Old 03-28-2015, 07:32 PM   #1301
cnorth
cnorth's Avatar
Re: Restoring Rusty
WOW you are really a jack of all trades kinda guy, good to see some more progress
cnorth is offline   Reply With Quote
Old 03-28-2015, 10:11 PM   #1302
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by greg64 View Post
Could you get the front edge properly with it hanging in that orientation? I would have thought it would be easier to spin it 180 degrees.
Originally I had it hanging the other way, but the bungee cords kept rubbing against the front lip, so I flipped it upside down, I had to lay on my back on the ground and shoot the front of the hood that way, the entire operation was a major PIA I also had to squeez in on the sides to paint the sides of it
Gregski is offline   Reply With Quote
Old 03-28-2015, 11:05 PM   #1303
greg64
greg64's Avatar
Re: Restoring Rusty
Aaah, that makes sense. Well hey, you got it done!
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-29-2015, 02:47 PM   #1304
rusty76
rusty76's Avatar
Re: Restoring Rusty
Looks good man. I can't wait to see how the hood turns out. My hood is bent so bad it looks like a "U". Almost but not all the way...lol.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-29-2015, 07:35 PM   #1305
jb3t
Re: Restoring Rusty
Hope you don't get bugs in the paint. Should have draped mosquito netting over the ole swing set.
jb3t is offline   Reply With Quote
Old 03-29-2015, 08:23 PM   #1306
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Ha, only one gnat landed on it, unlike the tailgate which I shot on the grass, that was a fly trap for sure, LOL
Old 03-29-2015, 08:26 PM   #1307
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Maybe this will give you an idea, here's how it all went down
I will share some more pics once it's on the truck and out of the garage
Old 03-29-2015, 08:36 PM   #1308
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
not sure you guys seen my other thread called Truck Won't Start No Sounds No Noises Nothing it's what has been keeping me busy and sleepless the last few days and nights
anywho since it deals with the ignition I will share some pics of me tearing up the steering column area so we can see what lurks beneath
Old 03-29-2015, 08:46 PM   #1309
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Ignition Switch
couple more shots of the ignition switch itself
on mine not all the blades are used, I'm sure yours will differ
Old 03-30-2015, 05:13 PM   #1310
rusty76
rusty76's Avatar
Re: Restoring Rusty
Could this been the problem with your truck not wanting to start the first go around? Little electrics are a pain in the butt aren't they.
My build thread
Crossmembers CC
Old 03-30-2015, 07:05 PM   #1311
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Actually no sir, the switch is fine, I was able to get the truck to turn over by manipulating it with a flat screw driver, you know sliding that black slider back and forth to simulate key movement
I think a broken Ignition Lock Cylinder is more like the culprit as the end part has broken into three pieces, it is that part that pushes on a metal rod which runs down the steering column down to the actual ignition switch, it's how they did back in the day, when Mechanical Solutions ruled the world
Old 03-30-2015, 08:38 PM   #1312
Titomars
Titomars's Avatar
Re: Restoring Rusty
In your photo you are missing the outer case to that cylinder. It is still in the column I am assuming.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 03-30-2015, 09:18 PM   #1313
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Damn you're good
Old 03-30-2015, 09:35 PM   #1314
Titomars
Titomars's Avatar
Re: Restoring Rusty
Damn you're good
Looks like you got it all now.
Old 03-30-2015, 10:38 PM   #1315
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
Hood turned out nice!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-30-2015, 11:02 PM   #1316
JacobSchni
JacobSchni's Avatar
Re: Restoring Rusty
did the lock cylinder fix the problem? otherwise it could be a broken ignition rack or that plastic gear. (little more down the column)
JacobSchni is offline   Reply With Quote
Old 03-31-2015, 12:29 AM   #1317
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Thank you
Old 03-31-2015, 12:32 AM   #1318
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
good point, the cylinder was the big problem, but the gear was missing a tooth too, so I had to order one, once it comes in in a couple of days I can reassembly the whole thing, I do yap about it in that other Truck Won't Start No Sounds No Noises Nothing thread
here's a pic of that sector gear with one tooth missing
Old 03-31-2015, 12:54 AM   #1319
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
Oh my goodness.
Chaplain is offline   Reply With Quote
Old 03-31-2015, 01:00 AM   #1320
Titomars
Titomars's Avatar
Re: Restoring Rusty
The sector gear probably took a hit from the lock cylinder falling apart. The parts got to go somewhere and plastic generally loses to metal
By the way the hood turned out great!
Old 03-31-2015, 02:01 AM   #1321
JacobSchni
JacobSchni's Avatar
Re: Restoring Rusty
for anyone wanting to see a in depth view of the steering column being taken apart:
http://forum.73-87chevytrucks.com/sm...?topic=12525.0
Old 03-31-2015, 02:19 AM   #1322
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
True
and thank you
Old 03-31-2015, 02:26 AM   #1323
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
found this page on the interwebs that explains what each wire does on the turn signal switch wiring harness ie the non ignition switch wires that run up the steering column
this isn't the exact part / plug match but the wires seem identical, so it might could help somebody out, I know it beats the wiring schematics for me anyways
white - stop lamp switch (what is that?)
green - right rear turn signal
yellow - left rear turn signal
purple - turn flasher (what is that?)
brown - hazard flasher
dark blue - right front turn signal
light blue - left front turn signal
black - horn
Old 03-31-2015, 02:40 AM   #1324
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
this shows what the pins on the ignition switch are, mine doesn't use all of them but the ones that it uses match
Old 03-31-2015, 02:47 AM   #1325
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Diagram of the two plugs the white one and the black one that plug in to the ignition switch and what they do
WHITE CONNECTOR
Pink - Start & Run (connect this to the ignition) ... Pink is ignition, pink is ignition, pink...
Purple - Start (connect this to the starter solenoid)... Purple is starter, purple is starter...
Red - This is the Battery connection bringing power into the switch. Red is usually power, red...
Brown - Accessory & Run (Accessories....)
BLACK CONNECTOR
Orange - Run (connect this to power anything in the Run state) I also have a Dark Brown / White Stripe wire going here, not sure what it's for
Light Brown / Black Stripe - Start position switches this lead to ground
