10-25-2013, 08:18 PM | #1326 |
Re: 1968
I finshed one of my side jobs today. The PO of this home got it repo and he got mad and went in the attic and cut all the elect wires to the breaker box.He cut wires all over the house in the attic also. So I rewired the elect breaker box and replaced all the wires. So now only two more fires to put out. Then I am back working on my truck.
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
10-25-2013, 08:21 PM | #1327 |
Re: 1968
Sounds like you are making some nice play money over there George if you keep that up it won't take you long to finish the truck.
10-26-2013, 05:16 PM | #1328 |
Re: 1968
yea the money is here but the time is what is killing me.
10-26-2013, 05:24 PM | #1329 |
Re: 1968
Today I ordere some parts from speedway.
wiring harness 20 circut 18 fuses 1/4,3/8,1/2,3/4 red slit wire looms dimmer switch dimmer switch pig tail also order a backing plate for my mirrow that goes in the door 2 stepside tail light lens. 3 universal joints for the driveshaft next week I should have my dash cluster and my edelbrook performer intake. also I am droppin off my pieces to the hood. The welding shop will break me 2 pieces of 22 gage metal 36 inch long for the nose of my hood. I am getting real close to having my truck back on the road. or at least a lot of parts to work on when I have the time.
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper Last edited by gdavis; 10-26-2013 at 05:30 PM. |
10-29-2013, 12:56 PM | #1330 |
Re: 1968
no parts came in yet. Except the three u joints. I will be glad when I can spend some time on the old girl. I will be instaling the first counter top Thursday, then the other three next monday. maybe I can take break for a week or so.
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper Last edited by gdavis; 10-30-2013 at 10:14 PM. |
11-01-2013, 09:23 PM | #1331 |
Re: 1968
Tomorrow, I will post pictures of the drive shaft. I am going to install the new u-joints and install it in the truck. I need to buy some Kubuta orange for the body of the truck. Tractor supply is my only ave. Then I can start doing some real damage (work)to the truck.
11-02-2013, 02:25 PM | #1332 |
Re: 1968
That's good, George! Sorry I missed you when I came through. They changed my work schedule, and it was the middle of the night when I came through. Looks like I will be making trips down there more often, though, so we will hook up soon!
=MATTHEW 69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
11-02-2013, 06:33 PM | #1333 |
Re: 1968
no problem man
11-02-2013, 06:49 PM | #1334 |
Re: 1968
Today I receved my Edelbrock performer intake. It looks sweet. Now I need the right gasket for the intake. Also got 3 u joints and carrier bearing. But I have a problem. I don't have the bracket that attaches to the cross member to install the carrier bearing. It was a one piece drive shaft from GM. But now it is two piece.
picture of intake picture of u joints and carrie bearing pictures of drive shaft rebuilt. I have to re-paint the driveshaft. stratched it up a little
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper Last edited by gdavis; 11-05-2013 at 08:02 PM. |
11-03-2013, 07:55 PM | #1335 |
Re: 1968
I found the bracket for the carrier bearing. So it looks like I will be installing the drive shaft soon.
11-03-2013, 08:00 PM | #1336 |
Re: 1968
I'm glad to hear it George, what's up next on the punch list?
11-04-2013, 07:11 PM | #1337 |
Re: 1968
Drive shaft installed
Hood metal welded on the front of the hood weld in the backing plates for the mirrows done both doors Intake mounted waiting for proper gaskets Valve covers waiting for intake installed Re-attach the parking brake cable to rear cable done ordering new chrome alt 80 amp and installing it no big deal this item
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper Last edited by gdavis; 11-05-2013 at 08:05 PM. |
11-04-2013, 07:20 PM | #1338 |
Re: 1968
Today, I got some parts in. not to many but a few.
6 emblems I order a while back. mirrow backing plate now I have both of them. I am waiting for the rear turn signal lens. Going to drop off the template for the brackets to be cut out of alunium 3/8 x 2 1/2 stock
11-05-2013, 07:56 PM | #1339 |
Re: 1968
Today, I welded the backing plates for the door mirrows. I also re-attached the parking brake cable. Waiting for the carrier bearing bracket to arive so I can install the drive shaft. Maybe I will get to go to the welding shop tomorrow to order the metal for the hood and the rear turn signal mounting plates.
11-05-2013, 11:38 PM | #1340 |
Re: 1968
George you should see if your buddy has a nicer hood you can start with so you dont have to fix that one, if he doesn't have one hoods are usually pretty inexpensive you should be able to find a good one locally.
11-06-2013, 11:40 PM | #1341 |
Re: 1968
He only has one 67/68 and he is going to use it.
11-06-2013, 11:54 PM | #1342 |
Re: 1968
Today, I had several parts that came in.
valve cover gaskets part number 7201 Edelbrock intake gaskets for the Edelbrock valve covers 2 sets of 6'' valve cover hold downs chrome Edelbrock oil filer chrome with boetie on it that fits on the Edelbrock valve cover wing boetie nut that fits on the chrome air filter 8 stanless bolts and washes for the vave covers 67/68 rear tail light lens I order dash cluster 2 step down push and pull door locks polish alunium 2 chrome sun visor clips polish alunium I am getting to my limit again for this month
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper Last edited by gdavis; 11-07-2013 at 07:39 PM. |
11-07-2013, 01:29 AM | #1343 |
Re: 1968
Good deal George.
That's everything you need to get it running right? |
11-07-2013, 07:24 PM | #1344 |
Re: 1968
yea it should be. I am working on the carpet now.
11-07-2013, 07:40 PM | #1345 |
Re: 1968
I picked up some stanless bolts and washer today. Going to use them on the engine compartment. They look a lot nicer than regular bolts. I also got some red wire looms for the distributor wires.
I ordered a black carpet today also. It came from another board member. He bought it for his truck, but changed his direction. I got it for a song. Couldn't pass it up. It is still in the box with pading. so it looks like the carb will have to wait till next mont. I need the carpet before I need the carb.
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper Last edited by gdavis; 11-07-2013 at 09:57 PM. |
11-08-2013, 06:24 PM | #1346 |
Re: 1968
tail light lens came in today and the chrome therostat housing. Going down south tomorrow. There is a guy that is selling a lot of parts so we shall see.
11-09-2013, 12:35 PM | #1347 |
Straight jacket required
Re: 1968
Great work, subscribed!!!
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." |
11-09-2013, 10:47 PM | #1348 |
Re: 1968
Went south and tried to buy some parts today But didnt make a deal so I came back with only a door panel trim. But I did meet a very nice guy down in Tarpon Springs, Fl. He drives a 1970 fleet side long wheel base 10 and it looks real nice. We talked for almost an hour.
So the trip was not a total loss.
11-09-2013, 10:49 PM | #1349 |
Re: 1968
Thanks for stopping by and seeing my build. I still have a long way to go. But it is only time.
11-09-2013, 11:56 PM | #1350 |
Re: 1968
very nice work great work ethic....subscribed
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
