Old 07-31-2016, 05:28 PM   #101
T and S
T and S's Avatar
Re: Rarest factory paint combos
Not real rare I guess, but here is how the factory paint turned out on my 66. Rubbed it out by hand, 'bout 30 hours worth of rubbing.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 08-01-2016, 01:00 PM   #102
davem815
davem815's Avatar
Originally Posted by Classic v6 GMC's View Post
All the paint codes in the book start with W83E5 and 3 more numbers after that.
Classic v6 GMC's,
I'm trying to determine the paint codes on my '66 special paint. Any chance any of the yellow's in your GMC Truck Special Paint Color book end with either 555 or 686? Both of those numbers are written on the firewall of my truck.
The 555 is written over the word comfort. It's much more legible in person than in this picture because the 555 is in much darker, crisper ink.
Thanks, Dave
1966 GMC 1500 (3/4 ton) Custom V6 3sp Edna
1970 GMC C2500 Deluxe lwb 307/4sp Ol' Green
1971 Chevy C20 Custom lwb 307/3OTT, now a project in family since 1974
2014 GMC K2500 Crewcab 6.0 gas
2005 GMC Canyon Ext cab 4wd daily driver
1963 F*rd/Howe C750 fire truck 11,000 miles
davem815 is offline   Reply With Quote
Old 08-01-2016, 08:56 PM   #103
Classic v6 GMC's
Classic v6 GMC's's Avatar
Originally Posted by davem815 View Post
Classic v6 GMC's,
Thanks, Dave
There is a 555 yellow!! Will post some pics in a few minutes.
Thanks, Andy
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 08-01-2016, 09:09 PM   #104
Classic v6 GMC's
Second and third pic is the 555 yellow.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 08-01-2016, 09:39 PM   #105
davem815
davem815's Avatar
Andy, that looks like it!
I held my phone up to the paint where a piece of trim is off and it looks like if it was polished up, it would match. I tried to have my wife take a picture of my phone and the paint, but the lighting in the barn was bad.
We named the truck banana the first time we saw it, so the icons i found above fit perfect.
Thanks, thanks, thanks
Dave
Any chance your going to carlisle truck nationals this weekend?
Old 08-01-2016, 10:00 PM   #106
Classic v6 GMC's
Dave
The lighting of my camera might make the color a little off as well.
We aren't going to Carlisle but hear that it's a great show.
Which motor is in your truck? 305 or 351? a 3 speed in a 3/4 ton is fairly unusual.
Andy
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 08-02-2016, 05:56 AM   #107
davem815
davem815's Avatar
It's a 305 w/ 3 speed on the tree. With 4.10. Not exactly a towing or hauling machine, first gear is kinda high.
Also came with radio delete. And hazard flasher.
Old 08-08-2016, 12:30 PM   #108
davem815
davem815's Avatar
Classic v6 GMC's, was you able to get a cross reference for your special paint code? I have been unable to find a cross reference for W83E5555 and the paint shop I checked with could not find a cross reference. They said the format did match anything they had.
Thanks, Dave
Old 08-08-2016, 08:05 PM   #109
Classic v6 GMC's
Thanks, Dave
To reference the W83E5531 on my dad's truck I used this site.
http://paintref.com/paintref/index.shtml
I messed with it until I found it under code WE5531
http://paintref.com/cgi-bin/colorcod...&button=Search
I tried WE5555 and it does not come up with anything.
You might try and get your paint shop to try 555, 5555, WE5555
All the paint codes in my book start W83E5 so the important part of the code is 555
Thanks,
Andy
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 08-09-2016, 07:34 AM   #110
davem815
davem815's Avatar
Thanks, I'll try those alternate numbers. I have tried on that website.
Old 08-13-2016, 12:15 AM   #111
mr57
mr57's Avatar
In 1964, was white a fairly common color?? Around here, most of the 60-66's were either gold or pea soup/diarrhea green, the odd one a light blue....
1957 Chevy swb
1964 Chevy swb panel
mr57 is offline   Reply With Quote
Old 10-25-2016, 12:32 PM   #112
davem815
davem815's Avatar
Well I looked and there is no 5531 under the hood that I can find.
Andy, I was rereading this thread and saw you mentioned your truck had the firewall markings intact. I have two questions:
1) does your have the word Comfort written on the driver side lower firewall? I'm assuming your truck is Comfort. Mine does and it has the 555 written over top. Maybe yours has the 531 paint code there?
