Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 03-10-2013, 10:55 PM   #101
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: 1940 "project moonshine"
few updates.lots has been going on but nothing that looks cool in pics.truck is mostly wired.motor is all closed up now.air system is working.lots of small stuff.got the rest of the sheetmetal on.we will be louvering the hood so that will go on last.last major hurdle will be changing the gears from 2.73 open carrier to 3.73 posi.thanks chizzler.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 03-10-2013, 11:11 PM   #102
youngrodder
youngrodder's Avatar
Lookin good Chizzler..
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 03-11-2013, 10:37 AM   #103
Luther Grimace
Luther Grimace's Avatar
How did you mount your wood bed floor? Specifically with those strips and where did you get them from?
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 03-11-2013, 05:14 PM   #104
CHIZZLER
CHIZZLER's Avatar
if you look back on my build you will see we made a raised bed floor frame using 1x1 steel.i then got the bed strips from mar-k and had them not drill the holes so i could drill through the bed strip and the frame below.the bed strips come with or without holes at any length you want.
61-crew cab D-max
Old 03-16-2013, 06:59 PM   #105
82swb
82swb's Avatar
I love everything about this truck. A 37-40 Chevy pick up may be in my future after see what you have done with this one.
82swb is offline   Reply With Quote
Old 03-16-2013, 09:01 PM   #106
CHIZZLER
CHIZZLER's Avatar
today we got a little more done.we punched 112 louvers in the hood.we also had to massage the front sheet metal around to align with the hood.all electrical is done but we have to mess with the yankee 960 turn signal switch a little.chizzler
61-crew cab D-max
Old 03-17-2013, 08:44 PM   #107
Luther Grimace
Great work. How long does it take to make all those louvers?
Old 03-17-2013, 11:08 PM   #108
CHIZZLER
CHIZZLER's Avatar
thanks.louvers took about 3 hours to lay out and punch.you have to grid the backside so you have something to follow once you start going.it helps keep everything in line.
61-crew cab D-max
Old 03-18-2013, 03:09 PM   #109
focusedontheprize
focusedontheprize's Avatar
Nice ride, what is the wheel and tire setup?
focusedontheprize is offline   Reply With Quote
Old 03-18-2013, 07:55 PM   #110
CHIZZLER
CHIZZLER's Avatar
15x5 w 620-15 tire on front,15x7 w 820-15 tire on rear.wheel vintiques.soon to be hurst super cushions in front and 710-15 firestone vintage in rear.
61-crew cab D-max
Old 03-19-2013, 01:26 AM   #111
YBNORML
YBNORML's Avatar
I love this truck. Just wicked!!!
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-23-2013, 11:54 PM   #112
CHIZZLER
CHIZZLER's Avatar
well today was the day.fired the motor and everything went well.no major problems or leaks.noted a little clicking coming from the valve covers.not sure if the roller rockers are hitting the inside of the valve covers.all n all motor sounds great temp and oil were perfect.electric fan came on.
61-crew cab D-max
Old 03-24-2013, 12:41 AM   #113
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Beautiful!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-24-2013, 09:32 AM   #114
duallyjams
duallyjams's Avatar
Time to see some action !
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-24-2013, 11:45 AM   #115
68GMCburban
68GMCburban's Avatar
You've got an awesome truck, man.
-Holden
1983 & 1972 Chevy Longbeds
(16) 67-72s (Rollback, 402's, Sierra Grande, Shortbeds, Shortsteps, Longhorn, etc)
1968 GMC Suburban- (Current project) Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=569806
(6) 60-66s (shortstep, rollback, two-ton, longbeds)
(3) 47-59s half tons
+ MANY more and always looking for more
68GMCburban is offline   Reply With Quote
Old 03-28-2013, 10:57 PM   #116
SCHRUMGMC
SCHRUMGMC's Avatar
Holy cow man thats a beauty
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-04-2013, 09:20 PM   #117
CHIZZLER
CHIZZLER's Avatar
got the seat back today.we had to make a new plywood base because it was rotted out.probably was a good thing.now has a nice new foam bottom.big swap meet this weekend.
61-crew cab D-max
Old 04-04-2013, 10:50 PM   #118
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lookin good!
-Nate
Old 04-13-2013, 08:18 PM   #119
CHIZZLER
CHIZZLER's Avatar
few update pics.today we took the red door and sanded it and blended in some other colors to try and match the rest of the body.it is not a great match for now but a little closer.we also put the seat in and made some kick panels from a sheet of black abs.thanks.
61-crew cab D-max
Old 04-13-2013, 08:22 PM   #120
Chris.
Looking great
Chris. is offline   Reply With Quote
Old 04-13-2013, 08:24 PM   #121
SCHRUMGMC
SCHRUMGMC's Avatar
Love the Bench Seat man, really nice
1971 GMC Sierra
1959 GMC 100
Old 04-13-2013, 08:26 PM   #122
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Cool build! Sweet truck, love the triple deuce, I'll stay tuned
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 04-13-2013, 11:16 PM   #123
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice work.
-Nate
Old 04-14-2013, 09:53 AM   #124
duallyjams
duallyjams's Avatar
The door looks a 100 % better, just don't touch the out side of the truck then put your hand on the seat.
James
IG duallyjams
Old 04-14-2013, 09:55 AM   #125
SCHRUMGMC
SCHRUMGMC's Avatar
Will you show the Original Owner ?
1971 GMC Sierra
1959 GMC 100
