Old 04-27-2014, 02:04 AM   #101
Layedoutsonoma91
Layedoutsonoma91's Avatar
Re: You guessed it, 1950 s10 swap.
Yea, it seems like everything is coming together slowly, and more nickle and dimes than I got to give. Im just waiting for the day I can sit in the driver seat and let it all pay off. Maybe in the next few weeks. Wish me luck!
1954 Chevy 3100 5 window, bagged on s10 frame,
6.0 ls swap/4l80e
Past build thread
http://67-72chevytrucks.com/vboard/s...=531261&page=3
1949 3100 s10 swap 5.3.
Instagram -@thejcates
Layedoutsonoma91 is offline   Reply With Quote
Old 04-27-2014, 11:06 AM   #102
99 to Life
99 to Life's Avatar
hey that day will come man, it will seem as it will never come sometimes, but it will. Then if you are even more lucky, you won't be ironing out a bunch of stuff on the shakedown. I hate the nickel and dime stuff, it gets overwhelming. Even if you make a checklist I don't like to look at them, when you look back you'll be like wow that was alot of work, lotta little things. But you'll have something to show for it, something fun to drive and something that will make alot of people want one. I wish us all good luck and weather. We are fortunate to have what we do have, even if its a crappy tool or a leaky garage (or a garage at all) or even a project to work on.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-27-2014, 11:49 AM   #103
Layedoutsonoma91
Well said ^ . Hopefully my updates will come a lot faster these next couple days.
6.0 ls swap/4l80e
Past build thread
Old 04-27-2014, 11:29 PM   #104
higgiec10
higgiec10's Avatar
Nice build hope to see more updates.
higgiec10 is offline   Reply With Quote
Old 04-28-2014, 12:20 AM   #105
Layedoutsonoma91
Got my old tag restored and registered, even got insurance.
Makes it seem even closer.
6.0 ls swap/4l80e
Past build thread
Old 05-02-2014, 12:06 AM   #106
Layedoutsonoma91
Video of the truck running a lot better.
http://youtu.be/z9wXim0-WFI
once I get the exhaust on it should run a lot smoother, no back fires.
Then got the radiator support made and mocked everything up.
lower radiator hose is only like 4 inches long
6.0 ls swap/4l80e
Past build thread
Old 05-02-2014, 12:12 PM   #107
99 to Life
99 to Life's Avatar
nice progress man, engine start ups are fun. getting closer thats for sure.
Old 05-02-2014, 01:45 PM   #108
FarmerSid
FarmerSid's Avatar
Right on! Looks good. Like the chrome MC and booster. What are the specs on it and how did you determine what one to pick?
Cheers!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 05-02-2014, 05:06 PM   #109
Layedoutsonoma91
Its just an ebay one. Just got one that bolts to an s10 since i was using an s10 interior brake pedal.
6.0 ls swap/4l80e
Past build thread
Old 05-02-2014, 07:16 PM   #110
FarmerSid
FarmerSid's Avatar
Thanks! I thought there would be a bit more involved in picking one.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-04-2014, 12:49 AM   #111
Layedoutsonoma91
Most brake systems are the same as far as boosters and master cylinder. I had to make the plunger that goes from the pedal to the booster tho.
6.0 ls swap/4l80e
Past build thread
Old 05-25-2014, 11:51 AM   #112
Layedoutsonoma91
Had a couple seat backs.... Took the truck on its maiden voyage and it started blowing oil out the exhaust. I think its just the valve seals, but haven't gotten to swap them all out yet. It only does it when you first start it, a little smoke, then once you would think a good bit of oil has gotten to the valves. i think my motor may be a little more than 3 degrees tilt which makes the oil gather around the cyl. that is dumping oil. I did a compression test and its not the rings. Taillights wont work either, I think the ones I bought are defective. Hope to have it rolling soon enough tho. Been a real bummerhere that past few weeks.... Keep on keepin on
6.0 ls swap/4l80e
Past build thread
Old 05-26-2014, 12:25 AM   #113
99 to Life
99 to Life's Avatar
You'll get there man, keep at it.
