Old 12-28-2012, 07:22 PM   #101
Coach529
Coach529's Avatar
Re: 1949 Chevy 3600 into a daily driver
Milestone night tonight. I bent some tubing and now Henry is running on his own fuel tank for the first time of this whole project.
Sorry....no pictures!!
Time for a drink!!! Whoohoo!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 12-28-2012, 09:10 PM   #102
NEWFISHER
NEWFISHER's Avatar
AWSOME! is Henry assembled enough to drive awaiting the axle? Cookies in the snow?
Feels good to have a running truck, mines been awol at the glass shop re-fixing some leaks grrrrrrr...picking it up at 8 and swapping the 700r4 in this weekend.
NEWFISHER is offline   Reply With Quote
Old 12-28-2012, 11:18 PM   #103
Coach529
Coach529's Avatar
It has actually been somewhat driveable the whole time. I had a temp fuel tank below the hood to run off of.
1949 Chevy 3600
Old 01-03-2013, 12:33 PM   #104
Coach529
Coach529's Avatar
Just got confirmation from Sid my axle is complete, assembled and shipping asap.
1949 Chevy 3600
Old 01-03-2013, 01:08 PM   #105
NEWFISHER
NEWFISHER's Avatar
WoooHooo,,,,you're gonna love it
Old 01-03-2013, 01:24 PM   #106
Coach529
Coach529's Avatar
Still have alot of loose ends to tie up before it is a driver.
Front shocks (need to fab upper mounts)
Needs rims and tires (all 4)
new rear end and drive shaft
Rear shocks (fab inboard mounting)
Rear notch, frame boxing, axle flip, etc
Fun, fun, fun!!
1949 Chevy 3600
Old 01-03-2013, 02:03 PM   #107
Dan in Pasadena
Dan in Pasadena's Avatar
Make sure you take good photos of all this Coach!
We need the inspiration....plus we need entertainment while sitting on our fat butts on our sofas! lol
Dan in Pasadena is offline   Reply With Quote
Old 01-03-2013, 02:09 PM   #108
Coach529
Coach529's Avatar
Photo's are a guarantee......
1949 Chevy 3600
Old 01-03-2013, 09:53 PM   #109
nebdrummer
nebdrummer's Avatar
Nice! Is this thing going to be slammed? I have a longbox as well and I flipped my rear spring shackle and that alone dropped 4". Then I had it down to 3 leaves a side, (still with the axle under springs) and it sat really pretty good, but the bigger bumps hit the bump stops. It did make for an awesomely smooth ride though.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 01-03-2013, 10:58 PM   #110
Coach529
Coach529's Avatar
I have a 4" drop axle coming from Sid and will probably remove a couple leaves to take it down another 1" to 1-1/2". The doing an axle flip on the back and remove leaves until the running boards sit level to the ground at ride height.
I will be doing a 2" to 3" c notch to give myself more travel.
Your truck is awesome BTW.
1949 Chevy 3600
Old 01-03-2013, 11:44 PM   #111
nebdrummer
nebdrummer's Avatar
Heres the lowest I could get it without cutting the rear of the frame.
Old 01-03-2013, 11:59 PM   #112
Coach529
Coach529's Avatar
That is pretty low. How much rear travel did ya have?
1949 Chevy 3600
Old 01-04-2013, 09:18 AM   #113
focusedontheprize
focusedontheprize's Avatar
Good plan. I did the same setup in the front - 4" drop axle with 2 springs removed. It sits low, lower than I was suspecting after putting the motor and transmission back in, but I love it. The old man calls it "the squirrel scraper".
As for the rear, I have been playing around with some ideas. I picked up Sid's 3" lowering blocks, but it isn't low enough for me (even when I removed some of the springs). I was debating on sending the leafs out to have them de-arched, but I don't want to notch the frame at this point right now. KustomBrad ran TCI's lowering leaf springs (not too sure if he notched the frame), but I like his stance.
http://67-72chevytrucks.com/vboard/s...4&postcount=11
focusedontheprize is offline   Reply With Quote
Old 01-04-2013, 12:03 PM   #114
Coach529
Coach529's Avatar
My springs have been in the de-arching process for the last 60 years. :-)
Do you have pictures of your current stance??
