Old 06-11-2009, 07:49 AM   #1326
70 Suburban
Rods
Re: My 1965 build thread
Hmmm maybe you should add that to your list.... He he he
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 06-11-2009, 09:30 AM   #1327
daverod
SSN 706
daverod's Avatar
I feel for you Allan. That sucks If I was you I'd blame it all on Strodder. Now go find some different headers and get that truck running.
daverod is offline   Reply With Quote
Old 06-11-2009, 04:13 PM   #1328
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Here ya go Alan, this is the only pic I have with the headers on. I'll get some more next when I'm at my parents!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 06-12-2009, 11:29 AM   #1329
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I have no one to blame except for myself.
Thanks for the pic ruff. Hopefully my headers will sell soon so I can get some other ones.
Alan's Classic is offline   Reply With Quote
Old 06-12-2009, 01:05 PM   #1330
protrash64
Resistance is Futile
protrash64's Avatar
That sucks about the headers, Alan. It will come together.
I have a suggestion for ya, if you get the chance. For us DIY body workers, how do you clean up your spreaders? Or do you just pitch them? I'm also interested in how you deal with your waste products such as sanding dust and the gun cleaner/mineral spirits/thinner that you use. Its probably second nature to you, but I need some ideas as Im setting up my space to be able to spray. Thanx and keep up the good work.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-12-2009, 01:33 PM   #1331
70 Suburban
Rods
Not sure what he does but i let the spent solvent evaporate. Same with the left over paint and primer. Epa says if its a slolid i can throw it in the trash. But i also use the 3m cups so i just set them out and throw them away. Dust goes in the trash. Epa states you can spray 12 cubic feet a day without a booth. As for the spreaders well peel it off just as the filler gets hard.. Leave a layer of it on the spreader and that makes it ez to peel
Old 06-12-2009, 04:00 PM   #1332
protrash64
protrash64's Avatar
Thanx for the info 70; the 3M cups are the mixing cups? for ratio?
Old 06-12-2009, 04:56 PM   #1333
70 Suburban
Rods
no Im sorry i was refering to the pps mixing cups. I mix spray and throw them away. for me I find them to save alot of time and thinner. I mix the paint in them then spray then let the cup sit and when the paint is dry I toss it out
Old 06-12-2009, 07:52 PM   #1334
scotts62
One day...
scotts62's Avatar
^^ See im a cheap arse and id rather clean them up than buy a .59 cup because its over 20 miles to where i get them
Scott
93 crew cab build
Project 62
Old 06-12-2009, 08:17 PM   #1335
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
OKC doesnt have any hardware stores??
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 06-12-2009, 08:18 PM   #1336
70 Suburban
Rods
from okc?? dont you have sherwin williams.. they sell them. tasco color. car quest... ?? I thnk oriles sels them too well you can order them. I dot it because its less mess and clean up. I dont have to mix it in a cup Im going to toss then pour it into a cup I have to use solvent to clean. so i guess im green.. lol
Old 06-12-2009, 08:40 PM   #1337
tiggamonsta
tiggamonsta's Avatar
When my dad first opened his shop he would set is excess liquids in the disposable aluminum pans you get at the grocery store. Then he would set it in an open air covered area to evaporate/harden. He did this for a couple years until his shop started to grow.
tiggamonsta is offline   Reply With Quote
Old 06-12-2009, 09:06 PM   #1338
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
these are like the headers i have but mine are 1 5/8 not 1 3/4
and mine have 3 in collector these have 3 1/2 collector
i want some of these but in ahc coatingheaders
Gage
Old 06-12-2009, 09:12 PM   #1339
Alan's Classic
I keep telling myself it will come together someday........I just hope I'm still able to drive any enjoy it. Read on about my answer to your other question.
That's some good info on EPA. I don't spray much at home only what I have too. I also use the PPS cups. They are the best thing since sliced bread. Once the product dries up in the PPS liner I just toss it. As far as solvent I just let my waste evaporate in a oil drain pan. I've probably only used a gallon of thinner in 2 years at home. PPS cups save alot of thinner. I'll reuse my spreaders until I can't use them any more. I just use thinner on a rag and wipe them off. Or just leave it to harden and peel it off.
Have you used the PPS liners yet?
Liners are cheaper than cups IMO. They also have the graduated liner that goes in the PPS cup (not liner) to measure by. It goes between the cup and the liner. It's pretty slick.
Another good idea.
Old 06-12-2009, 09:14 PM   #1340
Alan's Classic
Thanks for the link Gage.
Old 06-12-2009, 09:40 PM   #1341
protrash64
protrash64's Avatar
Thanx for the tips guys. I shoulda figured that there were liners available, Ive used them in paint trays for house painting projects for the same reason.
Old 06-12-2009, 09:47 PM   #1342
Alan's Classic
Just had to share a little of what I do at work. This along with any hard side hit sucks. Power sliding doors makes even harder. Thank goodness this one is manual. I don't have any before pics with me, but this is where it's at today. I have already replaced the suspension. The wheel was drove in and back.
And this is what I get to put in. They don't sell these pieces seperately like most cars.
Old 06-12-2009, 09:48 PM   #1343
scotts62
One day...
scotts62's Avatar
Originally Posted by Alan's Classic View Post
[COLOR="Blue"]
No i haven't yet. i want to because it makes everything so much easier to just mix the paint put a lid on it and spray. I s that what you are using? Where is the best place to get it? I have seen them in Auto body tool mart.
ps, sorry for all the questions
Scott
93 crew cab build
Project 62
Old 06-12-2009, 09:51 PM   #1344
scotts62
One day...
scotts62's Avatar
Thats cool, I liked the bodyshop i worked at and the kind of work but there were too many babies there that whined about everything and they basically starved me out and i went back to wrenching on semis.. and paint on the side
Scott
93 crew cab build
Project 62
Old 06-12-2009, 09:55 PM   #1345
protrash64
protrash64's Avatar
I'll stop whining about sanding on my warped bedsides now
Old 06-12-2009, 09:57 PM   #1346
Alan's Classic
If you don't know already you will have to get an adapter for your specific model gun to use the PPS system. I have been using them for 6-7 years (when they demonstrated at our shop). If you don't have a good connection with a paint supplier I don't know where the best place to get them would be. I ordered a case (100/ct) 2 years ago and just used my 50th one. You ask how do you know you used the 50th one. No.....I'm not counting them, they come in 2 sleeves of 50/ea. I have seen them in Autobody toolmart also.
Don't worry about the questions that's what we are here for to help each other.
Old 06-12-2009, 10:11 PM   #1347
scotts62
One day...
scotts62's Avatar
I wasn't referring to you man just the shop i worked at. I whine about doing it too but like it.. does that make sense..
[/QUOTE]
Yeah i knew about the adapter for the gun, im going to have to get some of them and check it out.
Your good at posting and and then being offline.. are you being sneaky and hiding under the radar??
Scott
93 crew cab build
Project 62
Old 06-12-2009, 10:18 PM   #1348
Alan's Classic
Clear as mud JK
Ancient chinese secret.
Old 06-12-2009, 10:27 PM   #1349
Alan's Classic
Along with all my other projects going on I'm also trying to do a step by step on how to rebuild vent windows. I've got one disassymbled. Now I need to clean and paint the frame and order some glass. Here is one pic of the progress.
Old 06-12-2009, 10:57 PM   #1350
70 Suburban
Rods
Here is the setup
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
