Old 05-22-2018, 08:58 PM   #101
mister.freeze
mister.freeze's Avatar
Re: Calling all 700R4 Experts!
Originally Posted by SeventyOne View Post
Really good stuff there. It will take me a while to get through it all.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 05-22-2018, 10:47 PM   #102
simicrintz
Very cool to see that it looks like you are on the right track to getting this properly addressed; good for you!!
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 05-23-2018, 09:30 AM   #103
made2drag
made2drag's Avatar
https://www.youtube.com/watch?v=uaPzcSFCr_E
You may be able to borrow this gauge from Autozone or Oriellys for free.
Line pressure test... run the hose through a hole in your firewall and check pressure while driving. I may do this myself. There is a chart floating around here somewhere to tell you what you should read. I'm still learning so if you already know this and it seems common sense, bare with me.
made2drag is offline   Reply With Quote
Old 05-23-2018, 09:43 AM   #104
made2drag
made2drag's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=169445
This link shows you pressures you should have. I would think that at 45 mph right before 4th is supposed to engage, you are suppose to have a min of 90-100 psi and a max of 190-230??? Again, im learning so do some reading....
Old 05-23-2018, 10:00 AM   #105
made2drag
made2drag's Avatar
https://www.youtube.com/watch?v=Av6Xh8Fwuy0
Real world test in all gears.....
Old 05-23-2018, 12:40 PM   #106
SeventyOne
Looking at the link to the cable you have: I've never seen a TV cable with the brass thing at the end.
There are 5 types of OE TV cables shown here
They are of varying lengths but again none have the brass thing. I think you have a Th350 kickdown installed. Google search image shows this, with brass thing.
Also I know you have the carb throttle corrector piece but do you have the cable bracket corrector?
https://www.ebay.com/itm/TH200C-2004...-/322530942176
SeventyOne is offline   Reply With Quote
Old 05-23-2018, 01:50 PM   #107
mister.freeze
This does have the brass thingy, and not the TH350 end.
Old 05-23-2018, 01:56 PM   #108
mister.freeze
Driving to work this morning, the trans didn’t shift into 4th. At one point, it felt ready to, so I gave the gas a quick whomp and into 4th it went. Went into 4th as it should after that. To me, that reinforces the sticky valve theory. Low pressure could also be the problem, I admit. I’ll try to find a port and see if I can borrow the gauge. Also, as stated before, it shifts better when cold, but won’t go into 4 until very warm.
Old 05-23-2018, 04:03 PM   #109
YoungPup1977
OUTTA here....
YoungPup1977 is offline   Reply With Quote
Old 05-23-2018, 05:12 PM   #110
made2drag
made2drag's Avatar
How far a drive is work?
Old 05-23-2018, 05:14 PM   #111
made2drag
made2drag's Avatar
Are you using Dextron 3?
Old 05-23-2018, 05:19 PM   #112
made2drag
made2drag's Avatar
You started having trouble after a fluid change so im wondering if the viscosity of the ATF has anything to do with it? When its warm its thinner and works, when cold its thicker and doesnt. I wonder if this effects pressure. I would also be driving 30 mins and checking the level often. Almost sounds a quart low to me. But im just thinking out loud
Old 05-23-2018, 05:20 PM   #113
made2drag
made2drag's Avatar
Originally Posted by YoungPup1977 View Post
You said this same thing back on post 53, so nothing has changed.....when you get the gauge what exactly are you looking for as far as pressure levels, can you list what you "should" see before you borrow a gauge.
Park =
Reverse =
Neutral =
Drive =
3rd =
2nd =
1st =
than list what you have after you get the gauge in each above mentioned gears....
I think the video in post #105 matches what a couple of links reference on pressure readings.
Old 05-23-2018, 05:24 PM   #114
made2drag
made2drag's Avatar
If you stomped on it and it went into 4th, doesn't that sound like the cable being too loose at normal throttle and when stretched a tad (while stomping on it) the pressure goes up enough to shift?
Old 05-23-2018, 05:26 PM   #115
made2drag
made2drag's Avatar
the port is on the drivers side and is also a port to measure trans temp. If I do my pressure tests, I might as well put a temp sensor in it when im done and run a temp guage.
Old 05-23-2018, 11:06 PM   #116
YoungPup1977
Now is this thread about your activities or is it for MR freeze...maybe you can add some fancy buttons to your dash too....just a thought... Have a great day folks !!!
Old 05-24-2018, 09:20 AM   #117
made2drag
made2drag's Avatar
Nope, but I was pointing out where to hook up a temp gauge......
Old 05-24-2018, 11:54 AM   #118
SeventyOne
I agree. Cable is wrong and brackets are wrong. nothings going to work right until those are addressed.
Old 05-24-2018, 04:06 PM   #119
YoungPup1977
Qq.............
Old 05-24-2018, 04:12 PM   #120
YoungPup1977
nope, but i was pointing out where to hook up a temp gauge......
qq............
Old 05-24-2018, 04:41 PM   #121
YoungPup1977
Qq...........
Old 05-24-2018, 05:26 PM   #122
SeventyOne
Step 1: get correct cable and brackets.
Step 2: check pressure with gauge.
Step 3: drive and adjust TV cable tension as needed for shift point.
Step 4: stop talking about this.
Old 05-24-2018, 05:31 PM   #123
YoungPup1977
LOL!!!!! I think the buttons on the dash are not aligned.... no wait, its the fluid, to thick of fluid...it works when its hot...gots to be the fluid...and its exactly a quart low.....
Old 05-24-2018, 05:43 PM   #124
SeventyOne
Actually wait lol
Step 1: replace 700r4 with Th350.
Step 2: talk about why the kickdown cable is wrong.
Step 3: turn K5 into flintstone-style foot propelled truck.
Old 05-24-2018, 05:56 PM   #125
YoungPup1977
I think the answer was in post #100, I copied and pasted this from post 100 below....
"Wow. Well... for starters, the short piece of shroud that actuallu goes in to the transmission is bigger than the “correct” cable, meaning the hile is bigger and the cable won’t seal. "
the hole is bigger and the cable wont seal.......I would love to see a pic of the cable bolted to the transmission......really sounds like a T350 cable bolted to the 700R4....not even sure it can be done, but .........
the T350 cable is smaller in diameter at the trans than a 700r4 TV cable is...thats why the "HOLE IS BIGGER AND THE CABLE WON"T SEAL "
DOES YOUR TRANS LEAK ?
LOL!!!!!!!!!