Old 06-08-2014, 08:12 PM   #114
altereddezignz
Where did you get the neck adaptor for the water pump for the lower radiator hose.
altereddezignz is offline   Reply With Quote
Old 06-08-2014, 10:41 PM   #115
Root2812
Root2812's Avatar
Did you paint your intake? I have a spare LS6 intake that I am going to paint to see if I like it. What did you use? Also what did you use for the injectors? I know the truck used different connectors than the car injectors. If you have a link to what you used that would help me out a lot. I'm also curious about your radiator. What brand is it? I like that your fills from the passenger side. All the Champion radiators I see for my 1950 all fill in the top middle like stock. Did you have space for a fan or did you have to go with a pusher?
You build is looking good.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 06-19-2014, 09:02 PM   #116
Layedoutsonoma91
The water neck is off ebay. Just searched straight ls1 water neck. Intake is painted with engone paint. I think any paint will work. I bought it already painted. I sent my harness to lsx-harness.com. i sent them the right connectors too but i think they will supply them. Radiator i got from speedwaymotors.com. it was on sale in the yardsale. I had to put my fan on the front to push. Not sure its gonna be enough airflow tho. Motor seemed to still get too hot. Well see once i drive it
6.0 ls swap/4l80e
Past build thread
Old 06-19-2014, 10:24 PM   #117
Purcell69
One word...Wow!
-Joe
Purcell69 is offline   Reply With Quote
Old 06-26-2014, 05:41 PM   #118
made2drag
made2drag's Avatar
COOL build! Love it!
made2drag is offline   Reply With Quote
Old 06-26-2014, 05:58 PM   #119
made2drag
made2drag's Avatar
are you gonna show it at the Sparks of Insanity show at the Birmingham Race Course Oct. 4th?
Old 07-09-2014, 12:32 AM   #120
Layedoutsonoma91
there is a show at the same place August the 10th ill be at, i wont be at sparks until sunday the 5th. My clubs show in Moody AL is the same day, that sat.
6.0 ls swap/4l80e
Past build thread
Old 07-09-2014, 12:40 AM   #121
Layedoutsonoma91
Been making alot of progress lately, Finally been driving it around!
6.0 ls swap/4l80e
Past build thread
Old 07-09-2014, 01:11 AM   #122
whitels1
whitels1's Avatar
Bad ass man, you can't go wrong with an LS swap, it's amazing how much it transforms the truck!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 07-09-2014, 09:38 AM   #123
Layedoutsonoma91
Oh yea. Im definantly stoked with it so far. Just need to keep the kinks ironed out and then it will be golden. Everyday it seems i get one more small issue fixed but find 5 more haha. Only takes time. Thanks for all the support so far guys!
6.0 ls swap/4l80e
Past build thread
Old 07-09-2014, 10:38 AM   #124
99 to Life
99 to Life's Avatar
hell yeah you been on it. interior is looking good as is the whole truck. So what you figure out with oil blowing out the exhaust? Engine running good?
congrats
Old 07-09-2014, 11:19 AM   #125
Layedoutsonoma91
I had the pcv system all screwed up. I was putting way too much vaccum on the heads and i guess it was forcing oil into the cylinders. I changed the valve stem seals and it got a lot better. Only did it under high rpm after that. I took vaccum completely off the heads all together and vented both sides and it started running great with no smoke. Put the exhaust on and it stopped running rich. Finally got all the air out of the power steering system. Had a scare last night tho. I pulled my radiator cap and there was black sludge at the top. I immediately thought head gasket was screwed. Isnt running hot tho. I let it settle and went back out there it was just on the top. Im just guessing it was leftover dexcool that was in the block that i didnt get all the way out. It does that when it mixes with green coolant. Getting an alignment today hopefully and ill be good!
6.0 ls swap/4l80e
Past build thread
