Old 01-17-2021, 01:42 AM   #101
SCOTI
SCOTI's Avatar
Re: Anyone can buy an SWB...
Originally Posted by Inverter View Post
I spend a lot of time visualizing and mentally planning but I still just figured it out as I go along. I think most of the builders here do something similar,, you can never have all the answers ahead of time. Im not sure why I do this work. Considering its Not a necessity and my work is only a hobby. I am obsessive about the aesthetics of most things and have a Love of the innards of custom or heavily modified chassis. the culture of chassis fab has shaped me over the years I guess..
This is my latest work. Its my 98 Im rebuilding. SFBD w/ C/O’s, tri-3 Link.
2x4 1/8” wall & 1.5 round tube.
Dude.... Nice! Lotta work right there!
I've been doing some tweaks to my OBS '99 CC SWB as well. Definitely not to your extent but a little lower than it was w/some fresh steering gear.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-17-2021, 01:53 AM   #102
Inverter
Inverter's Avatar
Thanks. I tried to sell the 98, almost couldn't give it away... I still have feelings for it so I disassembled it and said F it, I try something diff.
They just have great lines. Im going to raise the fender arches and run my 30+” tires with a 5” ride height.
These pics are better. I work on it a little each day.
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 01-17-2021, 02:43 AM   #103
SCOTI
SCOTI's Avatar
I'm leaving well enough alone on mine. Bolt-on static drop w/some tweaks for reinforcement & corrections. Still kicked my old-arse. Crawling around on parking-lot concrete doing the work/mods was rough. I was definitely feeling my age on this one.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-17-2021, 02:50 AM   #104
Inverter
Inverter's Avatar
Ha.. my knees dont like it when I squat for too long. What tweeks are you doin and what is the correction for?
TROY
Old 01-17-2021, 04:55 AM   #105
tucktuck
tucktuck's Avatar
Yea. getting closer though. The point where all 4 panels meet on each side(door,fender,cowl,hood) wasnt designed to fit well or tight. Its a process to figure out where to cut and move being that every move of one panel affects the remaining 3 panel gaps. Im well vested in this truck so its getting finished I forecast about spring time or so. Stayin on it, I wont disappoint.
Can't wait to see it...
I've been wanting to build one of these for years and finally picked one up a couple months ago. It's already down to the frame and starting to stockpile parts and strip the body down to bare metal.
I don't think it will be anything as crazy as yours, but you never know. It is a sickness, but I'm cool with it.
Too many great ideas on this build threads that lead you down a rabbit hole.
tucktuck is offline   Reply With Quote
Old 01-17-2021, 05:19 AM   #106
Inverter
Inverter's Avatar
Yep. It can get out of hand.
Ive done it a few times. I would suggest not to get carried away buying parts ahead of time. Usually it takes years to finish a complete build. You likely will change your mind on some things and could get stuck with unwanted parts.
One stage at a time. Start with chassis (frame/suspension/brakes), drivetrain (rear end), plumbing (brake/fuel lines), motor & trans, exhaust, body, in that order. Only buy parts for the stage you are in. This way you can have good access to your work without barriers like Laying out exhaust or mounting a motor/trans with the cab/body in the way.
Be careful, eye protection n such. Enjoy the journey.
TROY
Old 01-17-2021, 02:04 PM   #107
SCOTI
SCOTI's Avatar
Reinforcement for the c-notches & shock angle correction for the pass side shock.....
http://67-72chevytrucks.com/vboard/s...d.php?t=816847
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-08-2021, 11:36 AM   #108
tucktuck
tucktuck's Avatar
This is what I have been doing for the most part, some things I went ahead and bought that are hard to find etc...
Please tell me that this isn't still in lockdown...
Old 10-08-2021, 12:34 PM   #109
YellowK5
Active Member
Impressive work....Why buy what you can make!
YellowK5 is offline   Reply With Quote
Old 10-09-2021, 12:21 AM   #110
Gregski
Post Whore
Gregski's Avatar
Mad Skillz
Gregski is offline   Reply With Quote
Old 10-09-2021, 12:56 AM   #111
Warrens69GMC
Warrens69GMC's Avatar
You did all that work to make it a lowered shortbed? Congratulations?
Sorry, I liked it better as a longbed.
Old 10-09-2021, 10:14 AM   #112
SCOTI
SCOTI's Avatar
And we're ok w/you guys. Nothing wrong w/long beds if thats your thing. '"All that work" was a wee bit more than just going from a LWB to SWB.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
