Old 09-29-2012, 07:45 PM   #101
no2tracks
Re: What did you do yo your truck today??
Changed fuel filter, removed bedliner and 5th wheel hitch.
'94 K2500 Silverado 7.4 auto 4x4
no2tracks is offline   Reply With Quote
Old 10-04-2012, 07:29 PM   #102
MaritimeDragRacing
MaritimeDragRacing's Avatar
Doing what a GM truck is meant to do - Hooked to a race car trailer and heading for the drag strip in the morning.
http://www.maritimedragracing.com
Atlantic Canada’s #1 source for Drag Racing News, Race Results, Schedules and Track Information.
MaritimeDragRacing is offline   Reply With Quote
Old 10-04-2012, 09:06 PM   #103
no2tracks
New rear brakes, axle seals, and transmission fluid and filter change.
Old 10-09-2012, 08:28 PM   #104
jb1016
"Oh well, it's a driver."
jb1016's Avatar
New starter. Previous one only lasted about three and a half years.
Old 10-09-2012, 11:57 PM   #105
red94chev
red94chev's Avatar
Over the last few weeks: fuel pump, dist cap, rotor button, ICM, pickup assembly, coil, and battery. She'll hit 190K miles tomorrow.
red94chev is offline   Reply With Quote
Old 10-11-2012, 03:01 PM   #106
stocker96
stocker96's Avatar
Over the last week.....
New trans- monster 4L60 bulletproof kit, corvette servo, proshift class 3 shift kit.
new valve train
new pistons and rings
new intake
new crank
tinted the windows 5% all around
got the sub box built
ordered my HID relay with a "hi 4" harness
got my rear bumper back on
washed and waxed
replaced 4X4 actuator (4X4 works now)
grand total $9,546 and change. I'm now married to my truck....
stocker96 is offline   Reply With Quote
Old 10-11-2012, 10:07 PM   #107
Vega_67C10
Vega_67C10's Avatar
Cleaned the glass. Clean glass is king man!
I Saw Elvis at 1000 Feet - John Force
Vega_67C10 is offline   Reply With Quote
Old 10-12-2012, 01:54 AM   #108
stocker96
stocker96's Avatar
Tonight, got the sound system in. Installed a manual remote wire switch in the dash for the amp.
Old 10-12-2012, 10:55 AM   #109
3strats
New tires, bullet center caps from Summit and lug nuts on outlaw II's
3strats is offline   Reply With Quote
Old 10-12-2012, 03:31 PM   #110
dragginmetal
here, just not logged in
dragginmetal's Avatar
Sounds cool. Got any pics?
dragginmetal is offline   Reply With Quote
Old 10-12-2012, 10:10 PM   #111
3strats
Not yet. Doing a-arm bushings on monday. Was gonna do some before/after pics on the rims. They do look pretty good now. I know the suspense is killing you'
Old 10-13-2012, 12:45 AM   #112
dragginmetal
Lol. I dont mind waiting for some before and after pics, but the suspense is killing me.
Old 10-13-2012, 06:25 PM   #113
Red88
Red88's Avatar
Removed the smog pump and associated plumbing from my no-longer-needs-to-pass-smog-test 88 today. While I was at it replaced the broken ground from firewall to back of passenger side head. Quieter engine and much better idle!
'88 K1500 Scottsdale
5.7 TBI, 5spd MG5
Red88 is offline   Reply With Quote
Old 10-13-2012, 06:34 PM   #114
oneoff
oneoff's Avatar
I reconditioned two of the four bumper brackets to get them ready when we get to this part of the build.
Name:  bumper brackets.jpg
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=541803
Dennis H
1969 Chevy C10, SWB, LS3,6.2L engine
1969 Chevy Chevelle SS,BBC, Convertible
oneoff is offline   Reply With Quote
Old 10-13-2012, 08:25 PM   #115
TheDirt520
Cut off all the rivets holding the frame rails together so I can clean-box-paint the frame then use bolts when putting it back together,,, I have a second frame which I'm trimming down to use as plates to box the frame, damn thing has over a foot of flex stock, no good!
TheDirt520 is offline   Reply With Quote
Old 10-13-2012, 08:28 PM   #116
TheDirt520
��That's a 89 suburban frame I'm going to use under my 99 burban body
Old 10-14-2012, 08:36 PM   #117
eldogg
eldogg's Avatar
I did new Raybestos unit bearings, rotors, pads, brake hoses, and an idler arm on my K2500 today. O yeah and a brake flush. Well still doing it. I'm waiting on my wife to bring pizza and to help bleed the brakes.
eldogg is offline   Reply With Quote
Old 10-15-2012, 05:14 PM   #118
3strats
Well...
My a-arm bushing came to a screeching halt. Came apart good. Pulled old bushings, upper and lower no prob. Went together better than I thought. I even got saucy and cut half a coil... ooOOOooh!
Got interesting when I was going back together with everything.
For one thing, the old rubber bushings must have been well-worn. Arms with new bushings are a tight fit. Thats a good thing I suppose.
Then I tried putting the coil in. Ha! Whats the old G.I. Joe saying, "Knowing is half the battle!"
Should have picked up a coil spring compressor because i've pulled out about all of the remaining hair I had left.
Well of to the parts house soon as the wife gets home. Might pull an all nighter.
Old 10-16-2012, 07:06 AM   #119
TheDirt520
Looked at it! Had a lazy day slept till 6pm
Old 10-17-2012, 05:21 PM   #120
3strats
Ahhhh.... finally finished up with my 3 day extravaganza of replacing a-arm bushings.
Note: When your lower ball joint just won't come loose by popping side of spindle, DO NOT TRY AND GIVE JUST A "LOVE TAP" ON THE BALL JOINT SHAFT TO SEE IF IT WILL WORK!!!!!! You'll end up looking for a thread chaser.
Yes I just admitted to doing stupid things. I Am Man.
Old 10-17-2012, 06:41 PM   #121
TheDirt520
I found that out once 3strats that's why if I ever have to do bushing I do the ball joints as well
I am man all I do is stupid things
Old 10-17-2012, 06:56 PM   #122
TheDirt520
The worst one is when someone tells you too screw the nut on so it's flush with the top of the joint shaft to give you a nice area to hit, sure it knocked the ball joint loose but spent a few hours cutting that damn nut and shaft off so I could start workin, morons-
Would they be the morons for giving stupid advice or am I for doing it?
Exp- my 96 3/4ton sub broke a half shaft, being my first crappy ass IFS truck I didn't know what to do so I go to autozone, I couldn't afford the shaft at the time so the manager tells me just pull it out and u can drive your truck, jackass didn't mention that it holds the brakes to the spindle ! So wheel breaks off while driving had to replace , lower arm, spindle, rotor, caliper, hose, fender, wheelwell, and my rim, dumbass cost me $800 two weeks and cost me a trip I had planned
Old 10-17-2012, 10:13 PM   #123
Chevrolet4x4s
Chevrolet4x4s's Avatar
Picked up a transfer case skid plate, a larger front skid plate from a later model Tahoe, some misc little parts from the junk yard.
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 10-18-2012, 08:51 PM   #124
TheDirt520
Cut my spare frame apart so I can cut the top and bottom of the c channel off so I can use the rest to box my frame, I hate stupid rivetsName:  image.jpg
Old 10-23-2012, 09:19 PM   #125
3strats
Flat blacked my bowtie (got bored). Actually came out good. Thinking about doing the same to the faded/chipped chrome strip on the side molding.
