Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 12-29-2011, 11:33 AM   #101
modblacksmith
modblacksmith's Avatar
Re: Build of my 72 C/20
Thanks guys, I'm tryin to keep going on this until the day comes that I just have to pull the sheet metal off. I don't have any place to put it right now so the body off is going to have to wait until I get a larger garage to work in.
Professional hot glue and pop cycle stick engineer.
72 K/20 soon to be C/10, 454, Th400, 9” rear.
01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler.
78 Bahner 19’ jet boat, 460 Furd turd.
modblacksmith is offline   Reply With Quote
Old 01-01-2012, 02:48 AM   #102
modblacksmith
Update
I had the day off on Friday so the crew and I went to the pick and pull yard and I spent four hours yanking leaf springs out, somebody wasn't burning with diesel that morning and forgot a lot of the tools we needed and brought a lot of stuff we didn't need. There's a set of 52 inch springs in the garage already torn down and almost ready for paint, just need the buckets to show from DIY.
Old 01-08-2012, 07:52 PM   #103
modblacksmith
Some of the new parts, almost all the crossover steering parts and the DIY4X spring buckets. I still need to get a rebuild kit for the 2WD steering box, a couple weld in bungs for the other two heim joints to make my tie rod and some other odds and ends. The 3/4" bolts for the steering linkage are grade nine, there the same ones that Cat uses on there dozers, should of called this project overkill.
I'm going to start building my front cross member for the 52" springs this week. I still need to press out the bushings and get new ones coming this week.
Old 02-25-2012, 09:27 PM   #104
modblacksmith
Update, I installed my new cross member and the 52" springs last weekend, but I'm not happy with them so I'm going to tear apart the ones out of the rear and build a new set for the front to net more lift. I'll post some pics soon.
Old 02-25-2012, 11:27 PM   #105
UBLUZIN
Were did you get the cross over stuff?
UBLUZIN is offline   Reply With Quote
Old 02-26-2012, 03:28 PM   #106
modblacksmith
The heim joins and tube inserts I ordered of eBay, the Pittman arm is off a 99 Dodge 2500, that I drilled out to accept the 3/4" bolts. I cut and drilled the arm for the 60 out of 5/8 plate.
Old 03-05-2012, 09:32 PM   #107
babylonflyer
babylonflyer's Avatar
cool build..... waiting to see that truck in action!!!
babylonflyer is offline   Reply With Quote
Old 03-05-2012, 10:15 PM   #108
modblacksmith
Thanks, me too. It's completely tore apart right now, she's getting 52's in the front and 56 inch springs in the rear. I'll try to post pics soon.
Old 03-05-2012, 10:20 PM   #109
mjensen
mjensen's Avatar
Oh yeah! You better post pictures of that mod I ended up just going all new springs on mine.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 04-14-2012, 11:47 AM   #110
modblacksmith
Little bit of an update, I installed all of the springs and I'm still not happy. I lost almost three inches of lift in the rear with the 56's. Thinking I need to pony up and buy all new springs.
I did some wheelin and dealin and picked up a NV4500 5 speed last night though.
I'll try to get some pics up soon.
Old 06-01-2012, 08:34 PM   #111
modblacksmith
BIG UPDATE
Its been a while so I'll bring you up to date with the latest changes.
Built my own front cross-member adding 1.25" of lift over the B52 kit. I installed the first set of 52" springs and didn't like how soft they were so i took the ones out of the rear and re stacked them to make the springs handle the big block better. Added my new steering box and finished the crossover steering as well.
I had problem with the crossover right off the bat, when I turned my truck was shifting from side to side about 1.5". Come to find out that my front shackles are to long so I ordered the flush front shackle mounts from DIY4X.com and built new shorter cross tied shackles. Trying to get around building a panhard bar for the front. I have been playing with the idea of doing hydro assist too.
I'm in the middle of rebuilding and installing the 56" springs in the rear, pics to come.
