Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-13-2015, 09:48 PM   #101
70stroker
70stroker's Avatar
Re: 70 GMC 4wd version
Originally Posted by BigRed76 View Post
Are you running a short water pump?
Yes it is a short pump.
Like i said in 2wd form i had about another 3/4 of inch at the firewall of clearence and it seemed like i had more at the front of the motor. But im not about to swap everything back over to verify.
I moved on i think all is good.
70stroker is offline   Reply With Quote
Old 01-13-2015, 09:54 PM   #102
70stroker
70stroker's Avatar
Alot of progress, finished all wiring, all lights works everything has good grounds.
Also installed my front diff cover from chassis unlimites to match the rear, these things are pure beef.
Got the bed and front clip swapped over, front tire is a 35 rear a 33, im pretty sure im going 35s
Also started working on my fuel filler.
Old 01-13-2015, 10:21 PM   #103
mud.man.rj
mud.man.rj's Avatar
Fuel filler looks good, the 33's look small and the 35's just right.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 01-28-2015, 02:56 AM   #104
Axe
Your build looks great, If you haven't found a drive shaft any 1/2 ton with slip yoke should work 208 or 241 tc, if you can find one longer should be around 35.00 to have shortened. On your bumpers with the body lift back just weld a piece of angle on top of your frame and relocate holes for bumper, this way you don't loose any strength if you still want to tow a trailer, the front just cut your frame horns off and move them up an inch or whatever your body lift is. I have an 85 blazer I did it with a 3 inch body lift, bumper looks stock now.
Good luck and great work can't wait to see it finished.
Axe is offline   Reply With Quote
Old 04-25-2015, 02:35 AM   #105
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice transformation. Are you going white now on body color? Those big blocks are tight in there. I put one in a 69 k20 I pulled with and it was a sob to get the tall valve covers off it.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-28-2015, 10:51 PM   #106
70stroker
70stroker's Avatar
Thanks diesel, yes its going to be white. Figured easiest to paint behind the cab now so i dont have tl pull the bed again.
Didnt realize its been this long on the build, my wife and i bought our first home march 18th and its been a month of no sleep, new carpet, close a few doors just to open another one, paint all rooms, new bathroom flooring, etc. But we moved in this weekend so in a few weeks i should be back at it.
Old 05-15-2015, 03:11 PM   #107
b.sharp
b.sharp's Avatar
In my opinion you may have turning problems with the 35's. I think they will hit the back of the front fenders. You want to try your turning radius before buying tires.
b.sharp is offline   Reply With Quote
Old 05-16-2015, 03:49 PM   #108
mud.man.rj
mud.man.rj's Avatar
I agree on the tires hitting, my last 71 had 35's but needed min of 5"s of lift and were still close, but the 35's sure look better than the 33's.
5.0 4spd std.
7" lift w 35's.
Old 05-16-2015, 04:49 PM   #109
esoxman308
esoxman308's Avatar
Could always look for the stock Hummer size tires, they were a 34.5" tire in the size of 315/70/17.
esoxman308 is offline   Reply With Quote
Old 05-17-2015, 01:37 AM   #110
swamp rat
swamp rat's Avatar
Turning radius combined with hitting some bumps, rocks curbs or what have you..
I'd like 35's also but am concerned about hitting the fenders as well, my BDS 4" springs give me 12" from the top of the front tire to the top of the fender well with BFG 33's, just not sure its gonna clear the rear of the opening and would hate to spend the coin and find out i have a problem
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-17-2015, 07:39 PM   #111
70stroker
70stroker's Avatar
Appreciate all the concerns, i already bought the 35s before i even put one on. 500 for like new 35 bfgs wouldnt be hard to sell.
But they clear 100 percent fine, i drove the truck the 22 miles to my new house with no rubbing at all.
35s and 4 inches clear fine fore street driving, now that is with factory rallies so i dont have to worry about offset of aftermarket wheels.
I would never go bigger then a 16 on a old 4x4 so 315 70 17 where out of the question.
Old 05-17-2015, 11:32 PM   #112
swamp rat
swamp rat's Avatar
Not sure what lift you have?
I'd like to know the lift size and if you get a chance can you post a pic of the wheel turned and showing a shot of the clearance to the rear of the fender opening?
This is for my information to help me decide if i should buy 35's next for my other set of rims.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-18-2015, 07:44 AM   #113
cmabolt
cmabolt's Avatar
looking good. Great progress!
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636
Easier to beg forgiveness than ask permission!
cmabolt is offline   Reply With Quote
Old 08-19-2015, 07:06 PM   #114
70stroker
70stroker's Avatar
Not truck related, but got a new trailer.
Old 08-20-2015, 04:30 PM   #115
Dieselwrencher
That's a very nice trailer!
Ryan
Old 01-16-2016, 04:38 PM   #116
El Dorado Jim
nice build, any new progress?
El Dorado Jim is offline   Reply With Quote
Old 01-18-2016, 11:53 PM   #117
70stroker
70stroker's Avatar
Truck is basically done, got interior in, everything underneath checked and tightened, painted (which i did a paint job most will hate on here), drove it around town about 300 miles so far.
Really need front inner wheel wells before i throw a rock into the hood, and need radio antenna cable, bed line bed, and turn signal lense.
Thanks for the interest
Old 01-19-2016, 12:17 AM   #118
BigRed76
BigRed76's Avatar
Curious to know what the paint job is...
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-19-2016, 12:40 AM   #119
70stroker
70stroker's Avatar
Like i said alot wont like it.
Heres the most recent pics it wasnt done in these
Aux reverse lights
Hidheadlights
Old 01-19-2016, 12:42 AM   #120
70stroker
70stroker's Avatar
I got to thinking about thisnpost the other nighg, never did grt pics, but i have a 4 inch rough country lift, which everyone says wont clear, but i alsp have off road design shackles which are slightly longer then stock so i think thatmight be the difference.
Old 01-19-2016, 12:44 AM   #121
BigRed76
BigRed76's Avatar
That is different, but I like it.
And I have to ask, what are you using for headlights?
Zach
Old 01-19-2016, 12:49 AM   #122
70stroker
70stroker's Avatar
http://www.ebay.com/itm/H5001-H5006-...NSqPFw&vxp=mtr
I wanted to use the truck and not be afraid of scratchimg a nice paint job, and i wsnted all the trim which i dont have and csnt afford. So I figure over time ill buy trim piece by piece and when i have it i will do a proper paint job.
Old 01-19-2016, 01:21 AM   #123
BigRed76
BigRed76's Avatar
I just bought some headlight housings very similar to those. Im going to try them with HIDs.
Zach
Old 04-16-2016, 09:16 AM   #124
70stroker
70stroker's Avatar
In need of some help guys. My front turn signals wont work unless i hold thr bulb in (loose socket). So i am looking for the turn signal pigtail that runs from my light in the grill to the core support. I can find it in lmc or anywhere else, its a 1157 bulb.
Old 04-16-2016, 09:32 AM   #125
cmabolt
cmabolt's Avatar
I may have a new one I can send you. Let me check. I'll get send you a pm later today.
