Old 06-13-2009, 12:31 AM   #1351
protrash64
Resistance is Futile
protrash64's Avatar
Re: My 1965 build thread
[quote=scotts62;3357084] I wasn't referring to you man just the shop i worked at. I whine about doing it too but like it.. does that make sense..
I know you weren't, I couldn't believe the van Alan had pictured. I dont mind doing it either but my elbows disagree. How long 'til elbow replacement surgery...
[QUOTE=Alan's Classic;3357112]Along with all my other projects going on I'm also trying to do a step by step on how to rebuild vent windows. I've got one disassymbled. Now I need to clean and paint the frame and order some glass. Here is one pic of the progress.
I'm following this because I will be doing this in the next couple months
Originally Posted by 70 Suburban View Post
Here is the setup
70 Sub sprays with one hand and surfs with other....wow!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-13-2009, 01:06 AM   #1352
70 Suburban
Rods
its mad skills. that how I learned to spray left handed. ohh and I can switch hands and never let off the trigger or slow down.....lol
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 06-13-2009, 01:08 AM   #1353
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Originally Posted by protrash64 View Post
I'll stop whining about sanding on my warped bedsides now
warped bedsides that sounds familiar
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 06-13-2009, 01:10 AM   #1354
70 Suburban
Rods
lol i have not made it to the bed yet. I still dread the hood. I have a couple of oil can spots.. well one on each side the size of texas
Old 06-13-2009, 12:39 PM   #1355
scotts62
One day...
scotts62's Avatar
Yeah im going to have to order some and try em out.
Scott
93 crew cab build
Project 62
Old 06-13-2009, 11:04 PM   #1356
70 Suburban
Rods
i think you will be hooked. but you have to buy the adapter for your gun. so ether know what you have or what you need. for the sata I had to buy 2. one for the twist lock and one threaded
Old 06-14-2009, 01:09 AM   #1357
scotts62
One day...
scotts62's Avatar
I have the Develbliss threaded, ill check it out from Auto body tool mart.
Scott
93 crew cab build
Project 62
Old 06-15-2009, 05:35 PM   #1358
shortbed70
shortbed70's Avatar
I am going to be getting some from eastwood catalog they have the starter kit for 99.00 and I think it would help using gravity feed while spraying cab roof and underside of fender lips. Glad to see the trucks coming along alan.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 06-15-2009, 06:16 PM   #1359
SeanPaintsFlames
SeanPaintsFlames's Avatar
I use those PPS liners at the shop, too. What I do, though, instead of letting the paint dry in the cup -'cause that can take forever with base coat- is to pour it in an empty gallon can, then throw the emptied cup away. I use the same gallon can to dispose of left over clear, sealer. primer, and base, so it all dries together. I throw about 5 gallons away a year. THis way, you don't have a bunch of cups crowding your table top like this:
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 06-15-2009, 08:21 PM   #1360
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I don't think it has been mentioned yet, but you can spray with the PPS upside down if you want. When you first load it turn it upside down and pull the trigger. It sucks all of the air out of the liner and creates a vacumn so no mater how you hold the gun you will have a constant flow of paint.
Alan's Classic is offline   Reply With Quote
Old 06-15-2009, 08:27 PM   #1361
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I may have to invest in this, beause when I was spraying my dp90 on my frame my hands were coated in it from spraying almost upsidedown
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 06-15-2009, 09:38 PM   #1362
scotts62
One day...
scotts62's Avatar
Yep SOLD! I will order them
Scott
93 crew cab build
Project 62
Old 06-15-2009, 09:51 PM   #1363
70 Suburban
Rods
lol good call. the only thing is.. not that it matters for the home use. but they dont give ehough caps for the cups. If you use them in a shaker save the caps.
Old 06-15-2009, 09:57 PM   #1364
Alan's Classic
Old 06-15-2009, 10:12 PM   #1365
70 Suburban
Rods
I use a roll of tape on my shaker. I have phumatiic one fromt habor freight. works great.
Old 06-15-2009, 10:24 PM   #1366
Strodder
Daring to be Different
Strodder's Avatar
Man, I'm gone for 4 days and you guys are talking about me...... I didn't do anything.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 06-16-2009, 11:46 PM   #1367
Alan's Classic
Yeah, you weren't here to defend yourself
Old 06-17-2009, 07:29 AM   #1368
scotts62
One day...
scotts62's Avatar
Yep fair game
Scott
93 crew cab build
Project 62
Old 06-17-2009, 07:58 AM   #1369
4dranch
Shloooooong bed member #2
4dranch's Avatar
Sorry Alan..................
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 06-17-2009, 11:10 AM   #1370
Strodder
Strodder's Avatar
Like that would have stopped them.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 06-19-2009, 12:17 AM   #1371
Alan's Classic
I was wondering when you were going to throw that up.
Your right it doesn't matter if your here or not.
I wish I could post some progress. Not much to speak of. Shannon needed to order some parts from Jegs so I went ahead and ordered some fittings and SS hose for my power steering.
Mike's 64 Short Step told me about a 64 in the July Custom classic Trucks that had a 59 Impala dash in it. Did anyone else see it?
Old 06-19-2009, 12:55 AM   #1372
ruffrida2005
I was going to tell you about that, I was a nice looking truck, I just got mine in the mail the other day and thought about you. It really fit in the truck. I wonder if he's a board memeber!
Paul
Old 06-20-2009, 12:02 AM   #1373
Alan's Classic
I doubt he is a member. if he was I think we would know about it.
I sold a 2 wheel dolly the other day and have been looking for a lift for quite sometime. I found this one today. It's a year old but has never been used. Drove south of Atlanta to pick it up. I got it for less than 1/2 the price new. Now my dilemma is should I use it at home or at work. I'd diffenately use it more at work, but I want it at home too. I might set it up at home and clean it up and make sure it works. Dennis is gonna cringe since I didn't get a 2 post lift.
Old 06-20-2009, 08:40 AM   #1374
Strodder
Strodder's Avatar
Nice find Allan. Those lifts come in handy. Especially with body work, and brake work. You will still be wanting a regular lift though, for under car work. Don't get me wrong, I'm not knocking it, or you for getting it.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 06-20-2009, 07:46 PM   #1375
4dranch
4dranch's Avatar
Alan,
I agree with Dennis, That lift is not what you need get rid of it and let me know when you do.....and where you put it...
Nice score and I'm sure you will figure where she will most be used at...
David,
Daughters 66 truck:
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
