Old 06-20-2020, 12:26 AM   #101
59chev
59chev's Avatar
Re: The Vandal. 1957 "Big glass" 3100 restomod.
Beautiful! What brand of paint did you use?
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 06-20-2020, 08:40 AM   #102
Jason 56
Coming along nice. It’s going to look killer!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 06-20-2020, 10:41 AM   #103
BIGglaSS
BIGglaSS's Avatar
Southern Polyurethanes. (SPI)
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 06-22-2020, 08:31 PM   #104
slammed57
slammed57's Avatar
looks nice!! how many coats did you end with and which spray gun?
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 06-24-2020, 04:32 PM   #105
BIGglaSS
BIGglaSS's Avatar
4 coats with Tekna ProLite 1.4 tip. It sprays nothing like epoxy or primer. I moved too fast, causing lots of orange peel on the first couple coats. Slowed down for the last coat, and it filled in the peel. After I get the inside done, I'll test the cut and buff. If that doesn't get out the peel, then I'll sand with 800 and shoot 3 more.
Old 07-23-2020, 01:45 AM   #106
BIGglaSS
BIGglaSS's Avatar
Inside is painted.
Old 07-23-2020, 09:19 AM   #107
oldman3
oldman3's Avatar
Looks great...Jim
oldman3 is offline   Reply With Quote
Old 07-23-2020, 10:11 AM   #108
Rickysnickers
Wow, great!!!
Old 07-23-2020, 10:17 AM   #109
joedoh
joedoh's Avatar
classy!
is that one of those 15" impala wheels?
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 11-02-2020, 10:06 PM   #110
BIGglaSS
BIGglaSS's Avatar
Originally Posted by Rickysnickers View Post
Wow, great!!!
Thanks, neighbor... I'm also in Eagle.
classy!
Yes, it is.
Old 11-02-2020, 10:06 PM   #111
BIGglaSS
BIGglaSS's Avatar
Old 11-03-2020, 09:40 AM   #112
youngrodder
youngrodder's Avatar
I really like your color combo...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-04-2020, 10:49 AM   #113
slammed57
slammed57's Avatar
looks great bud!
My 57 current build
Old 11-04-2020, 11:24 AM   #114
Rickysnickers
Old 11-07-2020, 11:29 AM   #115
BIGglaSS
BIGglaSS's Avatar
Update on painting. Short story, I switched to black base & clear coat, and re-painted the cab. I can't form an opinion on which is better. Base/clear, or single stage. I think the clear makes the black deeper and darker. Overall, I fought with dirt, dust and lint, and hope it will all cut/buff out. Everything from the cab forward is done, I haven't even unboxed the bed and fenders yet. Meanwhile, I will focus on getting it running before cut/buff and put the fenders on.
Radiator, and transmission plumbed. Serpentine belt installed.
Old 11-07-2020, 04:52 PM   #116
Rickysnickers
Looks nice!!
Old 11-08-2020, 12:25 AM   #117
oldman3
oldman3's Avatar
Sweet...Jim
Old 01-06-2021, 05:01 PM   #118
slammed57
slammed57's Avatar
Any updates? quick question. which did you find easier to spray , single stage? bc/cc? Iam guessin you went with spi clear, which one to you go with and and was it to buff. still torn over hear on ss or bc/cc
My 57 current build
Old 01-09-2021, 05:40 PM   #119
BIGglaSS
BIGglaSS's Avatar
Slammed57, No updates. I had a little time before christmas to work on this mess.
I used SPI black base, and SPI universal clear.
For the long story version... When I did the single stage, there were some areas of heavy orange peel that removed too much material to sand out. I broke through to the primer. I called SPI and had a long conversation. He said I would have to respray vs. spotting in and blending the single stage. The rough areas were due to me (f'n novice) not getting the gun close enough. After a long conversation , his opinion is that base/clear is a better choice for novices. Therefore, I decided to start over with base/clear. Some of the reasons being that you can repair and denib the base coat until it is perfect. Black base is blacker due to the higher pigment load.
Neither way is easier. I could not keep the dust and trash out of any coat. Therefore, there are a lot of imperfections. My overall opinion, universal clear was easier to spray than single stage. To get enough coverage to sand it out, I hammered on 5 coats. To my eye, base clear is blacker and has more depth with a 'wet' look, which I prefer. So far I have only cut and buff the cowl panel. Time consuming, but buffed easy. 1000-1500-2000-2500, trizact 3000-8000, sonax cutmax, sonax polish. It is a lot of steps!
Either way, it is a LOT of work, and I'm considering sending the bed out for paint instead of doing it myself. To get back to SS vs. base/clear, IF I ever do it again, I will still do base/clear. I like the way it looks better than single stage. Hope this helps...
Old 01-09-2021, 07:28 PM   #120
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Just finished going through the thread... nice work!
I sent mine to the shop in 2013 where they got all the body and chassis work done and it's been in storage until last fall.
Our end products are going to close to twins...
Hoping to get it on the road in the spring.
Ken
87Lowrider is offline   Reply With Quote
Old 01-10-2021, 05:31 PM   #121
slammed57
slammed57's Avatar
I appreciate it, just keep at it , little by little. Dont you just love electrical? Iam being sarcastic of course.
My 57 current build
Old 01-18-2021, 01:19 AM   #122
BIGglaSS
BIGglaSS's Avatar
Slammed, I will admit this project broke my spirit for building cars. I have lost all motivation. I'm at the point that I just want this thing out of my garage, and out of my life. Once the engine fires and lets some smoke out of the tires, I may change my mind. Hopefully soon!
Old 01-18-2021, 09:11 AM   #123
gigamanx
Say it ain't so! Just think of all the arm chair mechanics who wish they were as far along as you in driving and enjoying your hard work. If you've lost faith, walk away from it for a bit until the build-bug hits you again. I've had to do that a few times and find some other outlet for a few weekends before jumping back into things.
Enjoy the journey!
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 01-18-2021, 11:15 AM   #124
Rickysnickers
You've already done a lot of the hard work. Don't quit now, the end is on the horizon. Just take a step back and leave it for a bit, then come back refreshed and start again.
Old 01-18-2021, 04:06 PM   #125
_Ogre
_Ogre's Avatar
life happens, understand your thoughts, truk took 8 years due to a lot of walking away
paint looks awesome, mirror finish
shop air compressor timer
