Old 09-09-2020, 12:19 PM   #101
bocephus79
bocephus79's Avatar
Re: Eric's 1966 Turbo 6.0 build
Originally Posted by 88Stanger View Post
Where did you get the seat?
Jeff
It's a Snowden Seat
bocephus79 is offline   Reply With Quote
Old 03-05-2021, 02:00 PM   #102
bocephus79
bocephus79's Avatar
I'm still here!! as usual carwash season dominated my life this year. Before winter I did get to drive it ( at least out of the shop and back inside)
Painting the hood now and putting the interior together.
The window glass frames are hitting the " whiskers" inside the door when I try to roll it up. I see that alot of people have this issue, but haven't found a solution yet.
Has anyone found the holy grail answer?
also has anyone used a good billet window crank/ door handle set from someone?
Old 03-05-2021, 02:35 PM   #103
SCOTI
SCOTI's Avatar
Getting closer!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-05-2021, 08:18 PM   #104
cwcarpenter98
cwcarpenter98's Avatar
Lookin good! On my truck, I just bent the flange back some on those felts. My truck hasn't been painted yet though, so I wasn't concerned about any fresh paint
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 03-05-2021, 11:58 PM   #105
bigmoe
bigmoe's Avatar
With my truck I pulled the glass out of the channels, squeezed the top of the channels together as much as possible to get the glass back in. I used windshield urethane to glue the channels back on and I also put some small spacers (1/16" - 1/8" or so) in the bottom of the channel so the glass didn't go in all the way. If you go to an autoglass shop near closing time you can get a part tube of urethane from them. They throw them out because they won't keep till the next day.
The truck is coming along nicely. Love that colour.
bigmoe is offline   Reply With Quote
Old 05-04-2021, 11:14 AM   #106
bocephus79
bocephus79's Avatar
BAck with an update:
Removed the glass and cleaned up the glass channels nd painted them.
I bought new felt strips from rubber the right way. They fit way better, but before installing I took the advice from this thread and " widened" the inner gap where they clip in. worked perfect.
Wood ready for poly, fenders on even has working taillights!
Old 05-04-2021, 11:30 AM   #107
bigmoe
bigmoe's Avatar
Nice door panels! Buy those somewhere or custom made?
Old 05-04-2021, 04:21 PM   #108
bocephus79
bocephus79's Avatar
TMI out of the brothers catalog. i think I got both on sale for $300 quality is " meh" but I'm picky
Old 05-04-2021, 04:40 PM   #109
roll_the_dice
roll_the_dice's Avatar
Wonder why I haven't seen this build? Great job...Looks awesome...you're in the home stretch now.
roll_the_dice is offline   Reply With Quote
Old 06-10-2021, 12:57 PM   #110
bocephus79
bocephus79's Avatar
So I've decided I'm taking this truck to a father's day car show come hell or high water. The jam session is on! Had my better half help get the bed wood in place. and test fit the grill
Old 06-10-2021, 10:56 PM   #111
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by bocephus79 View Post
Some Progress Updates. Most of the interior is done, at least the hard parts I wanted to do before the doors were installed.
the new door handles seem too " short" The actuator pin on the push button needs to be like 1/8 longer to make the latch open all the way.
As far as the bed wood kit from Mark-k goes..I wanted the bed on the truck so when I mock the wood up to drill the holes everything is perfect. Man was setting that thing on the frame stressful
Beautiful Blue.
66 C20 Service Truck:
Old 06-10-2021, 11:49 PM   #112
cwcarpenter98
The white grille and blue truck is a perfect combo
Christian Carpenter
Old 06-14-2021, 09:50 AM   #113
88Stanger
88Stanger's Avatar
nice job!!!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 06-17-2021, 11:09 PM   #114
bocephus79
bocephus79's Avatar
SO learned a few lessons from the headlight install:
New parts suck
Don't have new parts powdercoated assuming they will fit
J.W SPeaker lights are expensive.
I struggled for 2 days with the lights. I did have to open up the holes in the back buckets for them, but the main issue was with the adjusting bucket itself.
The tabs on the bucket that "align" the headlight in just didnt fit no matter what I did. Obviously made worse is the fact that the new LED bulbs are shaped a little different than the factory halogens.
Took my old grill apart to get the factory buckets, chopped the backs off them, sandblasted, painted and everything fits perfect. :shrugs:
Old 06-17-2021, 11:21 PM   #115
bocephus79
bocephus79's Avatar
5 days till car show. still have never driven the truck.
had to remove the transmission to fix an oil leak. When I put the engine together I tightened the rear cover first, then bolted the oil pan up. The rear cover hung down past the mating surface of the pan, a la leak city. Rookie move.
Problem: occasionally when moving the truck around the shop the torque converter would " lock" and either stall the engine or worse, try to drive through the brakes and into whatever it was that was in front of me.
since the trans was out I took it back to the builder and had him add a different valve in the pump. I guess its a common issue with 4l80e's and big billet converters.
https://www.summitracing.com/parts/sox-34200-14k
SO per usual the race is on.
Old 06-17-2021, 11:28 PM   #116
bocephus79
bocephus79's Avatar
At this point I was going to throw in the towel. Not only was my trans at the shop, but I had some major issues at the carwash that ate up 3 days and 3 late, late nights.
My 75 year old car guy neighbor who Invited me to the car show came to the shop with:
random stainless bolts
a bucket of detailing supplies
gatorade and beef jerky
He says " I've got nothing better to do and you seem like you need the help"
.......Damn, I hope I'm a cool old guy one day!!!!
Well I can't back out now!
Got the bed all snug and even did front and rear bumpers!!
Old 06-17-2021, 11:31 PM   #117
bocephus79
bocephus79's Avatar
Well, Got the trans back and installed.
(Language warning)
I'm sure the neighbors loved the first 3 miles put in on the truck after the full resto...
https://youtu.be/GZLx3ZKFq0g
Old 06-17-2021, 11:34 PM   #118
bocephus79
bocephus79's Avatar
Back where we started, taking the first drive to mom's house. Hood still needs wet sanded and buffed, tailgate was fighting me so it's not going on right now, and I just ordered some tires for these temporary wheels because they are dry rotted.
But I think I'm Driving this beast to the Father's day Car Show!!!!
Old 06-18-2021, 09:44 AM   #119
SCOTI
SCOTI's Avatar
Congrats on pushing through! We all can learn something from an old neighbor even better when they're helping us 'grow'. The fact that you acknowledge & appreciate what he did likely means you're likely to do the same for another. Kudos for that.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-28-2021, 11:24 AM   #120
bocephus79
bocephus79's Avatar
Made it to the show!
Old 06-28-2021, 12:01 PM   #121
joesscamaro
Nice job...that's got to be a good feeling!
joesscamaro is offline   Reply With Quote
Old 06-28-2021, 02:35 PM   #122
SCOTI
SCOTI's Avatar
Congrats for making the show!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-28-2021, 03:56 PM   #123
LostMy65
LostMy65's Avatar
A sense of accomplishment, I bet!
Old 06-28-2021, 04:35 PM   #124
88Stanger
88Stanger's Avatar
Awesome Job !!!
Old 07-08-2021, 04:45 PM   #125
bocephus79
bocephus79's Avatar
SOOO Many bugs to work out...But she's a runner
https://youtu.be/m0MvFuaZU5Q