1 of 2
Old 06-01-2012, 08:39 PM   #112
modblacksmith
2 of 2. New wheels and sneak peak at rear bumper.
Old 06-01-2012, 09:34 PM   #113
quadzero
quadzero's Avatar
Fantastic project, beautiful truck too. I like the cross-over steering and looking forward to seeing that come together. Really appreciate all the work you are putting into this. Where is that neighbour's kid when I have long tedious things to do?
quadzero is offline   Reply With Quote
Old 06-01-2012, 09:35 PM   #114
72chevyk10
I built it
72chevyk10's Avatar
wow!! that bumper is.... beefy!! to say the least haha
and those wheels will look GOOD with that truck
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 06-02-2012, 09:52 AM   #115
modblacksmith
Thank you. Still a ton of work left to do. Haha, he's not around much anymore so I have to do the tedious things again myself.
Old 06-02-2012, 09:58 AM   #116
modblacksmith
Thanks bud. Haha yeah the bumper is a little bit overkill but so is everything else I build. It took me forever to sand and paint them so I hope they look good on the truck or its going to be a lot of time lost.
That roll bar looks grate on your truck, were did you find that, hahaha.
Old 06-02-2012, 11:59 AM   #117
72chevyk10
I built it
72chevyk10's Avatar
hey overkill is under rated haha
well thank you! and thanks again for letting me know about it. cept it made the truck look lower... now i need 4in more lift and 38s
Old 06-04-2012, 11:12 AM   #118
modblacksmith
Yes, now your thinking, everyone needs at least 37's I almost have my headache rack finished up, it weighs three times as much as the bar did. I'll post pics when I get it painted and get the lights installed.
Old 06-04-2012, 04:22 PM   #119
72chevyk10
I built it
72chevyk10's Avatar
how does your rig ride with the 56" springs out back? im thinkin of doin a shackle flip and the 56's some day
Old 06-04-2012, 04:57 PM   #120
modblacksmith
I haven't had much drive time on them yet but so far there grate. There softer than the old springs I had in it before but not so soft that there spongie. I took them out of a 3/4 ton camper special so there is more thinner leafs to them than a regular set of 3/4 ton springs. I'm not done with the swap yet, I want to take out the overloads and add a few more leafs per side. On the other hand I mite be aquiring another truck here in a few weeks so this project could change directions again. I can't get it out of my system I want this truck up in the air.
Old 01-22-2013, 02:34 PM   #121
JDeere550
JDeere550's Avatar
that dodge pitman arm splines match up with the chevy 2wd p/s gear box without modification besides drilling the drag link end? just making sure i get what you're saying before i buy the pitman arm i found on craigslist lol
1970 C/20 4x4, 350, sm465, np205(She tipped over... total rebuild from the frame up!)
ya gotta keep on keepin' on,
Life's a garden, dig it!
JDeere550 is offline   Reply With Quote
Old 01-22-2013, 04:07 PM   #122
modblacksmith
Re: Build of my 72 Custom/20
Yes that's correct, it'll go right on there.
Old 01-22-2013, 04:50 PM   #123
JDeere550
JDeere550's Avatar
Right on dude, that's awesome. thanks for the info! You got any updates for this thing yet or what?
Old 02-09-2013, 12:36 AM   #124
modblacksmith
Your welcome. I haven't been on this site much lately and I didn't renew my subscription due to the lack of impute from people.
As for updates there isn't very many, the truck has been sitting on the side of the house for months.
I've been wheelin and dealin to get parts for my 83 k30 dually. I sold the NV4500 to buy 8 to 10 lug adapters for the dually so i can run 22.5's and the bumper and headache rack are going on the dually. This truck is eventually going to be an advertising tool for my fab bis if it ever gets off the ground. I've been thinking about selling my tons for 2.5 rocks for this truck to give you an idea of were this project is heading. Also I picked up a nasty roller cam and a set of roller rockers for it.
Old 03-18-2013, 01:09 AM   #125
modblacksmith
Re: Build of my 72 Custom/20 on Rocks
Boom! Epic update!
