Old 07-24-2012, 11:20 PM   #101
gettmoneyy7
gettmoneyy7's Avatar
Re: My 82 shortbed
thanks i appreciate it
gettmoneyy7 is offline   Reply With Quote
Old 09-05-2012, 05:26 PM   #102
gettmoneyy7
Re: My 82 shortbed
Picked up the frame, core support, and fender wells from the shop and brought it home after 2 days of it being there. Looked good now it just needed to get primed asap.
Old 09-05-2012, 05:56 PM   #103
gettmoneyy7
Re: My 82 shortbed
Began to prep it to get primed... took the front wheels off and next the rear end and put it on jack stands
Old 09-24-2012, 12:58 AM   #104
gettmoneyy7
Re: My 82 shortbed
As soon as i got the frame in my back yard i stripped it of its wheels and began prep work to prime it along with the motor mounts and crossmember with the help of my uncle and a friend since i didnt know much at this time.. unfortuantly this is outside so had to prime it asap
Old 09-24-2012, 01:45 AM   #105
gettmoneyy7
Re: My 82 shortbed
Next morning i began by stripping the front suspension and experimenting on how i would hang it to spray it... also comparing the old spindles to the drop ones to see the difference.
Old 02-02-2013, 04:03 PM   #106
gettmoneyy7
Re: My 82 shortbed
Began prepping the rear end to get painted, in a effort to avoid chips and what not when i put the flip kit in i went ahead and took the stock suspension apart sanded the flip kit down and installed it then slid it under the frame to make sure everything was correct before i painted.
Old 02-02-2013, 04:23 PM   #107
mud.man.rj
mud.man.rj's Avatar
Re: My 82 shortbed
Very nice work on your truck, sure is coming along nicely. When you get it back together watch where you park, sounds crazy on the streets there for hit and runs. Going to be one very cool truck that you did yourself, congrats.
mud.man.rj is offline   Reply With Quote
Old 02-02-2013, 04:28 PM   #108
gettmoneyy7
Re: My 82 shortbed
now it was time to figure out how we would hang it to paint it and at last we figured it out.. hung it up and began preparing it to get painted, took the rear end pan off and drained the oil along with the rims. painted with canned apoxy appliance paint so in the future it would be easier to touch it up.
Old 02-02-2013, 04:45 PM   #109
gettmoneyy7
Re: My 82 shortbed
started prepping the frame next to get sprayed by removing the old powersteering pump and front suspension and priming those areas after checking that they were clean.
Old 02-02-2013, 04:52 PM   #110
gettmoneyy7
Re: My 82 shortbed
After removing the power steering pump we realized we had a minor stress crack so grinded the area down and drilled a tiny whole at each end of the crack to prevent it from going further. grinded a little line down the crack and proceeded to weld it up..
Old 02-02-2013, 05:01 PM   #111
gettmoneyy7
Re: My 82 shortbed
Thank you. and yes i will defently have to be careful were i park after all this work i would really hate for someone to hit it or even cratch it.. its came a long way
Old 02-03-2013, 08:15 PM   #112
Hankster
Hankster's Avatar
Re: My 82 shortbed
Amazing work. You are doing to yours what I dream about doing to my 86! Can't wait to see if finished
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 02-03-2013, 09:45 PM   #113
moregrip
moregrip's Avatar
Re: My 82 shortbed
Looks great! What primer did you use?
moregrip is offline   Reply With Quote
Old 02-04-2013, 11:48 AM   #114
gettmoneyy7
Re: My 82 shortbed
Thanks and I used self etching primer due To the fact that it was sandblasted down to bear medal and self etching bonds with the metal rather than just creating a layer over it .
Old 02-04-2013, 01:39 PM   #115
Sin7
Sin7's Avatar
Re: My 82 shortbed
great work man
Sin7 = Luis
1959 Apache
Sin7 is offline   Reply With Quote
Old 02-05-2013, 03:02 AM   #116
gettmoneyy7
Re: My 82 shortbed
Thank you .. Trying to get more pics posted just getting them in order.
