Old 10-02-2019, 08:08 AM   #101
k5kev
New Member
Re: NEW: 3/4T-1T Brake Booster System-Only Here! Finally!
Hi Frank,
I need a set up if you have one left or the parts to put one together. Disc/disc prop valve if possible. Thanks, Kevin.
k5kev is offline   Reply With Quote
Old 10-02-2019, 08:04 PM   #102
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Smile Re: NEW: 3/4T-1T Brake Booster System-Only Here! Finally!
[QUOTE=k5kev;8602748]Hi Frank,
I need a set up if you have one left or the parts to put one together. Disc/disc prop valve if possible. Thanks, Kevin.[/QUOTE
Yes, I am building them on a regular basis and have all components in stock. Just let me know if it is going on a 3/4T-1T or 1/2T. Size matters! Thanks, Frank
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 10-02-2019, 09:20 PM   #103
k5kev
New Member
It’s going in a 72 4x4 blazer, but I want the 3/4-1 ton.
Old 10-03-2019, 03:08 AM   #104
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Sure. I do those all of the time.
Phone: 360-956-7170
Old 10-03-2019, 07:24 AM   #105
k5kev
New Member
PayPal sent. Thanks.
Old 10-04-2019, 05:47 PM   #106
bmfm64
bmfm64's Avatar
Frank, what is the difference between the 3/4-1 ton vs the 1/2 ton? the brakes are super stiff on my Blazer and I wouldn't mind swapping the booster out to a better one.
bmfm64 is offline   Reply With Quote
Old 10-04-2019, 08:18 PM   #107
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I have a 9"DD that is about 30% more powerful than stock 1/2T and I have these 3/4T-1T systems that are about 50%+ more powerful. These are usually too powerful for a 1/2T unless you are running very big wheels & tires.
Phone: 360-956-7170
Old 10-08-2019, 04:38 PM   #108
bmfm64
bmfm64's Avatar
Hi Frank- Im running a 20" steel wheel alonmg wiht 35" tires- the tire/wheel combo is pretty heavy. Do you recommend the 1 ton one?
Old 10-08-2019, 10:23 PM   #109
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Yes. That will work best. It is almost finished. 4 wheel DB setup. Frank
Phone: 360-956-7170
Old 11-21-2019, 07:15 AM   #110
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: NEW: 3/4T-1T Brake Booster System-Only Here! Finally!
Do you have any of the 1/2 ton kits? If so you have a price. Need to get something on my daughter 1/2 ton step side I'm building.
It has 18" wheels all around.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-21-2019, 11:46 AM   #111
68 P.O.S.
Here you go Andy http://67-72chevytrucks.com/vboard/s...d.php?t=779896 I bought this one from him a few years ago and it works great.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 01-08-2020, 05:41 PM   #112
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
2020 PRICES:
[/U]
Slight increase--$25-- to cover extra shipping charges-coming & going (some over $50), bleeder set, prop lock tool, threaded rod.
$350 + $75 S/H/INS
Phone: 360-956-7170
Old 01-08-2020, 08:14 PM   #113
NorCalC20LWB
Hi Frank, I have a 3/4 ton with disc/drum and a leaky aftermarket prop valve plus very hard/stiff braking. Do you think your setup would be good upgrade for my situation?
Thanks,
Brian
NorCalC20LWB is offline   Reply With Quote
Old 01-09-2020, 12:32 PM   #114
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Thanks,
Brian
Hard stiff braking sounds like a bad booster. It should only take a light pedal pressure to stop. I always start with a fresh firewall booster/MC set and move out from there to make good brakes. Frank
Phone: 360-956-7170
Old 01-24-2020, 12:45 PM   #115
fishmunger
fishmunger's Avatar
Hi,
I have a 72K10 that I want to replace/upgrade the braking system. Its old and I need to tow my boat safely. It's front disc rear drum. It has 35x12.5 tires.
I'm assuming I want the 3/4 or 1 ton booster?
Also, this is a direct bolt in to my existing truck right?
Do you have any in stock currently?
Thank you.
fishmunger is offline   Reply With Quote
Old 01-24-2020, 06:52 PM   #116
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Originally Posted by fishmunger View Post
Hi,
Thank you.
I have all new (not rebuilt) components to do a big 3/4T-1T booster with the correct 1/2T MC/PROP for your K10. It is a much more powerful set for bigger tires and a heavier truck load. Direct bolt in, uses OEM lines and OEM style brackets & pedal rod. Frank
Phone: 360-956-7170
Old 01-27-2020, 08:52 PM   #117
JerryIndy2112
JerryIndy2112's Avatar
Hey
I am Jerry. I have a '71 one ton. The front brakes are disk, redone last year. This year I found my rear drums were shot. I had to do disk on back. Do you have a set up that would match this system? Is it more expensive. Let me know. I would prefer black, but can paint what ever you have.
Jerry
JerryIndy2112 is offline   Reply With Quote
Old 01-27-2020, 10:19 PM   #118
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Originally Posted by JerryIndy2112 View Post
Hey
Jerry
Yes. I can build a 1Ton disk/disk system for the same price. It will be black booster & brackets, like those shown on the first pages of this thread. You can pay with PP or CC using the email addy or secure phone # listed on all of my posts. Frank
Phone: 360-956-7170
Old 01-27-2020, 10:30 PM   #119
JerryIndy2112
Cool,
I can pay on 2/7/20. look forward to getting this on my truck. thanks. I will pay as soon as i can.
Jerry
Old 02-10-2020, 09:19 PM   #120
Willys_MB
Willys_MB's Avatar
Hi Frank,
Does the booster come with the braces needed to install? I just picked up a 71 3/4 ton front end to swap into my 68 3/4 ton. I need the whole booster assembly as my truck doesn’t have one. I know I need the MC and proportioning valve and that’s why I’m thinking of going your route. Any tips or ideas for other parts I may need?
Thanks!
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 02-11-2020, 04:03 PM   #121
Willys_MB
Willys_MB's Avatar
Originally Posted by Willys_MB View Post
Hi Frank,
Thanks!
Not sure if you saw this. You're usually pretty quick to respond, but I've been missing posts a lot without the email notifications. I just thought I'd check in.
Old 02-11-2020, 04:24 PM   #122
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Hi Frank,
Thanks!
Look at the first post on this thread. The brackets on the new set are stronger than original. The two extra original braces are not needed or recommended. Frank
Phone: 360-956-7170
Old 02-11-2020, 11:13 PM   #123
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
3/4T Brake Booster Systems are temporarily SOLD OUT.
Waiting for more new boosters to be built.
I will post when ready. You can get on list by posting on here.
Thanks, Frank
Phone: 360-956-7170
Old 02-12-2020, 01:09 AM   #124
Willys_MB
Willys_MB's Avatar
Thanks, Frank
Damn, I was getting geared up to buy one. Any idea how long the wait is? I guess I’ll be first in line.
Old 03-21-2020, 01:30 PM   #125
Willys_MB
Willys_MB's Avatar
PayPal sent per PM saying you have some in stock. $425+3%