2) does your truck have an emergency flasher switch? Is there a EW written on the center left of the upper firewall? I'm thinking EW may have been for Emergency Warning. Two other truck besides mine had EW with the switch.
Old 10-25-2016, 04:32 PM   #113
Railroadman
Railroadman's Avatar
My '66 was a work truck, painted 519 School Bus yellow. That's what I intend to put it back to when I get that far.
Railroadman is offline   Reply With Quote
Old 10-25-2016, 09:56 PM   #114
Classic v6 GMC's
Yes our truck has "Comfort" on the same spot as yours and the same circle around and under the brake booster. Our truck does not have the paint code in the same spot. Ours paint code was partially under the driver side inner fender and wrote as 5531.
Our truck does have the emergency flasher switch and a "ew" on the far passenger side of the fire wall.
Our truck also has the "Tinted W/S" in the same spot.
Does your truck have a "2T" around/under the brake booster and above the steering column. I think it stands for two tone paint.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 10-26-2016, 03:40 AM   #115
davem815
davem815's Avatar
I will have to check tonight. I know it has a circle around the brake booster bolt holes and some letters in that area. I think they at partially covered by the brake booster. I just assumed they were part of the brake booster markings.
Old 10-28-2016, 12:09 PM   #116
5661DWL
Just starting restoration on a 1961 Chev Apache 10 in Tahiti Coral/White. This is the only truck I've ever seen in this color. 283ci/4spd truck.
5661DWL is offline   Reply With Quote
Old 10-28-2016, 12:44 PM   #117
GMCNUT
GMCNUT's Avatar
Holy dog crap batman - someone else has one of these? LOL
I found a matching Tahiti Coral two-tone long fleetside identical to yours in a junkyard one time and found it super interesting because it also came with the special Sage Green interior which was only used with this Tahiti Coral exterior - totally different than the normal Bluish Silver interior color used in 1961. This year, I found a short bed BBW fleetside in this same two tone Tahiti and it has the Sage interior too - I just bought this truck so don't have pics but will take a couple later today and post them
Between me and you though, I think we are it for Tahiti Coral truck owners
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 10-28-2016, 12:45 PM   #118
GMCNUT
GMCNUT's Avatar
So Tahiti was a one-year only color - post some shots of the dash and door panels etc inside yours
Old 10-28-2016, 12:51 PM   #119
5661DWL
This truck does not have the Sage Green interior color. It has the standard interior colors. Radio delete, drivers only arm rest.
Old 10-28-2016, 12:56 PM   #120
GMCNUT
GMCNUT's Avatar
OK - cool - could be its not a Custom Cab - seems like that Green interior was offered on the Customs and both these I found are custom cabs....
Still wanna see more pics of this truck - send us a link to your online photo album
Old 10-28-2016, 12:57 PM   #121
5661DWL
Found this truck in the black bed wood thread... Tahiti Coral? or GMC equivalent
http://s270.photobucket.com/user/jon...4/133.jpg.html
Old 10-28-2016, 12:59 PM   #122
5661DWL
Sorry, the link didn't work. Black Bed thread post 81
Old 10-28-2016, 01:03 PM   #123
5661DWL
This is not a custom cab truck. I'll work on getting more photos. The truck is located at a relatives farm, he's the owner, I helping with the restoration. I did learn to drive in this truck when I was about 10 or so... some 45 years ago.
Old 10-28-2016, 01:51 PM   #124
GMCNUT
GMCNUT's Avatar
Sure - so GMC shared a lot of things with sister GM division Pontiac in the 50's and 60's and the color you see on Jon's restoration is called "Mesa Tan" on GMC and Corsair Tan on Pontiacs. Mesa was a solid color single stage lacquer where your trucks' Tahiti color was a "poly" color or metallic color. These metallic "poly" colors were started being offered on Truck interiors beginning in 1958, and seems like the first poly was Oriental Green in 58 for exterior colors - all others were still solid color mon-metallics. By 1961 Poly colors were being offered more widely for exterior choices so Tahiti Coral, Klondike Gold and Tampico Turquoise became available. GMC offered a more close match to your Tahiti color on its 1963 trucks called "Palomino Tan" but even it was non-poly. I don't know why I thought you needed to know all that, but too late now LOL
Old 10-28-2016, 10:01 PM   #125
factorystock
factorystock's Avatar
Hope you revive this rare color in the resto! Check out post #24 http://67-72chevytrucks.com/vboard/s...ssembly+photos
factorystock is offline   Reply With Quote
