Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-11-2012, 10:55 AM   #101
bundeber
Re: "TANGERINE" (C20 to K10) (LWB to SWB) (CST/MOD) (5.3)
Man this is crazy! I would have never thought to do this, I would have been stuffing late model goodies under the dash like Drew. I can see how this could be used to make a crew cab truck too. I'd like to see some more close ups on the 8th wonder and how it fits between late model firewall and the upper portion of the old cowl.
bundeber is offline   Reply With Quote
Old 01-12-2012, 02:36 AM   #102
fakerwade
fakerwade's Avatar
Hey bundeber, welcome to all the fun! Here are some pics of the 8th wonder in action. (remember it's still a work in progress)
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 01-12-2012, 02:47 AM   #103
fakerwade
fakerwade's Avatar
While I've been waiting for the patch panels from LMC, I've been busy. I welded in the cab corners, and the drop panel. Still have some finishing work to do.
Wade
Old 01-12-2012, 03:55 AM   #104
hick
Your nuts.
Further more, I am going to use this thread to "build viciously" threw you.
You sir are my hero...
On a side not, why aren't you using the yukon dash?
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims.
hick is offline   Reply With Quote
Old 01-12-2012, 08:32 AM   #105
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the metal replacement Wade. Keep at it.
mcbassin is offline   Reply With Quote
Old 01-12-2012, 12:43 PM   #106
bundeber
Thanks for the picts on the 8th wonder. That's a tricky spot as you need to seal up the cowl and still leave mounting locations for the cowl piece from the "new" body implant. As well as locate the wiper motor in a location that functions. I have an ideal for this.... but it's a bit complex.... I'll try to photoshop it into one of your photos.
OK, with the cab set back in location on the new firewall.... I think I would start by connecting the cowl support on the cab to the firewall permanently. This will preserve the mounting location for the cowl, and top portion of the fender. I would do this with a sheet or metal, set it in behind the lip on the cowl support and contour the bottom edge to match the new firewall. This is the orange piece in the photo. You'll have to build in fresh air ductwork on the passenger side at the same time. Making sure to reinforce the fender mounting locations on each side. This will seal this area from the engine bay so you don't get hot gasses into the cab.
Picture two. What I would do here to clean this up is remove the lightened areas. Leaving the mounting tabs for the cowl piece attached to the cab. THis will clean this area up, and allow much easier access for blending the two trucks together. The section between the two red lines I would bend down as a reinforcement flange much like the rest of that opening.
Old 01-12-2012, 03:05 PM   #107
fakerwade
fakerwade's Avatar
Originally Posted by hick View Post
Your nuts.
,,,,,You sir are funny as he11!! (vicariously)
Listen up, here's the deal, I get my ideas the same way all great inventors and artists do,,,,,,,,,I steal them from someone else!! Over the years I've spent a lot of time going to car shows, talking to builders, even watching Barret Jackson (thanks to DVR I can actually stand it!!). I've seen a Mercedes gullwing that was grafted onto a complete rolling chassis and floor/firewall of a late model Mercedes. There was also a 56 Chev p.u. that was similarly grafted onto a Corvette (if I remember correctly) and I think the "Cheemer" was built the same way.
I'm still getting a lot of inspiration from guy's on this site. If you want more "outside the box" builds check out Mcbassin's or Hart Rod's build threads. Based on your signature you should also check out Dieselwrenchers builds (that guy is fearless!!).
Thanks for the props,,I do appreciate them, as far as the dash goes, I could probably use the yukon dash with some modification (especially around defrost vent area) but it just doesn't match my style.
Wade
Old 01-12-2012, 07:31 PM   #108
fakerwade
fakerwade's Avatar
Hey bundeber, You must be a mind reader!!! It's no fair getting ahead of the build!!
Wade
Old 01-13-2012, 11:06 AM   #109
bundeber
you know what they say... great minds think alike!
Old 01-13-2012, 10:24 PM   #110
fakerwade
fakerwade's Avatar
Update on my "A" pillar patches from LMC,,,,,they didn't show. Big long story ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Nuff said.
P.S. The decision on the raised white letters on my tires (in or out) was sort of made for me,,,I found a different tire/wheel combo that I liked better. The tires don't have raised white letters, so problem solved.
Wade
Old 01-13-2012, 11:54 PM   #111
68 TT
Still plays with trucks
68 TT's Avatar
Sorry you had problems with them. Time to try a new vendor?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-14-2012, 04:05 AM   #112
fakerwade
fakerwade's Avatar
Yep,,,,
Wade
Old 01-14-2012, 10:15 AM   #113
truck farmer
You might try Classic Parts of America out of Kansas City, there pretty reasonable
truck farmer is offline   Reply With Quote
Old 01-15-2012, 01:54 PM   #114
fakerwade
fakerwade's Avatar
Hey truck farmer, I checked them out and bookmarked them, I also liked 68tt,s suggestion (post 80) about truck and car shop. I'll probably try both places in the future. I'm hoping I don't need to buy too much more. I know I still need some lights and lenses,,,, and a new windshield and back window would be nice, and, and, and ,,,,,,,,,
Wade
Old 01-15-2012, 11:52 PM   #115
KRUSTY 51
KRUSTY 51's Avatar
I've had great luck with parts from the truck and car shop, for my truck & my '51 chevy wagon. Any hoo crazy build you've taken on can't wait to see the next installment of progress.
