10-25-2014, 12:26 PM | #1251 |
Re: What did you do to your truck today? Chapter II
10-25-2014, 12:51 PM | #1252 |
Took a drive this morning. Grounded something out and got some smoke in the cab. Found my main battery ground had vibrated off and grounded the chassis while the engine continued to run. These trucks give us opportunities to be patient. Love that old truck!
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
10-25-2014, 12:59 PM | #1253 |
10-25-2014, 02:47 PM | #1254 |
Thanks OD, picked up the March serpentine set up used from a forum member who switched to one with a/c which I'm sure I'll be doing in a year or two.
10-25-2014, 04:58 PM | #1255 |
10-25-2014, 08:28 PM | #1256 |
OD they are nice but the price isn't so nice lol.
10-25-2014, 08:46 PM | #1257 |
10-25-2014, 08:53 PM | #1258 |
So true, so true lol
10-25-2014, 10:30 PM | #1259 |
Started straightening and stripping the grill for my 67. Have some more work to do but getting there.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
10-25-2014, 11:05 PM | #1260 |
Well I finally found the vacuum leak in the ol 68. It's the carb base cracked/broken at the bolt ear. Anyone know where to find a Rochester monojet 7029014 model?
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
10-26-2014, 12:13 AM | #1261 |
I live in Clarkston Wa, and Wife and I made a trip to Moses Lake Wa (160miles) today to get a complete great condition Cab for our 67 chevy took the drive on and off tilt deck snowmobile trailer and Lynn owner had a sweet new smaller tractor He had the cab lifted up on the forks and tilted back ready for us so I could see under the cab, All cab supports are all Rust Free and only a small few rust thru holes on the RH side kickpanel to floor Was really impressed.
It had the original owners manual and factory inspection sheet in the jockey box him and I both found all guage cluster there, stock radio in the dash, ignition switch w/key in the dash, Jockbox insert intack, complete cig lighter, descent seat windshield descent, had all good condition cab mounts and all hardward bolts intact good condition floormat not going to use cause my truck has good carpet but was just neat, all heater box there etc.. I told him I was using this cab for a Jig type foundation so I can chop the top on this cab and doors and fix any rust if it had any and I have almost No rust to repair so I could again chop the top and get all prepped and ready on body work, glass and rubbers fit, all custom work done to this cab with out having to teardown or fix all the rust on my truck cab. I went to pull and save in Spokane and they and spalding auto parts wanted $250 for a top and $50 each for doors so I could have the extra parts to chop the cab on my truck now, Wow way to much money. I got this cab and he thru in an extra set of doors and a top he had already cut off a truck he scrapped and a few more goodies All for $250 and I don`t have to touch my truck now I can keep it intact and get the running gear in tact and improve driveability and everything there mocked up and tested before it comes time to tear it down and shorten the frame and the LWB I and going to shorting the longbox down to a SWB now paying the money for a shortbox kit I`ll do it my self I have extensive Fabrication skills Cant wait to get the cab stripped down blasted and go from there. Got all my CPP shock relocation brackets in today and going to order ubolts and drop blocks to bring the back down a couple more inchs. Wildcard Last edited by Wildcard; 10-26-2014 at 12:19 AM. |
10-26-2014, 01:35 AM | #1262 |
I replaced the front drum shoes, repacked the wheel bearings & replaced both front shocks. I replaced the belts & installed a new alternator. Next I sprayed on that Rust-Oleum® truck bed coating lining on the inside of the bed before I replaced the wood this week.
"Now all I need is a shop to go with my shop vac!" |
10-26-2014, 01:40 AM | #1263 | |
what did it cost ya for the wood kit? and where is the best priced place to get it, I`m shortening the LWBed box down to a SWB Wildcard |
10-26-2014, 12:49 PM | #1264 | |
10-26-2014, 04:29 PM | #1265 |
I installed a universal windshield washer pump where the TSC (transmission spark contol) relays used to be. Not the prettiest job, but it works now!
-Jeff |
10-26-2014, 08:12 PM | #1266 |
i got something done this weekend.now i gotta finish the caps
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
10-26-2014, 08:14 PM | #1267 |
Replacement Monojet Carby
It depends on how much $ you have to spend .
Rock Auto.com has *very* good rebuilds in the *exact* original part number , most over the countercarbys mix and match parts willy nilly , I don't like that . I have also found that E-Bay will yield you a N.O.S. , rebuilt or cheap used one if your patient . Cheap like $15 delivered to your door , you'll have to clean it up etc. but if you're after the correct ' Just So ' one like your clean truck deserves , that's the way to go .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
10-26-2014, 09:25 PM | #1268 |
trying to finish up my 3/4 to 1/2 ton conversion. I added a hydro-boost system and put a prop valve on from a 93 truck to wrap up the disc conversion.
10-27-2014, 12:34 AM | #1269 |
Did an oil change and a burnout. Just keeping the old girl going.
1972 Chevrolet swb fleet side. - SOLD 2018 Toyota Tacoma but hunting for another C10 Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303 Instagram: https://www.instagram.com/72c10shortbox/?hl=en |
10-28-2014, 12:19 AM | #1270 |
got the truck up on the lift this evening at work to grease all the new frontend parts, had it aligned Friday.
Here is a pic or two of the Cab I got in Moses Lake, got extra pair of doors and and extra top for free so got what I need for extra parts when I start chopping the top 4inchs. had good dash panel, jockey box and the stock AM radio was still in the dash, had original Owners manual and dealership inspection paper still in the Jockey box, pretty cool. We went to and got back from Moses Lake Saturday and Sunday morning I went out and completely stripped All the parts out of the Cab and gonna check on havin it sandblasted or rent me a portable trailer type compressor and portable sandblaster, I did this when I built my 28` Model A chopped, channeled Ford Coupe I still have. Wildcard |
10-28-2014, 12:30 AM | #1271 |
here are a couple more of the Cab I got, came with complete matching doors and like mentioned before another pair of doors and extra top.
I ordered 10inch ubolts last night so I can complete the shock relocation bracket install along with I`m making a 2inch drop block for the rear also. Wildcard |
10-30-2014, 02:31 AM | #1272 |
I installed a cowl screen today to keep all the dang leaves out of my cab via thru the vents. I used some screen door mesh that I had laying around & I hot glued it to the back side of the cowl. It wasn't the easiest thing to do, the screen kept wanting to roll up on me before the hot glue set up, but it was by far cheaper than ordering one thru a vendor.
10-30-2014, 06:50 AM | #1273 |
What brand DynoBoost did you install?
1970 C10 Short Stepper with 71/72 front clip. |
10-30-2014, 08:03 AM | #1274 | |
10-30-2014, 08:05 AM | #1275 | |
Prophylactic Measure
This is a very good idea and should be done to all our trucks , the collected leaves rusted out and destroyed my other wise perfect low mileage , good original paint cab .
-Nate Quote:
