
http://www.cal-look.com/forum/image-...oject-patina!/
Matt
HAPPILY DIVORCED!
Old 03-17-2011, 03:16 PM   #124
heymoe
heymoe's Avatar
Jay,
I have a mechanical pump and my tank is the same design and so far I have zero issues with fuel. I have a 90deg fitting at the tank and a 90 correcting the run back to the fuel pump.
Hope this helps.
Old 03-17-2011, 06:37 PM   #125
Mieser3
Mieser3's Avatar
Originally Posted by heymoe View Post
Jay,
Hope this helps.
That helps a lot. Thanks for the info Matt. I appreciate it.
Jay
1970 Camaro Z-28/RS