Brian.
'70 GMCHEVY
'51 chevy "tin woodie wagon"
IF YOUR CONFUSED I'LL USE smaller WORDS!
KRUSTY 51 is offline   Reply With Quote
Old 01-16-2012, 12:51 AM   #116
PHAT TONY
PHAT TONY's Avatar
This is AWSOME, sell it to me for .45 on the dollar; when you're further along of course.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 01-16-2012, 05:05 AM   #117
fakerwade
fakerwade's Avatar
Thanks KRUSTY,, good to have you onboard!
Dude that's funny,, it took me a second,,, but I got it!! (stupid economy)
Stick around,,,lots more fun coming soon.
Wade
Old 01-18-2012, 07:25 PM   #118
68 TT
68 TT's Avatar
Enjoying the snow?
I think this is the first time I can remember that Seattle has more snow than we do in total for the season. You guys seem to be getting the brunt of this system.
Old 01-19-2012, 01:57 AM   #119
fakerwade
fakerwade's Avatar
Originally Posted by 68 TT View Post
Enjoying the snow?
Hey 68TT, Yeah we got snow! Only about 8-9 inches, but you drive 10 minutes in any direction and it's a lot thicker, another advantage of being 700 feet above sea level. How much did you get up there?
I finally got my A-pillar patches,,, but now I can't get the cab moved into the shop. Our forklift has smoothie hard rubber tires, it doesn't go anywhere in the snow. We're supposed to get rain tomorrow, hopefully I'll be able to get the cab in Friday night so I can work on it over the weekend.
By the way I finally got a picture of 67c10rustbuket's 1959 Chevrolet Brookwood (it's pretty sweet!!), I hope he doesn't mind me posting it.
Wade
Old 01-19-2012, 03:33 PM   #120
FrankieD
FrankieD's Avatar
quote=fakerwade;5132414]Hey 68TT, Yeah we got snow! Only about 8-9 inches, but you drive 10 minutes in any direction and it's a lot thicker, another advantage of being 700 feet above sea level. How much did you get up there?
[/quote]
You guys got more snow than we have in Northern ILL. and it is really killin my truck budget and the wife isn't liking paying for my truck parts and Plow Insurance.
I like that 59 I never saw one in a 2dr wagon before pretty rare. My parents bought a new 59 wagon when I was a kid, real boats but cool now.
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 01-19-2012, 04:12 PM   #121
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Man that 59 is so awesome, and it looks pretty rust free too boot! I've had problems with LMC before too. Now I get my parts through a local guy and no more issues. I lost it when I saw the LMC catalog in the trash can!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-19-2012, 07:42 PM   #122
68 TT
68 TT's Avatar
We only got about 4" so far but it is still snowing.
Sorry you can't get the truck in the shop. Hope the rain melts off enough the fork lift can get around.
Old 01-19-2012, 11:36 PM   #123
67c10rustbuket
67c10rustbuket's Avatar
I dont mind at all, share all you want, and you can even come down and put a newer chassis under it for me.
They are a little rare, the 59 2 door brookwood production was approx 20,000 about the same as the 59 vette and elcamino while there were hundreds of thousands of each other model sedan in 1959.
The wag would be super rust free if it weren't for someones wife's uncle shooting half the windows out 20-ish years ago so there is some interior floor rust. her grandpa made him (uncle) go to a junkyard and pull windows for all the ones he shot out on the farm and there is quite a few chevy farm trucks that he shot windows out of, but of course there were no 59 wag 2dr windows. the exterior body is rust free except the driver rear lower quarter.
cant wait to see that body permanently attached to the tahoe floor/chassis that thing is wicked cool wade! Is it going to be a stock suspension or are you going to lift it ? I wish we had some snow here so I could have some 4xfun
PS driving a forklift in the snow is fun
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 01-23-2012, 03:33 AM   #124
fakerwade
fakerwade's Avatar
I think I'd be tempted to shoot a wife's uncle, if ya know what I mean??!!! Those rear windows are probably going to be pretty tough to find.
I can't wait to see this come together too!! I worked my butt off this weekend getting it a little closer!
Wade
Old 01-23-2012, 03:47 AM   #125
fakerwade
fakerwade's Avatar
So here is the latest,,,,,I went to install the "A" pillar patches and decided to think it through before I just started chopping and welding (what a concept!). Here's what I came up with,,,,,,,,
I built this gauge so that I could more precisely weld the patch on in the correct location. I felt that the most important thing was to have the fender mounting hole in the correct three dimensional location.
Once I had the gauge in place I finished cutting off the end of the "A" pillar.
Wade
