Old 09-29-2017, 08:51 PM   #1301
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 85 GMC Sierra "Scarlett"
Originally Posted by 82streetshow View Post
coming along nicely, I should be right behind you
Originally Posted by rustytruck50 View Post
Looks great! Enjoy watching the progress!
Originally Posted by SCOTI View Post
Tick tock..... You guys are cutting it close 🤤
Thanks guys. As always Scot no matter how we try it ends up being last minute
Originally Posted by moregrip View Post
Looks fantastic! Are the rear shocks upside down?
Actually they are on correct. For some reason the stickers are on wrong. Problem reported and resolved.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
"Refining Sierra"
Old 09-30-2017, 09:35 AM   #1302
mywifestruck
Looks awesome
mywifestruck is offline   Reply With Quote
Old 10-02-2017, 09:07 AM   #1303
N2TRUX
Happy to be here
N2TRUX's Avatar
As many of you know, we did make it to Goodguys Lonestar Nationals in Ft Worth to be in the RideTech booth. Of course it was a down to the wire thrash, so allow me to share.
With the rear finished we moved back to the front. One last trip to FedEx had netted the final package with some key components for the front install.
Ridetech provides a template to cut the required holes in the crossmember for the coil over shocks to go through but I really wanted to install the mounting brackets first.
I bolted the bracket in place, and as I suspected the holes I had drilled to remove the rivets were off.
I used the RideTech bracket as a guide to align and drill the holes on center. With that done and bolts installed I scribbed inside the hole to get my cut Mark.
Articles-
"Refining Sierra"
Old 10-02-2017, 09:21 AM   #1304
N2TRUX
Happy to be here
N2TRUX's Avatar
There are several ways to make the cut required in the crossmember. The easiest would be with a plasma cutter. I did not have one available so I reverted to plan B and C. I followed the scribbed line with my cut off wheel and considered using it to make the cut.
I soon realized my tool and compressor would have made this a long process so I traced the line deep enough to use as a guide. I tried my sawsall but the width of the blade wouldn't allow tight enough turns so I changed tools again.
I have an air powered jig saw that's compact and cuts well. I used the most aggressive blade I had and slowly made the cut.
It was time consuming, but much cleaner than the sawsall. I dressed the cut with various flapper discs to ensure no stress point would develop.
***Note the 7/16" x3" bolts that are used to install the upper A arms are pushed in to a hex shaped pocket on the back of the bracket. DO NOT use washers on the head of these bolts.
Articles-
"Refining Sierra"
Old 10-02-2017, 09:25 AM   #1305
1957 Chief
Proud Vet that loves the USA
Originally Posted by N2TRUX View Post
There are several ways to make the cut required in the crossmember. The easiest would be with a plasma cutter. I did not have one available so I reverted to plan B and C. I followed the scribbed line with my cut off wheel and considered using it to make the cut. I
Totally agree with you Ken. There is just no good way, besides a plasma cutter to get in there.
I used a jigsaw with a think metal blade as well.
Bubba
1957 Chief is offline   Reply With Quote
Old 10-02-2017, 10:13 AM   #1306
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by 1957 Chief View Post
Totally agree with you Ken. There is just no good way, besides a plasma cutter to get in there. I used a jigsaw with a think metal blade as well.Bubba
Bubba I had looked at the template and considered using a 4.5" hole saw. I actually bought one to use. I calcualted the time it would have taken to cut a small piece of wood or sheetmetal to bolt in place to allow for a pilot hole for the hole saw to use as a guide. I still "think" it would have worked, but time was too valuable at this point and I went straight to the tried and true method.
Articles-
"Refining Sierra"
Old 10-02-2017, 11:23 AM   #1307
82streetshow
I was without a plasma cutter as well. i went the hard route, took the whole crossmember out and took it somewhere that did, powdercoated it, then reinstalled
82streetshow is offline   Reply With Quote
Old 10-02-2017, 01:10 PM   #1308
N2TRUX
Happy to be here
N2TRUX's Avatar
I was without a plasma cutter as well. I went the hard route, took the whole crossmember out and took it somewhere that did, powdercoated it, then reinstalled
I actually considered this myself. You are at the point where its only a few more bolts to drop the entire crossmember. I even have a spare crossmember that made it that much more enticing. In the end, it was a time factor. What could I do in the least amount of time to obtain results that were acceptable to my self proclaimed level of quality.
Articles-
"Refining Sierra"
Old 10-02-2017, 02:01 PM   #1309
UKNOWME
UKNOWME's Avatar
So let’s see the final stance with the coilovers? Does it sit any lower than before? Any chance to drive it yet to give a review on the ride?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 10-02-2017, 02:28 PM   #1310
N2TRUX
Happy to be here
N2TRUX's Avatar
Unfortunately I'm not ready to answer yet. We set the coil overs up with an additional 1" preload above -0-. Ironically this gave as an increase in height of 1" from where I was before we started. On the trailer going to FT Worth she settled a 1/2" . We drove her off the trailer and in to the show. With no adjustment on the shocks, and no front end alignment she didnt feel very good. I will elaborate more on the next updates.
Articles-
"Refining Sierra"
Old 10-02-2017, 03:41 PM   #1311
UKNOWME
UKNOWME's Avatar
Ok thanks!
1964 Chevy c10
Old 10-02-2017, 06:01 PM   #1312
82streetshow
does the rear sway bar brackets weld to diff housing?
Old 10-03-2017, 09:26 AM   #1313
N2TRUX
Happy to be here
N2TRUX's Avatar
Ok thanks!
