Old 07-26-2013, 10:53 AM   #101
Andice
Andice's Avatar
Re: 1966 GMC 305 V6 Service
Rufton: I am impressed by the work you've done on your 305 V6 engine! Do you happen to have a part number for the oil filler cap? I could use a new one and yours looks just like what I need.
Andice is offline   Reply With Quote
Old 07-27-2013, 03:11 AM   #102
DouglasRaymond
Interesting, not sure I would get it right!
DouglasRaymond is offline   Reply With Quote
Old 07-29-2013, 05:03 PM   #103
Rufton
Thanks. Maybe you can find a match at swap meet, ebay, etc.
Rufton is offline   Reply With Quote
Old 07-29-2013, 05:25 PM   #104
Rufton
Strange road trip 305E V6 HWY milage.
1. 9.3 mpg (about 60 mph I-75)
2. 17.1 mpg (about 70 mph I-75)
3. 16.7 mpg (about 70 mph I-75 return trip)
4. 9.5 mpg (about 60 mph I-75 return trip)
Mileage calibrated against map quest.
Triple checked full tank when I got the 17.1 mpg; even saw gas in tank through filler neck.
Thought I was home free until the last 9.5 mpg reading.
I suspect the carb or distributor is misbehaving under 70 mph.
Maybe I'll advance timing a bit more than stock and verify timing advance is functioning. I'm a little suspicious of carb power valve function.
Old 07-29-2013, 06:29 PM   #105
Andice
Andice's Avatar
Rufton: Thanks for the detailed images of the oil filler cap. The cap in my 305E has two thinner mounting tabs on the underside. It kind if resembles the tabs on a breather/oil filler cap. I will consider trying a cap like yours. Can't explain your spotty fuel consumption, but mine is in the shop right now getting a proper tune since it has been backfiring a little. I may have damaged the power valve in my Holley carb
Old 07-29-2013, 06:59 PM   #106
Rufton
I've got a spare Stromberg. When time allows I hope to rebuild it for comparison. I hope to install an UEGO O2 AFR gauge because it takes away a lot of guess work. I'm willing to consider holley as well. Don't think Stromberg power valve is affected by back fire but it's design does look primitive. Not sure how to test power valve function; suppose one could wire open/shut to see how it affects performance.
Old 07-29-2013, 07:19 PM   #107
Rufton
The Stromberg power valve actuation rod ( looks like nail ). Moves up and down w/ vacuum to stroke spring loaded power valve (looks like jet w/ wire in center). Don't know if hangs up.
The old Stromberg suffered plenty of back fires through the years but power valve still functioned on the bench.
Old 07-31-2013, 02:22 PM   #108
Rufton
Distributor seems to be behaving. I wanted to dial in a couple more degrees but advance already looks good relative to some other engines. Not sure if I ever hit mechanical advance stop; didn't wan't to spin it faster cause not confident in tach accuracy (indicates low compared to car tach).
7-31-2013 66 GMC 305E V6 timing data:
Timing (vacuum advance connected, cold engine):
6* 490 RPM
24* 1000 rpm
42* 1500 rpm
45* 2000 rpm
48* 2500 rpm
Timing (vacuum advance connected, warm engine):
9* 600 rpm
16* 1000 rpm
16* 1000 rpm
42* 1500 rpm
46* 2000 rpm
49* 2500 rpm
55* 3000 rpm
Timing (vacuum advance plugged, warm engine):
9* 600 rpm
16* 1000 rpm
25* 1500 rpm
29* 2000 rpm
33* 2500 rpm
38* 3000 rpm
Dwell (warm engine):
31 dwell 620 rpm
30 to 31 dwell from 620 to 2500 rpm.
Timed vacuum port Stromberg WW:
<2” Hg 620 to 900 rpm
4” Hg 950 rpm
6.5” Hg 1000 rpm
13.5” Hg 1200 rpm
15.5” Hg 1500 rpm
18.5” Hg 2000 rpm
18.5” Hg 2500 rpm
Old 08-12-2013, 12:10 PM   #109
TommyDuncan
I have a couple spare caps. I never compared them but they appear the same. When I get home I will compare them. PM me your address and I'll send you one.
TommyDuncan is offline   Reply With Quote
Old 08-12-2013, 09:27 PM   #110
duallyjams
duallyjams's Avatar
what's the rpm on the engine when your running 60-70 mph
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-12-2013, 11:24 PM   #111
TommyDuncan
I did the math and 60mph should be about 2150rpm. 70 should be pushing 2500rpm.
Old 08-13-2013, 06:46 PM   #112
Andice
Andice's Avatar
I must have been smoking crack because my oil filler cap is just like Rufton's and likely the same as all other oil filler caps for this era GM vehicle. Sorry for the stupid posts and thanks for the offer T Duncan.
Old 08-13-2013, 08:30 PM   #113
awbrown
rufton , what port do you have the vacuum on now ?? From what you are telling us it looks like it is on the ported vacuum , it should be on manifold vacuum .. all the vehicles I have had got much better milage on manifold vacuum than ported...
awbrown is offline   Reply With Quote
Old 09-16-2013, 05:48 PM   #114
performo
Junior Member
performo's Avatar
Hello, Does anyone know the factory weight of the GMC 305 v-6?
Thanks in advance.
performo is offline   Reply With Quote
Old 09-16-2013, 05:57 PM   #115
TommyDuncan
Thanks in advance.
the number I keep hearing is 800 lbs and judging by how the two I have on stands feel when I try to move them I believe it!
Old 09-16-2013, 06:28 PM   #116
performo
Junior Member
performo's Avatar
That works for me. I have been scouring the internet and can not find the weight specs. Thanks Tommy.
Old 09-16-2013, 06:33 PM   #117
TommyDuncan
Thanks in advance.
I just stole this from Jolly's site:
The "GMC Replacement Engine Catalogs" lists the following dry weights:
305A = 738 lbs.
305B = 771 lbs.
305C = 840 lbs.
305E = 795 lbs.
351 = 860 lbs.
401 = 880 lbs.
478 = 925 lbs.
702 = 1485 lbs.
637 = 1219 lbs.
Old 09-17-2013, 01:44 PM   #118
performo
Junior Member
performo's Avatar
Great weights reference, Thank you
Old 12-03-2013, 11:29 PM   #119
3/4ton Randy
Rufton, I would like to thank you for all the hard work, pictures, and detailed information you have put into this thread. I recently purchased a '66 with the 305 V6, and I have been a little worried about how to take care of it. You have saved us so much time and probably wasted effort. You are great!
3/4ton Randy is offline   Reply With Quote
Old 12-04-2013, 12:31 AM   #120
raylube
raylube's Avatar
X 2. Do you have a list of
part numbers and vendors?
raylube is online now   Reply With Quote
Old 12-04-2013, 03:35 PM   #121
b.sharp
b.sharp's Avatar
I have just purchase a 1ton with one of these engines. I have no idea what exact motor it is. Is there a way to tell one from another. I know it's the V6 but do not know which one. It there anything major to check before trying to turn these engines over? Truck is junk and for parts but hoping to save the motor for a '68 GMC. Great thread!!
b.sharp is offline   Reply With Quote
Old 12-04-2013, 06:54 PM   #122
MusicMan70
MusicMan70's Avatar
Look here BSharp;
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 12-04-2013, 07:14 PM   #123
b.sharp
b.sharp's Avatar
I will check it out this weekend. Truck is at my in-laws. Thank you for the information.
Old 12-04-2013, 07:20 PM   #124
TJ's Chevy
TJ's Chevy's Avatar
One sweet 305 E! Doing fantastic work!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-05-2013, 10:12 AM   #125
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
This threads sets the bar.
Thank you for taking the time to stop and photograph the various steps along the way. A picture really is worth 1000 words.
That said, I'll go back to lurking and learning.
