Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-08-2014, 05:03 PM   #101
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Re: Project 6 Point Oh
Originally Posted by East Tex View Post
They were from Lowe's. Rip off huh? That's what happens when you don't plan ahead LOL.
I would've never thought those would be from Lowe's haha. It's hard to plan your entire build ahead. There's always those little things you sort forget about.
What % gloss is the powder coating? Looks very similar to mine which was 60%. They did nice job!
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 07-12-2014, 10:09 AM   #102
East Tex
I'm not sure on the percentage of gloss. I'll ask my guy, the next batch of stuff that I take to him.
My 1972 K5 6.0 LTR 4L60 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=622068
East Tex is offline   Reply With Quote
Old 07-21-2014, 10:54 PM   #103
East Tex
OK DarkOlive, you have a good eye for powder coating LOL. I talked to my powder coater and he said that my stuff was 60%.
He said that he had a 90%, but it was so shiny and glossy, that the smallest scuff would stand out bad and he didn't recommend it.
Old 07-21-2014, 10:55 PM   #104
East Tex
Scored some tow hooks last week!
Old 07-21-2014, 10:59 PM   #105
East Tex
I got my new wiring harness and ECU reflashed from Speartech.
Old 07-21-2014, 11:06 PM   #106
East Tex
Started my fuel lines last week. The bulk of it is stainless lines that I formed with a tubing bender, and the tank and motor will be hooked to the stainless lines with 6AN braided hoses.
Old 07-21-2014, 11:10 PM   #107
East Tex
Ordered a few wrong 6AN fittings, so I'm waiting on the new ones, then I can finish the fuel system.
Old 08-08-2014, 10:15 PM   #108
East Tex
Finally finished my fuel system. I just need to fab a bracket by the bell housing, to hold the braided lines up. Where the weight of the hoses wont be hanging off of the fuel rail. I also figured out that wrenches scar up the anodized fittings, unless you put tape on them. I know they make special wrenches for those fittings, but I didn't have any.
Old 08-08-2014, 10:17 PM   #109
East Tex
More
Old 08-08-2014, 10:42 PM   #110
East Tex
more
Old 08-08-2014, 10:53 PM   #111
East Tex
Old 06-24-2015, 12:50 AM   #112
East Tex
Well, it has been a while since I've posted anything. I have been working on it, but have neglected to update this thread. So, here we go...
Old 06-24-2015, 12:59 AM   #113
East Tex
Fuel lines are finished. My LS has a truck manifold with a return line, so I had to run a supply and a return. I had plenty of 3/8" stainless, so I ran 3/8" on the return line too.
Old 06-24-2015, 01:14 AM   #114
East Tex
Long story but the bottom line is, if you have an aftermarket aluminum radiator, an aftermarket core support, and reproduction rubber mounts, just be ready to modify everything so that it will all fit correctly.
Old 06-24-2015, 01:18 AM   #115
East Tex
Trailblazer SS exhaust manifold studs are a mess, so time to remove the old ones, chase the threads, and replace with new studs. I still need to get them ceramic coated.
Old 06-24-2015, 01:29 AM   #116
East Tex
The good news is...I AM FINISHED WITH MOCK UP!!!!!
Time to tear it down and get the frame powder coated, change out ring and pinion in both diffs, and start final assembly.
I have more pics on my camera and I will get more stuff posted soon.
I would love to have a rolling chassis soon.
Old 07-22-2015, 10:37 PM   #117
East Tex
Time to tear it all back apart and powder coat the frame and other pieces.
Old 07-22-2015, 10:41 PM   #118
East Tex
Looks like my axles are pitted a little, but they will clean up good enough with some steel wool or fine sandpaper. I am going to replace the inner bearings that ride on the axles too.
Old 07-22-2015, 10:51 PM   #119
East Tex
Removing front spring bushings.
Old 07-23-2015, 09:21 AM   #120
East Tex
I posted the wrong picture of the front axle, the photo shows where the inner seal rides.
Old 07-23-2015, 10:02 AM   #121
East Tex
Tearing down the front diff. Sandblasting the knuckles and misc pieces.
Old 07-23-2015, 10:17 AM   #122
East Tex
Pressure washing and grinding smooth a few rough spots before taking the frame to the powder coaters.
Old 07-23-2015, 10:28 AM   #123
East Tex
This aftermarket radiator core support has some serious spot weld splatter. I am going to grind off the splatter before taking it to the powder coater. Also I drilled holes and welded in some nuts, so I could relocate the battery tray to the driver's side.
Old 07-23-2015, 10:41 AM   #124
East Tex
I'm going to tear these diffs down and set up the new ring and pinions. Then tear them down to bare housings and take the housings in to be powder coated. Then when the housings are back from the powder coaters, all I'll have to do is wash them out real good and install shims, bearings, and gears that I've already dialed in.
Old 07-23-2015, 10:54 AM   #125
East Tex
One thing I hadn't planned on, was the Eaton Posi clutches came out in pieces. Also the rear axles had huge grooves where the axle bearings ride. They had already replaced the stock style bearings with offset bearings and seals, but those never work well. So it is getting new rear axles and axle bearings. The brake drums were grooved deep and are junk.
