Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 10-13-2011, 03:10 PM   #101
Scottshotrods
Re: Vintage Air Sale
Originally Posted by yank View Post
Justin looking to put A/C in my truck over the winter.Looking for a quote on SureFit kit 941171 with a R4 compressor bracket and a serpintine pulley compressor. Might go with the bulk head fitting since my firewall has been smoothed.
Mike Palmiter
P/M sent
Justin
Scottshotrods is offline
Old 10-15-2011, 04:13 PM   #102
67lowered
Justin
P/M sent for surefit 941170. Let me know if you need any other info
thanks
67lowered is offline
Old 10-15-2011, 04:28 PM   #103
Scottshotrods
Originally Posted by 67lowered View Post
Justin
thanks
Pm sent
Justin
Old 10-17-2011, 12:25 AM   #104
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
Looking for pricing on Gen IV system for my '71 GMC. Factory air truck, but will not need lines and compressor, using compressor on LS1 engine, which means I am on my own as far as lines are concerned!!!
Looking forwards to your response!!!
Mike
Nothing cool anymore, I am old and boring....
schwoch1 is offline
Old 10-17-2011, 10:36 AM   #105
Scottshotrods
Mike
I sent you a p/m
Justin
(805)485-0382
Old 10-20-2011, 10:59 AM   #106
dean jendro
Old and crusty
dean jendro's Avatar
Justin,
Need a quote for a Gen4 system for my '64' Chev. I do not need the compressor as I will be using the stock compressor on my 5.3LS motor. I went this direction so I could retain all the stock LS serpentine system.
Dean
dean jendro is offline
Old 10-20-2011, 12:00 PM   #107
Scottshotrods
Originally Posted by dean jendro View Post
Justin,
Dean
P/m sent
Justin
Old 10-20-2011, 12:45 PM   #108
Scottshotrods
Vinatge air just released there sure fit kit for the 64-66 chevy trucks and this is a 100% bolt in and this is in there GEN IV KIT THE BEST AC KIT ON THE MARKET!!!!!!!!!!!!!
Justin
Old 10-22-2011, 07:21 AM   #109
mighty_mike015
Just a piece of information to you LS swap guys. Vintage Air says that the LS compressors should not be used with there kits because they are variable displacement compressors and will burn up/fail prematurely. I have not personally experience this, but want to pass on what I have heard, so you aren't swapping out compressors a year down the road. I'm working on scanning all the necessary components into ProE and designing a bolt in bracket system for the serpentine Sanden compressor that Vintage Air kits use. Hoping to have a model worked up in a couple weeks.
mighty_mike015 is offline
Old 10-22-2011, 08:46 AM   #110
dean jendro
Old and crusty
Never heard this one before. Not being an air conditioning expert I don't know how to respond. I know lots of Silverado LS owners who don't have any troubles with the stock compressor. What about the Vintage Air system makes them fail prematurely?
Old 10-22-2011, 09:38 PM   #111
mighty_mike015
I'm not an AC expert either, but I'm going to guess since they are variable displacement, the stock LS computer will control the compressor stroke or compression somehow depending on the load. The Vintage Air probably just runs them full bore because they don't have a computer to control it. I really don't know, that's just my interpretation of it. Anyways, I originally learned this from the Vintage Air Q and A during the 48hourcamaro build at Ridetech. I've tried to find the video, but no success so far.
Old 10-22-2011, 10:46 PM   #112
Mike Bradbury
Mike Bradbury's Avatar
Scott I'll send you a PM for a quote on a complete system for my '69
Mike
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline
Old 10-22-2011, 11:41 PM   #113
Scottshotrods
Mike
p/m sent
Justin
Old 10-23-2011, 10:48 PM   #114
Scottshotrods
In referance on LS comp should not be used with vintage air kits this is a new one for myself.I have sold several dozens of ac kits with customers running ls motors with factory ac comp on them and I have never had one customer call me back and say there was a problem.
On a other note we have a customers hotrod we installed the new gen IV in with a ls motor and factory comp on the motor and this car is driven 5 days a week and he has never had a problem the only thing he complained about was the ac blows to cold for him.But then he said when he did not have it in his car his wife would not ride with him anywhere.If he was having a problem I would be the first to know about it he tells me everthing about his car
Justin
Old 10-24-2011, 08:20 PM   #115
PGSigns
PGSigns's Avatar
Justin
I tried to find some info on the GenIV for the 64 to 66 trucks with no luck. To you have any information you can share or an idea when VA is going to post it on their website?4
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline
Old 10-24-2011, 10:36 PM   #116
Scottshotrods
Here is some more info to all who has a ls motor in there truck and the ones who are running the factory comp
We do not recommend using the ls factory compressors off of the camaros,gto's or vettes because they are a variable displacement type compressor and our epansion valve metered system requires a fixed displacement type compressor.
The truck ls motors are the only motors that come with a fixed displacement type compressor and this will work fine with no problems.
Justin
Old 10-24-2011, 10:38 PM   #117
Scottshotrods
For the gen IV sure fit kit for the 64-66 trucks they are all done and ready to ship and Vintage air is doing there best to have the instuctions uploaded to there site this week
Justin
Old 10-25-2011, 08:40 AM   #118
dean jendro
Old and crusty
Justin
Thanks for this info Justin. My whole setup is from a 2003 Silverado so it should work out fine.
Dean
Old 10-25-2011, 08:42 AM   #119
dean jendro
Old and crusty
Justin
Justin
Thanks, Justin
I will wait to read the install instructions to make certain I'm not missing something then I'll call you to order.
Dean
Old 10-25-2011, 06:12 PM   #120
mighty_mike015
Thanks for the verification Justin.
Old 10-28-2011, 10:31 AM   #121
boonedogs72
boonedogs72's Avatar
looking for a price on a complete kit for 72 blazer non factory air and it has a serp setup from 95 chevy.
boonedogs72 is offline
Old 10-30-2011, 11:10 AM   #122
Scottshotrods
P/m sent
Justin
Old 11-01-2011, 09:36 PM   #123
Scottshotrods
64-66 surefit instructions are all up at vintage air now take a look at them and let me know if you have any questions.
Justin
Old 11-02-2011, 07:28 AM   #124
PGSigns
PGSigns's Avatar
Looked like a nice setup. Gotta wait a while bought a 03 duelly Monday and need to recover a bit.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline
Old 11-02-2011, 07:49 PM   #125
dean jendro
Old and crusty
Justin,
Great talking with you today. Can't wait to see my GenIV system for my "64" Chevy short step project. It should make a sweet ride when done.
Dean
Closed Thread
