Old 01-23-2019, 07:19 AM   #101
roll_the_dice
roll_the_dice's Avatar
Re: 1965 LWB Stepside Build
Thanks Christian...I think they are slightly different...but I will double check.
roll_the_dice is offline   Reply With Quote
Old 01-23-2019, 08:33 PM   #102
roll_the_dice
Finally got the passenger side kick panel carpet out today along with the remaining grommets out of the firewall and the cab firewall insulation. The insulation was damp...it rained this morning. I also knew that the front window leaked some...it's on my list to redo the window gasket. Anyway, pulled all that out and found a decent amount of surface rust. It isn't soft, so that is good. I will get it wire wheeled and get some Por 15 or the like on it and go from there. All in all, I have been pleased with taking the truck apart and the lack of major rust.
Old 01-23-2019, 09:55 PM   #103
Johns 66
Johns 66's Avatar
Glad its not soft like mine was....
Johns 66 is offline   Reply With Quote
Old 01-23-2019, 10:51 PM   #104
cwcarpenter98
cwcarpenter98's Avatar
No problem man. My floor looks to be about the middle between solid and swiss cheese. Not pulling anything completely apart because ignorance is bliss
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-23-2019, 11:53 PM   #105
kdad
Doesn't look bad at all.. wire wheel and Por15... Good as new..
As I get back to my swiss cheese tomorrow../.LOL
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039
She may not be the prom queen but at least she puts out..
kdad is offline   Reply With Quote
Old 01-25-2019, 09:09 AM   #106
roll_the_dice
Thanks guys...your swiss cheese makes me feel better.
Got the passenger door sill out last night...truck is now bare inside minus steering column. Going to get my wire wheel out and do some work if it warms up...cold out there for this southern boy (30 degrees).
Ordering interior paint today... I will be using a 1965 corvette exterior color...silver pearl metallic. Will be interior and wheel color. I may paint the floor board too and just use a rubber mat like it came originally. Depends how "nice" I can get the floors to look. My original interior color looks like it was the silver fawn color.
Old 01-26-2019, 06:11 PM   #107
roll_the_dice
Bad news for this week... found my swiss cheese in the floor...both sides of the truck near the kick panel. In their infinite wisdom, the PO patched it with a license plate riveted to the bottom of the truck (covered in undercoating) and poured silicone on the cab floor to fill in the holes/cracks. I got all the silicone out and wire wheeled the metal.
I don't think I can afford to have a patch panel welded in right now...so I have to figure something else out. Maybe a temporary fiberglass fix along with the POR-15. I have seen some videos. I also have experience in fiberglass work. It will all be under the carpet anyway...I am putting feelers out for a welder among my friends.
I also got everything off the firewall today and sanded off the undercoating that was on the firewall. Will get the steering column out tomorrow. Should be ready to paint the firewall later this week.
Here are some of the pictures from this week's work.
Picture 1 is the rust, #2 is the silicone I pulled out on the passenger side!
The best picture to me is the steering wheel. I took off my old non OEM wheel and had to try this one out for looks. Got it from Johns 66. Thanks again John...It is going to look even more awesome after I restore it.
Old 01-26-2019, 06:19 PM   #108
roll_the_dice
Forgot to mention...in the circled jagged hole, the PO had the hydraulic clutch rod through it...held in, by a large balled up wad of...you guessed it...SILICONE! Maybe they had stock in silicone.
Old 01-26-2019, 08:07 PM   #109
Johns 66
Johns 66's Avatar
Well my friend Andy...makes me think of Shawshank Redemption ...lol
Im sorry you found swiss cheese too...It seems like its a pretty standard thing on these old trucks....Most likely from the heater core leaking antifreeze on it......But you can get it taken care of Im sure, yours is not as bad as mine was although mine was filled with Bondo and not silicone.....what some people thought was a repair is beyond me but then again never know what those who owned it were going through at the time.
But good news is it is starting to take shape!!!!! and this should be the worst part you find!!!!!!
Old 01-27-2019, 01:26 AM   #110
Captainfab
60-66 Nut
If you plan to fix the rust correctly at a later date, I would just clean the area the best you can, treat it with a rust converter, possibly a coat of paint and then rivet or screw a piece of sheet metal over the area. Treat and coat the sheet metal as well.
