Old 04-19-2017, 10:33 PM   #101
DPowers
DPowers's Avatar
Re: La Crosse- 1960 GMC Custom
That's interesting about the keys. Any way you can make the bezels more vintage looking to match the cluster?
DPowers is offline   Reply With Quote
Old 04-19-2017, 10:42 PM   #102
Classic v6 GMC's
Classic v6 GMC's's Avatar
The power steering line was to long and looked out of place so I shortened it and routed it down below the pump. Also installed the return line.
Then I ran the transmission lines. The lines where a little long but compression fittings fixed that.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 04-19-2017, 10:54 PM   #103
Classic v6 GMC's
I thought so to. Maybe I can paint the bezels a flat black or something. They are to to shiny for the rest of the dash.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 04-20-2017, 10:11 AM   #104
DPowers
DPowers's Avatar
Maybe battleship gray or a hammered paint?
Old 05-06-2017, 11:48 AM   #105
Blue666(2)
Originally Posted by Classic v6 GMC's View Post
Today I removed the old choke and throttle cables and put the plug back in the hole.
While I was under the dash I saw a key hanging in the heater duct. I got them out and one is for the truck and the other was for the gas cap.
They must have fallen down the defroster vent.
And here are some pics with the gauges that we installed on the weekend. Not sure if I will keep the chrome bezels/face plates.
Did you recess these into the lower dash? From the pictures, I can't see any wires or the back part of the gauge.
They might look better, with black trim rings, if you can fit them on either side of the speedo/fuel/water temp pod. This would be easier to see/read as you drive also. You can snap & print a picture of the new gauges & tape it in place to get a better idea.
Great build, Like what you have with the truck.
Blue666(2) is offline   Reply With Quote
Old 05-06-2017, 11:10 PM   #106
Classic v6 GMC's
Yes we recessed them into the lower dash were the cigarette lighter and throttle cable would go. I will probably remove the gauge face plates and that will probably make a big difference. I was saving the sides of the gauge pod for a tach and clock.
Thanks for the complements and ideas.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-10-2017, 09:56 PM   #107
Classic v6 GMC's
Well I have not posted in a while because we were busy working on the 67 c20. It's almost finished so I can turn the focus back to this truck.
Since the last time I posted we started up the motor and got it running good.
When we started it up we decided that we need to get rid of the fan(to dangerous with out a fan shroud) and bought two electric fans and a controller.
I installed the fans on Friday and just need to wire up the controller.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-10-2017, 11:28 PM   #108
TJ's Chevy
TJ's Chevy's Avatar
Dual cooling fans are nice, I'm doing one big single for my 66.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-11-2017, 07:27 PM   #109
Classic v6 GMC's
Yeah I would have gone with one big one but I got the two smaller ones for a better price. If I was thinking ahead I would have just bought the radiator with the fan and shroud.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-11-2017, 07:54 PM   #110
Classic v6 GMC's
Today we installed a 67-72 glass pack exhaust kit from LMC. It worked out good, just had to modify it for the headers and have to work on the rear track bar mount. Still need to install a few hangers.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-11-2017, 09:39 PM   #111
62stepside longbox
62stepside longbox's Avatar
Looks awesome! Are those rear ebrake cables new? If so where did you buy them? One of mine is seized up solid...
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 06-11-2017, 09:47 PM   #112
Classic v6 GMC's
They were replaced by the previous owner when he rebuilt the brakes so I am not sure where he got them.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-12-2017, 01:33 AM   #113
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
What A Beauty theres a 1960 GmC a few blocks away 2 old brothers and 1 sister told me that they were teanagers camping ang fishing in it and cant sell to ANYONE to many storys and Family Fun helped put on my jackstand and move under carport
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 06-12-2017, 07:26 PM   #114
Classic v6 GMC's
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 08-06-2017, 10:06 PM   #115
Classic v6 GMC's
Update
We are almost back on the road after 10 months!
I have not posted any updates in a couple months but we slowly finished the exhaust, welding up the rear axle and panhard bar, ran all the brake lines and finished up most of the wiring.
Today we finally started it up and let it run for a while.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 08-06-2017, 10:15 PM   #116
Classic v6 GMC's
Then we drove it around the yard and removed the camper shell. After looking at the truck for months we decided that the camper didn't fit the truck and it looks better with out it.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 08-07-2017, 12:22 AM   #117
Captainfab
60-66 Nut
I assume everything went well with the cam break in? Did those pusher fans keep the engine cool?
Old 08-07-2017, 12:53 AM   #118
TJ's Chevy
TJ's Chevy's Avatar
Cool man, glad you got to drive it a bit! Hope to see some footage soon!
Old 08-07-2017, 01:24 PM   #119
Classic v6 GMC's
Yes everything went well with the engine break in. The fans turned on around 185 degrees and the engine never went above 190-195.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 08-07-2017, 01:37 PM   #120
Classic v6 GMC's
Thanks TJ. I hope to get a video of it running and driving soon.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 10-01-2017, 07:11 PM   #121
DPowers
DPowers's Avatar
Any updates on La Crosse?
Old 10-01-2017, 07:22 PM   #122
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Jumping in to watch this build!
Looking great!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-01-2017, 08:54 PM   #123
Classic v6 GMC's
WOW! The last 2 months went fast with a road trip and other stuff.
About a month ago we bought a new Edelbrock 500 for it because the Holley was dumping to much fuel. The Edelbrock was an instant improvement and really helped the throttle response and reliability. It starts right up every time.
I will try and get a link to a video.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 10-01-2017, 09:07 PM   #124
Classic v6 GMC's
Not the best video. The electric fans are a little loud with the hood open.
https://drive.google.com/file/d/0BwJ...ew?usp=sharing
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 10-01-2017, 10:10 PM   #125
DPowers
DPowers's Avatar
Very nice.
