Old 11-01-2013, 01:00 AM   #101
C20scott
Re: Backyard Cummins
Forgot to add a though.
SANDING SUCKS!! Especially all of the radiuses on the inside of the cab. If you enjoy sanding/body work, i envy you, and i will pay you to sand next time. Otherwise, I will be making a trip to the blasting shop and start painting from scratch.
Next step on the inside is a combination of carpet>seats>wiring. From there I need a driveshaft so i can get closer to test driving. And hopefully some black smokey burnouts...
1969 K20, Cummins 12v conversion in progress...
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=574152
C20scott is offline   Reply With Quote
Old 11-01-2013, 07:22 PM   #102
y5mgisi
Second Chance Program
y5mgisi's Avatar
Thanks for the info!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 01-22-2014, 09:34 PM   #103
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice project and great work on it! Have you made anymore progress on your build?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-23-2014, 09:27 AM   #104
Zane M
Great work so far!
Zane M is offline   Reply With Quote
Old 01-24-2014, 10:19 PM   #105
superduty_59
Awesome build. Diesel is the only way to go if you want power, fuel mileage and the best sound you can hear. 12v p-pumped would also be the engine of my choice. Any new progress?
superduty_59 is offline   Reply With Quote
Old 01-26-2014, 11:10 PM   #106
C20scott
Visible progress has been slow lately. Wiring has taken up most of my time.
I was able to participate in the application of Herculiner on a friends truck. This is what i plan to do once i move on to exterior paint. It looks awesome, easy application, and is really tough.
Old 01-26-2014, 11:15 PM   #107
C20scott
I FINALLY got my ride height figured out. Previously i had about 2" of sag in the rear. My solution was to buy shackle flip brackets from Off Road Development. They give a 4" lift without the need for lift blocks or aftermarket springs, and they better my pinion angle. They took awhile to install, as you need to remove the rivets on your stock hangers.
Old 01-26-2014, 11:29 PM   #108
C20scott
90% complete with wiring. the holdup is with all my non-stock accessories.
Push button start, grid heater, and new keyed ignition shown below.
Old 01-26-2014, 11:36 PM   #109
C20scott
Instrument cluster is one of my last difficult wiring tasks.
**Note the inset .357mag shells that with green LED's in them. They will blink with left or right turn signal!
Old 01-26-2014, 11:39 PM   #110
C20scott
Custom driveshaft now that my ride height is set. 3.5" Diameter, courtesy of SB Driveline.
CV up front, with 1410 flange in rear.
Old 01-26-2014, 11:43 PM   #111
C20scott
Added a few more legs to my exhaust. I decided that there wasnt enough room to bother routing between the framerails. So i routed it under the heater core to the outer passenger side. I will end up needing to cut my wells to accommodate.
I will eventually have a turndown right after the passengers door. Im not a "Stack" kindof guy...
Old 01-26-2014, 11:50 PM   #112
C20scott
Of course there is no standard 4x4 linkage for the nv4500/np205 combo that i had. I ended up chopping up one that i had laying around, and making my own.
Its basically an angle iron mounted to the top of the tranny, with a pivot point welded on from another linkage. Works perfect!
Old 01-26-2014, 11:59 PM   #113
C20scott
I procured a set of seats out of an 03 silverado. I really like the comfort of these, and that the seatbelts are integrated into the seat. So i dont have to mount my own.
These seats are much larger than i had initially thought, truck cabs nowadays are much larger than older..
In order to make them sit low enough i had to recess the floor. I cut out the raised conflicting locations of the stock floor, and boxed them out with flat sheet metal. This is required at 3 locations for both the passenger and driver's side.
The seats sit alot better now, still big, but better. I cleaned up the welds and drilled the necessary holes. I will still need to reinforce the mount locations below the cab, as the seats are responsible for stopping me in a crash...
Old 01-27-2014, 12:04 AM   #114
C20scott
2 things on my to-do list before i install carpet.
