Old 08-13-2015, 07:38 PM   #101
BigRed76
BigRed76's Avatar
Re: Spring Swap Thread - 1963 K15
One more question, I didn't see it mentioned anywhere but are those rancho shocks?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 08-13-2015, 09:22 PM   #102
'63GENIII
'63GENIII's Avatar
Yes they are RS9000S. I got them when I first swapped the axles a few years ago. The springs were so stiff that I never noticed a difference after adjusting them. Now it's night and day when I adjust them.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-13-2015, 11:59 PM   #103
BigRed76
BigRed76's Avatar
You're a step ahead of me haha my next question was going to be if you had adjusted them yet. Thanks for being the guinea pig on this looks like you did a top notch job
Zach
Old 08-14-2015, 12:08 AM   #104
'63GENIII
'63GENIII's Avatar
I just got tired of waiting for someone else to be the test dummy. I tell ya though, had this not worked, I'd be sleeping in the kids treehouse out back. Lol. Thanks for the compliments.
Chris
'63 k15 long step
Old 08-14-2015, 12:11 AM   #105
BigRed76
BigRed76's Avatar
I've been contemplating the 52" front spring sway for a while, but just haven't had the time or space to dive into it yet. I was also under the impression that longer rear springs wouldn't make enough difference to justify all the work, but it seems you've proved it to be well worth the extra work.
Zach
Old 08-14-2015, 08:40 PM   #106
'63GENIII
'63GENIII's Avatar
Hey Zach, yeah it was definitely worth all the work in my mind. I really like driving the truck again. Although I think that the rear 56 swap is just about moving the rear hanger, I've had several trucks with the 56s and a few with the 63s. There really wasn't a comparison for me. If I ever need more capacity, I'll dig up some 63" 3/4 ton springs and mess with those.
BTW, where in Loveland are you? My Father in Law lives there. Been there a few times myself for Thanksgiving. Real nice country.
Chris
'63 k15 long step
Old 08-15-2015, 02:28 PM   #107
BigRed76
BigRed76's Avatar
Yeah I would probably go with some 3/4 ton 63" springs to keep the load carrying capacity. Did the 63" springs interfere with your bumper brackets at all?
And I'm in South Loveland up on HP hill, and it is indeed a nice place.
Zach
Old 08-17-2015, 04:13 PM   #108
rickcdewitt
rickcdewitt's Avatar
I got the spring pads, bump stops and shock hangers cut off of the 14b and got it into place. Lots of measuring later, I was ready to set the new pads and the reworked shock mounts. I did have to get new 5/8" u bolts and plates for the tops of the springs. The plates are crazy thick (3/8") and are really well built.
i'm just about to this point with my k20 and have some 3/4t 63's and newer 2500 springs as well. i have few questions if you don't mind.
where did you get your new perches and top plates? my local offroad shop is out of them at the moment so i might as well order some.
do you think the rear hanger will interfere with using a modified drop hitch or bumper brackets? i'm wondering if i should use my 2000 model springs for better clearance?
anyways nice truck and pit! my pits 15 yrs old and always been a great shop dog,rick
1970 k20 6.0l/nv4500/np205/14bff in progress
build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014
rickcdewitt is offline   Reply With Quote
Old 08-19-2015, 11:04 PM   #109
'63GENIII
'63GENIII's Avatar
Hey Zach, Yes the DIY brakes did interfere a little with the bumper brackets. I believe that the two brackets on each side were originally supposed to "sandwich" the frame rail. Mine came with both brackets (2 on each side) bolted to the outside of the frame rail. I re installed the brackets the same way that they were because the rear cross member prevented me from putting it back the way it was stock. It worked out well though. I trimmed the bracket that was up against the frame enough to clear the hanger. The outer bracket actually uses the same bolt as the top rear spring hanger. I'll have to get some pics of it. Its just a little difficult to explain.
Chris
'63 k15 long step
Old 08-19-2015, 11:22 PM   #110
'63GENIII
'63GENIII's Avatar
Rick,
My last post kind of described the issues that I had with the bumper brackets. Not sure if you have the same kind. As far as the drop hitch, I got mine with the fuel tank and skid plate from an '89 Blazer. The hitch went on fine although the bottom bracket of the shackle did make it necessary to shim the back half of the hitch down 1/4". Having the tank in at that time made those bolts a PITA to install even with the bed off! lol. The top spring plates were from Ruff Stuff in Roseville, as were the u bolts. Top quality and fast ship. The spring perches were Summit but I got them before I found R.S. He has them too.
I just checked out your build. Nice work. Looks like its coming together pretty fast. Gonna be a great ride when its done! Keep up the great work.
Chris
'63 k15 long step
Old 12-29-2015, 02:49 PM   #111
dieseldude4bt
Did you get your drive shaft vibration issue fixed?
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 12-30-2015, 02:09 AM   #112
'63GENIII
'63GENIII's Avatar
For the most part yes. When I installed the TC, I must have been in a hurry because it was way off. I've got it corrected as best I can right now. Occasionally it will have a slight vibration when Im lugging 4th but other than that, its been great. I almost think that the divorced T cases need some sort of brace to keep it a little more rigid. Thats another project for another day. The DS vibration almost drove me insane. Just had to keep on messing with it.
Chris
'63 k15 long step
Old 01-09-2016, 09:30 PM   #113
Dsuper5
Dsuper5's Avatar
Hi 63genIII
Could you please let me know the parts number for the REAR Shackles and hangers ? I am trying to say all the parts which attach the REAR springs to the frame. Read trough your tread several times and could not positively identify them.
Just removed all the rear suspension parts on my 64 4x4 suburban and the Hangers i have wont do it.
Thank You
Eddy
Dsuper5 is offline   Reply With Quote
Old 01-09-2016, 09:34 PM   #114
Dsuper5
Dsuper5's Avatar
Top new springs bottom old ones.
Old 01-09-2016, 09:55 PM   #115
'63GENIII
'63GENIII's Avatar
Originally Posted by Dsuper5 View Post
Hi 63genIII
Thank You
Eddy
Will do Eddy. I think I just found the receipts for them the other day while cleaning the garage. Ill take a look in a few.
Chris
'63 k15 long step
Old 01-09-2016, 10:40 PM   #116
'63GENIII
'63GENIII's Avatar
Ok Eddy, I found the receipts. For the front hanger of the rear springs, I used an ORD GU28010 - 1 which is listed as a "shackle flip kit for 67-72 GM
For the rear of rear hangers, I used DIY 4x4 item #00590ka "first gen shackle flip and switch w/ 4.5" shackles."
I used the ORD up front and had to flip the spring front eye to the rear since the bigger eye on the front of the spring created a clearance issue with the hanger (which really wasn't sized to anchor the front of the spring anyway).
That said, I didn't know that the differences in frame widths that occurred throughout the years were compensated for by moving the hangers inward or outward so that the spring perches on the axles remained somewhat the same. I wasn't aware of this possible problem because the 2005 14BFF needed new spring perches anyway. Im guessing that you are trying to re use your existing spring perches so I would recommend taking some measurements. If you need measurements off of mine, I can get them tomorrow.
Chris
'63 k15 long step
Old 01-10-2016, 12:12 AM   #117
Dsuper5
Dsuper5's Avatar
Cool i found them, Thx a lot will make it easier i hope. Updates will be posted as available.
Old 01-24-2016, 12:37 PM   #118
jwalt2gfd
I was wondering what year of truck did you get the 63" springs from? I am just getting ready to start my 64 k10 build and I am looking at doing the same spring swap you just did. Great work and pics.
jwalt2gfd is offline   Reply With Quote
Old 01-24-2016, 05:57 PM   #119
'63GENIII
'63GENIII's Avatar
Pretty sure that they came off of an '07 Silverado 1500.
Chris
'63 k15 long step
Old 01-24-2016, 09:31 PM   #120
BigRed76
BigRed76's Avatar
I'm sure there are many variations, but GM started using the 63" springs in 88 on the GMT400 trucks.
Zach
Old 01-25-2016, 01:49 PM   #121
jwalt2gfd
One more question, what year truck had the 52" springs, are these rear springs or did chevy have a 52" front spring. If they are rears what spring rate did you go with. Thanks for the help.
Old 01-25-2016, 03:45 PM   #122
1972RedNeck
1972RedNeck's Avatar
Subscribed for future reference...
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-26-2016, 11:55 AM   #123
jwalt2gfd
1972redneck, what does that mean?
Old 01-26-2016, 12:02 PM   #124
jwalt2gfd
Hey 63genIII, is this a short or long bed truck?
Old 01-26-2016, 10:21 PM   #125
'63GENIII
'63GENIII's Avatar
Its a long step
Chris
'63 k15 long step
