05-06-2021, 09:35 AM | #1251 |
Re: What did you do to your truck today part IV
Went out for the maiden voyage last night.[ATTACH][/ATTACH]
05-06-2021, 09:37 AM | #1252 |
Guest
Posts: n/a
That's a beauty!
05-06-2021, 09:44 AM | #1253 |
Congrats! Beautiful truck...love the color.
05-07-2021, 05:31 PM | #1254 |
Finally adjusted my passenger side door so my wife doesn't have to slam it anymore...
05-07-2021, 05:33 PM | #1255 | |
05-07-2021, 09:24 PM | #1256 | |
Guest
Posts: n/a
Replaced my rusty reverse lights, and connected them up...to a switch, don't have it setup on my shifter yet. Had to keep the old lenses, new ones looked far too clean on my old POS. Of course, this is largely for those behind me to GTF out of the way, 'cause I can't see a damn thing back there. |
05-09-2021, 12:57 PM | #1257 |
Supposed to be GM light green #503 but it didn't quite turn out when mixed, even though the mixed sample was dead on... A little bit lighter and less blue than factory. I can live with it.
05-09-2021, 09:01 PM | #1258 |
Right hand rocker and cab corner done over the weekend
05-09-2021, 09:23 PM | #1259 |
Looks killer Andy!!!!!
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
05-10-2021, 07:20 PM | #1260 |
Started prep for a re-paint. Wow, the damage a set of bed hooks can do. I never addressed these properly the last time I painted it 10 years ago, but hopefully this time it wont be waving at me after I shoot the gloss to it.
05-10-2021, 07:35 PM | #1261 | |
Guest
Posts: n/a
05-10-2021, 07:56 PM | #1262 |
05-17-2021, 10:09 PM | #1263 |
But Found Her 25yrs Later!
I don't remember why I took it off, but beings we're coming into summer, I put the 60-62 fan shroud back on.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 05-17-2021 at 10:15 PM. |
05-19-2021, 12:36 PM | #1264 |
Guest
Posts: n/a
Bored at work...rattle-can primer flames, just for laughs.
05-19-2021, 08:51 PM | #1265 |
You've got skills.
Primer red oxide?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
05-19-2021, 09:00 PM | #1266 |
Guest
Posts: n/a
05-20-2021, 02:49 PM | #1267 |
Guest
Posts: n/a
Largely finished the install of Dual Electric Fans this morning. I found a fan set that mostly fit, but I still needed to fab up a mount for it. Of course I thought of a better way after it's all installed, but that's how it goes...will change it later, works fine for now.
05-20-2021, 02:59 PM | #1268 | |
05-20-2021, 03:16 PM | #1269 |
Guest
Posts: n/a
Summit Racing SUM-G4852 - Summit Racing® High Output Electric Fans
Electric Fan, Black, Plastic, Dual, 11 in. Diameter, Puller, 2,760 cfm, Each Summit Racing SUM-890114 - Electric Fan Thermostat Kit Dual Fan Control, Non-Adjustable, 185 Degrees On/170 Degrees Off, Kit I went with duals incase I ever install AC, I can dedicate one fan to the AC. |
05-20-2021, 04:02 PM | #1270 | |
05-21-2021, 12:36 PM | #1271 |
Guest
Posts: n/a
05-21-2021, 01:40 PM | #1272 |
Those look great. Post a pic of the engine when you get them on.
05-21-2021, 02:09 PM | #1273 |
Guest
Posts: n/a
05-23-2021, 06:37 PM | #1274 |
It has been over 10 years, cost too much money, and took gobs of time.
It is finally near completion and I actually drove it today. Just a few small items left to do. |
05-23-2021, 06:39 PM | #1275 |
Congrats...looks great!