- connect reverse light switch(pigtail is in the mail)
- buy new high hump(the old one is chopped up and unusable from PO)
I plan on using carpet tape instead of adhesive, as i want the option to remove someday..
Color is Stock Interiors "dark green"
Old 01-27-2014, 01:17 AM   #115
C20scott
Better pics of gauge bezel below.
- Speedo, volt, water temp, oil press, and fuel level are all VDO vision
- Tachometer is a standard Autometer, that i will need to set for a 4cyl engine, to match the Cummins tach sensor.
- EGT and Boost are digital autometer gauges
- Turn signal indicators are .357mag shells that i drilled the primers out of(after firing). I bought a pack of 10 pre-wired green LED lights off of ebay for $8. I inserted these into the shells, and glued them into place.
- Switches are still up in the air at this point. Offroad lights, cooling fan off, air compressor engage, are the ones that i can think of now... Maybe PA system or something stupid like that??
-Headlight/wiper switches have been relocated elsewhere on the dash.
Old 01-27-2014, 02:25 AM   #116
y5mgisi
y5mgisi's Avatar
Love it all.
Old 01-27-2014, 03:49 PM   #117
Dieselwrencher
Loking good. You might change your mind about dumping the exhaust behind the cab once you start driving it. With no muffler you might get tired of it quickly.
Ryan
Old 01-27-2014, 04:01 PM   #118
y5mgisi
y5mgisi's Avatar
Also, your shackle flip is from offroad design. Not offroad development.
Old 01-28-2014, 09:34 PM   #119
C20scott
I may be able to convince myself to have a stack in the bed if it was out of necessity, meaning noise, or soot on my fenders. Until then I want to be "Low Key". Luckily my pipe routing will be easily accessible for modification.
ORD, offroad design, sorry for the typo.
Old 01-29-2014, 08:13 PM   #120
Dieselwrencher
If you can, run the exhaust pipe along the outside of the frame and then have it angle out behind the rear tire or something. That's what I'm going to try to do to my Longhorn some time this year.
Ryan
Old 01-29-2014, 09:37 PM   #121
rambler
MOVE OVER
rambler's Avatar
subscribed... would want to do this someday,but no way do I have these skills....
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 02-05-2014, 02:20 AM   #122
C20scott
The NV4500 reverse switch pigtail is the same between GM and Cummins transmissions. Part # is 12085485, and should cost less than 10$. It is a dual prong male connector, with a notch on one of the prongs. Allows current to pass through to your reverse light..
Hopefully this saves someone a few hours of research.
Old 02-05-2014, 02:24 AM   #123
C20scott
Got around to wiring up the gauge bezel. Looks somewhat complicated, but in reality its not. Take it one wire at a time and eventually it will look like this.
I have a harness connector that i will be connecting all of the wires into. Switch purposes are still undetermined. I will probably finish this up in the next few weekends.
Old 02-05-2014, 02:30 AM   #124
C20scott
Another embarrassment that needs to be fixed. The PO had cut about 5 holes in the trans hump, with what had appeared to be a cutting torch, or a chainsaw.
Option A: $100 for a hump out of a nearby salvage yard.
Option B: Cut out all holes, and rebuild hump with sheet metal already in my garage...
I didnt take a pic of the "before", but here is "after" i cut out the holes. I am also extremely tired of dealing with the off-brand sound deadener that the PO applied to the floorboards. It is a sticky mastic that looks like crap, difficult to remove, and melts when i grind or weld near it. i might cover it up with another layer or something.
I will finish this up in the next week or so also.
Old 02-05-2014, 02:36 AM   #125
C20scott
Yet another stupid mod that i have taken on. I am happy with the placement of the driver/passenger seats, however, the center jump seat brackets will need to be modified to fit. Also, i want it to fold down.
So, this means i tear it apart, find out what its made of, and re-create. At this point i think i can buy some marine seat fold-down brackets, cut the round tubing at the desired joint, and bolt them on. Hopefully it doesn't turn into too large of the project.
This one may wait for a month or so, as it is not critical to me driving the truck around