I found this truck on the net and remember that is was not notched, but he commented that there was very little travel.
up front: 4" drop axle from sid, and I removed 3 leaves
out back: 6" drop mono-leaf from classic performance plus 3" lowering blocks.
That is pretty much the stance I am looking for!!
1949 Chevy 3600
Old 01-04-2013, 06:29 PM   #115
nebdrummer
nebdrummer's Avatar
Remember guys, the 3/4 ton frame doesn't have near the factory frame arch as the 1/2 tons do. That's why it's easier for the short bed guys to lay running boards without cutting the frame.
Coach, the rear had about 3 inches till the bump stop, and 4 to the frame. It did settle a little and I started hitting bumpstop with only 3 leafs in the rear. So removing the stops and a pipe cutout for the axle to travel to in a bump would work wonders. The end of the first page on my build thread shows how I did mine.
Old 01-06-2013, 07:27 PM   #116
focusedontheprize
The truck you posted Coach is from Sid's gallery (http://www.droppedaxles.com/PHOTO_ALBUM.html)
Would you run mono-leafs out back? I just don't know about them - they just seem "too light" for me especially if I plan on doing some hauling.
Old 01-06-2013, 07:40 PM   #117
Coach529
Coach529's Avatar
I have never done any research on the mono leafs, so I cannot comment. I plan on doing the axle flip and then remove 2-3 leaves.
That should be low enough....but if it is not I plan on making a lowering block to place between the springs and axle.
1949 Chevy 3600
Old 01-10-2013, 01:25 PM   #118
Coach529
Coach529's Avatar
Not much new on the project. Just stacking up parts for when I have some time to get some stuff done.
My radiator from Gulfstream87 over at HAMB showed up this week.
I also received my dropped axle from Sid. Everything looks great. I got the whole meal deal from Sid. All new modern tie rods ends, drag link. New installed King Pins. Should be better than new.
I ordered my new U-Bolts online last night. Need to order some caster shims and I should be almost ready to go.
I need to go to the local junkyard and find some Chevy 5 bolt steel wheels with some rubber on them for rollers for now until I decided on what I am going to run.
Also need to find a rear end and figure out what I am going to do about a driveshaft. Probably end up with a 4 x 4 S-10 rear end.
1949 Chevy 3600
Old 01-10-2013, 02:56 PM   #119
NEWFISHER
NEWFISHER's Avatar
Remember to install the Zerk fittings at the backside of the spindles before you install the axle ( ask me how I know) 1/4" straight ones at the uppers and 45 degree ones below if I remember right so you can access the fitting. When the backing plates and the steer arms are installed, you can get to the lowers.
Old 01-10-2013, 03:00 PM   #120
Coach529
Coach529's Avatar
Thanks for the heads up....
1949 Chevy 3600
Old 01-10-2013, 03:26 PM   #121
focusedontheprize
Sid was a great guy to work with. He was incredibly helpful with everything when I did mine (as I have heard from many people). I saw your post asking about the stance, I will wait till get the front clip back on to take a side shot - the rear needs to go lower.....
Are you grabbing a few leafs out of the front spring packs?
Old 01-10-2013, 04:45 PM   #122
Coach529
Coach529's Avatar
Yea I am planning on two for now. My stock springs are pretty sacked out so I am afraid to grab more than that.
1949 Chevy 3600
Old 01-10-2013, 06:02 PM   #123
NEWFISHER
NEWFISHER's Avatar
It's gonna be loooooow Start soaking the leaf pack pins with ATF and Kerosine mix and you might want to pick up some new ones. I grabbed mine for less than $5 at the local Napa.
Old 01-10-2013, 07:18 PM   #124
Coach529
Coach529's Avatar
I have the pins already.......figured they would not come apart without a fight!!
Shooting for that 5" to 5-1/2" drop on the front. Will look sick!!
1949 Chevy 3600
Old 01-17-2013, 02:51 PM   #125
NEWFISHER
NEWFISHER's Avatar
How's the drop comming?