Posted via Mobile Device.
Old 02-05-2013, 10:21 PM   #117
jughead12
Re: My 82 shortbed
nice!!
jughead12 is offline   Reply With Quote
Old 02-07-2013, 02:39 AM   #118
gettmoneyy7
Re: My 82 shortbed
As for the frame horns they were off a inch of two for the core support due to a possible hit from the passenger side sometime in its life. So we had to improvise. started by hooking up the comealong and cranked it a couple times and the driverside frame horn came right over were it needed to be. as for the other side had to put a 4x4 from the wall to about a foot behind of the motor mount and one on the inside of the passenger horn and give the 4x4 a couple wacks with a sledge and then beat the buckles out on both side of the top of the horns. All metaled the dings we made and primed it.
Old 02-07-2013, 02:51 AM   #119
gettmoneyy7
Re: My 82 shortbed
what it looked like after.
Old 02-07-2013, 11:44 AM   #120
gettmoneyy7
Re: My 82 shortbed
Removed the yoke and replaced the seal and painted the yoke
Old 02-07-2013, 03:25 PM   #121
gettmoneyy7
Re: My 82 shortbed
Rear end pan came in the mail so put it on and slid it under the frame to see what it looked like.
Old 02-08-2013, 01:33 AM   #122
gettmoneyy7
Re: My 82 shortbed
After studing some pics of the 4 1/2 to 6 in drop which I already have I desided I dont think it's low enough for me .. I took out the helper spring to but I want no wheel gap, if I would have known the make 3 inch drop springs I would have got those instead of my 2 inch ones .. I'm thinking about cutting a inch off what's your guys opinions on that? And were do I cut????????? I wish I could bag but at the moment I don't think my bugget will allow I'm 19 and all is getting paid for by me.. Also what would it run to just bag the front? An estimate if anyone knows cuz then ill bag the front and slamm the hell out of the rear with 2 inch drop shackles on top of the flip kit ? If Anyone has advice please
Old 02-08-2013, 10:37 AM   #123
91V3500
Re: My 82 shortbed
I had a 82 shortbed years ago that I started off with a 5" front and 8" rear static drop. It had 15" wheels with 50 series tires, and that was as low as I could go because the a-arms were right on the ground (2"). I had 3" drop spindles, 2" coil springs, 6" flip kit, and a 2" rear block. I ran it like that for years with no issues. You could run your 2" spindles and cut 3" worth of coils off your springs, just try to cut so that the spring ends in the same location so they seat in the spring buckets but it's not that critical. And just because you cut 3" off does not mean it will drop it 3" because the spring will be compressed when you put it back in the truck. So you ususlly have to cut more than 3" off to get a 3" drop.
As for the bags you can go just as cheap or expensive as you want, depending on the valves and compressor setup. The cheapest way is with manual brass valves and you can upgrade to electronic valves later. To do the front that way would cost about $500-600 for materials. I like to use 2500# bags instead of 2600 because it takes less air to fill them, after all you're not trying to lift a big block or anything
91V3500 is offline   Reply With Quote
Old 02-08-2013, 10:39 AM   #124
moregrip
moregrip's Avatar
Re: My 82 shortbed
fantastic! what brand if I may ask? easy to apply?
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
Old 02-08-2013, 01:55 PM   #125
gettmoneyy7
Re: My 82 shortbed
We'll as of now I have mcgraugys 2 1/2 drop spindles and belltech 2 inch drop springs and I sall that same set up on a truck in person with 20"s and it still had a little wheel gap .. I hate that if I would have known they had 3 inch drop spindles and 3"drop springs I would have got either, guess i should have done more research, ii got thesee back when i hardly knew anything but now I'm thinking of cutting the 2" Drop springs to make them 3 but I have no idea how you measure that on them .. And thank you I appreciate the help I'm considering my opinions
c10, frame off build