Old 01-27-2019, 11:43 AM   #111
roll_the_dice
Thanks John...that is a good idea. I would like to get it repaired correctly. My main concern of the fiberglass was repairing it down the road with this fix. I was planning on using POR-15 anyway...but I do like the idea of putting a piece of sheet metal over the top and treating that as well. Much easier to remove the rivets to get to the area than having to cut out the fiberglass work as well.
Now I have a better plan!
Old 01-27-2019, 11:47 AM   #112
roll_the_dice
I love that movie!
That's OK...I knew there had to be rust somewhere and now I am a proud member of the rust club. Hopefully I can get it repaired correctly this summer when I am planning on getting the doors repaired later this year. Just knock it all out at the same time.
Old 01-27-2019, 05:51 PM   #113
roll_the_dice
Didn't get much done today, but I did get the steering wheel column removed. While I wait on the POR-15, I am going to get the firewall painted (if it gets warm enough) and start blasting parts again for paint. I just ordered the paint to paint the inside of the cab. Once that is completed along with the floor repair, I will get the wiring harness in and start putting the truck back together... Getting closer!
Old 01-27-2019, 05:59 PM   #114
cwcarpenter98
Finding that swiss cheese sucks! The PO of my truck found some about 20 years ago and decided to do a repair similar to yours. After all these years, the rust still spread, I'm just ignoring it
Christian Carpenter
Old 01-28-2019, 04:01 PM   #115
roll_the_dice
While I wait on parts and POR-15...I thought I would prime the firewall today, this is the first coat...beautiful 60 degrees here. Since this isn't a show truck, I did not worry about getting all the undercoating off at the bend of the firewall. But It will look much better with the basecoat on later this week as well.
Old 01-28-2019, 04:14 PM   #116
straight6chevyguy
straight6chevyguy's Avatar
look'n good!
sorry about the rust but it doesn't look to bad.
Being the redneck I am I would just screw some sheet metal down and call it good.
Nothing like doing things right however.
Keep up the good work!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 01-28-2019, 04:21 PM   #117
roll_the_dice
Originally Posted by straight6chevyguy View Post
look'n good!
Thanks! I appreciate it.
I agree...I am going to put POR-15 on it and then screw or rivet some sheet metal over it and seal that also. When I have time and more money to put in the truck, I will get it repaired correctly. I don't ever plan on selling this truck, so I might not care or think about it once it is under carpet or floor mat.
Old 01-28-2019, 04:30 PM   #118
Johns 66
Johns 66's Avatar
Andy...this is gonna be SWEET, looks REALLY Good....Weather is so nice today......but supposed to snow tomorrow...…
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Old 01-28-2019, 04:35 PM   #119
roll_the_dice
Thanks John...not bad for a rattle can. No snow thank goodness here, but maybe some rain tomorrow afternoon.
Old 01-28-2019, 09:07 PM   #120
cwcarpenter98
Rattle can is best can I can't wait to see it with some color!
I'm hoping the threat of snow will cancel my 8 am accounting class tomorrow, but I doubt that will happen
Christian Carpenter
Old 01-28-2019, 09:29 PM   #121
roll_the_dice
Thanks Christian...I Can't wait to see color on it also.
Just talked to my son at UGA and he is hoping classes are cancelled also...and he is also taking an 8AM Accounting class. haha
Old 01-28-2019, 09:51 PM   #122
cwcarpenter98
Great minds think alike I think he has a better chance of getting some snow than I do
Christian Carpenter
Old 01-29-2019, 11:56 AM   #123
roll_the_dice
OK, got the firewall shot today with #503 light green which as I have said is the original color of the truck. I think it will be a nice pop of color against the mostly satin black engine bay. I am going to clean up the cowl section and shoot it in the same color (I think), so it will peek out from under the cowl. This color will darken some after I get clear on it, but will wait for that so I can do the cowl section at the same time along with the rest of the cab after I clean it up.
Again not perfect and I am not striving for perfect or I would not have painted it in my driveway.
Old 01-29-2019, 12:06 PM   #124
roll_the_dice
Just took the tape off...not bad, but now that I look at it, I think I am going to do the entire cowl section including the top just under the cowl, not just the windshield wiper section...here it is without the tarp and tape. Should be easier to paint that entire section also than just in the wiper section...thoughts?
Old 01-29-2019, 12:31 PM   #125
cwcarpenter98
I think it looks great! Even if you don't see the paint once it is all back together, you will know that it is there. I say go ahead and paint it
Christian Carpenter