My pleasure. I promise to give an insightful review once I have enough data.
Yes, the only part of this kit that does require welding are the lower mounting points for the rear sway bar. I removed the lower shock mounts attached to the axle for aesthetics, but that is not required.
Articles-
"Refining Sierra"
Old 10-03-2017, 10:34 AM   #1314
N2TRUX
Happy to be here
N2TRUX's Avatar
With the upper mounting bracket secured in place I was able to start hanging parts. The upper ball joints are bolted to the upper A Arms. The A arms are stamped with a D & P for obvious reasons. Even though they look the same, especially late at night, they must be mounted on the correct side.
With the upper arms in place you can move to the lower A arms. Fortunately the lower ball joints come pressed in place. The factory U bolts are used to mount the lower arms. I bead blasted them to clean up the old threads, then gave them a coat of satin black.
I found that the bolts had spread wide and didnt want to fit back in the holes properly. I installed the nuts to protect the threads then gave them a few whacks with a hammer till they fit properly. Also note that the lower arms have a guide pin to align them. Be sure that seated properly while installing the arms.
Articles-
"Refining Sierra"
Old 10-03-2017, 01:14 PM   #1315
JohnJ@RideTech
JohnJ@RideTech's Avatar
Looking good Ken!
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 10-03-2017, 03:44 PM   #1316
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by JohnJ@RideTech View Post
Looking good Ken!
Thanks buddy.
Articles-
"Refining Sierra"
Old 10-03-2017, 04:25 PM   #1317
Chaplain
Chaplain's Avatar
Thumbs up...
Chaplain is offline   Reply With Quote
Old 10-03-2017, 08:55 PM   #1318
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Chaplain View Post
Thumbs up...
Articles-
"Refining Sierra"
Old 10-03-2017, 09:12 PM   #1319
N2TRUX
Happy to be here
N2TRUX's Avatar
Chase at RideTech opted to include the new CPP Modular 73-87 C10 2.5" drop spindle upgrade to accommodate the Wilwood D52 calipers that I had previously installed. These spindles are designed to be used with the factory 12" HD rotors and bearings.
I bolted done the adapter bracket that was provided, and mounted the spindles in place. Since Chris was available to help hold things in place, we skipped to the front sway bar. RideTech has updated the Musclebar to a new design. We mounted the end links loosely and slid the bar in place. One end of the bushing clamps lines up with a factory hole and the other needs to be drilled. We tightened everything down and called it a night.
The the new MuscleBar requires a shorter version of the factory bushing stands. This kit is a beta version and did not include the stands. Notice that the end links are at an aggressive angle with everything in place and at full droop. We "assumed" that would correct itself when set on the ground. We all know what assuming does.
Articles-
"Refining Sierra"
Old 10-03-2017, 09:14 PM   #1320
N2TRUX
Happy to be here
N2TRUX's Avatar
The next morning I finished up the brake install. The recently replaced bearing were repacked, and fresh grease seals were added to ensure that there was no issue with the new spindle. With everything well lubed it was cinched down tight.
With the rotors in place I wiped them down with brake clean to remove any grease residue and installed the Wilwood calipers. They were tightened to specs and the stainless brake lines were routed clear of any obstructions.
Articles-
"Refining Sierra"
Old 10-03-2017, 09:30 PM   #1321
85/Silverado
85/Silverado's Avatar
I hate it when there's a echo.
85/Silverado is offline   Reply With Quote
Old 10-03-2017, 09:36 PM   #1322
1957 Chief
HAHA I was thinking the same.
Ken, on the last photo, looks like the spindle is laid way back. Is that just the way the camera was held? And looks sexy my friend!
Bubba
Old 10-03-2017, 09:50 PM   #1323
N2TRUX
Happy to be here
N2TRUX's Avatar
Bubba
Y'all caught me in the middle of editing, hence the "echo" post.
Bubba I believe what your seeing is an improper angle dues to the upper A arms being installed backwards. Well, technically not "backwards" just mounted on the wrong side. I discovered this as I was in the process of triple checking all of my work. Laying on my back in the middle of the night, totally exhausted, I wondered why the angles looked all wrong. Thats when I noticed the big D stamped in the passenger side upper arm.
To tired to do it again and take fresh pics, I resolved the issue the next morning.
Articles-
"Refining Sierra"
Old 10-03-2017, 09:53 PM   #1324
1957 Chief
Yes sir, were quick on the trigger. Glad you squared that up. And yes late nights and no sleep can easily make certain "minute" tasks a chore.
Looks sweet tho! Anxious to get details on your ride height and adjustments.
Bubba
Old 10-04-2017, 08:05 AM   #1325
N2TRUX
Happy to be here
N2TRUX's Avatar
Wednesday night ran in to Thursday morning rather quickly. I was out of time and had to make some executive decisions. I still had not installed the optional front frame braces, or the rear sway bar lower mounts.
I had to repair the rear brake line, adjust the coil overs, install the bed and bolt the wheels on or she wasn't going anywhere.
We decided that the damaged brake line took precedence. Unfortunately it fought me with three trips to different auto parts before finally getting a new line and correct fittings to work.
With the clock ticking we bled and tested the brake repair and deemed it done. I called my neighbor for help and we got the bed in place.
Once more we looked the system over and bolted the wheels back on. She was ready to set on the ground with no time left to install the frame braces. She was as done as she was going to get and still make our deadline to be in Ft. Worth as I had promised.
Articles-
"Refining Sierra"
