09-22-2020, 10:05 AM | #1376 |
Re: 53 Surburban "Family Truckster"
I haven't pulled the trigger yet but I'm strongly considering these.
I plan to powder coat them fully to de-bling them. That's where my head is at currently. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
09-22-2020, 03:55 PM | #1377 |
Those would look really good.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
09-30-2020, 04:25 PM | #1378 | |
10-01-2020, 09:25 AM | #1379 | |
Marc
10-16-2020, 08:14 AM | #1380 |
I have been putting in time on Coopers OBS Blazer so I have not been working on my the Suburban. Plus I'm still waiting on my buddy to glue my block back together. I did go out last night to work on it a little. it is funny how you have a plan when you are constantly working on something. Step away for a bit and you loose track of what's next....
One aspect of my last build that I was not fond of was the wiring (which I was responsible for). That truck had SO MANY circuits. I figured a little better preplanning will go a long way. I installed a removeable panel to mount most of the circuit boards to. I drilled a hole and inserted a grommet for a wire pass thru. I also ran out at lunch an grabbed a small section of SS 1.5" tube to complete my cooling hoses. I will paint it satin black at some point. For the lower hose I was able to use a 1.75" - 1.5" 90 degree elbow. It worked great. Thank you Marc
10-16-2020, 10:32 PM | #1381 |
Looking good...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
10-17-2020, 09:01 PM | #1382 |
I worked on finishing up my gas tank vent. I purchased the vent off eBay. I had to build a small bracket to attach to an existing bolt from my Porterbuilt set up.
I like how it turned out, tucked up and out of the way. Marc
10-17-2020, 11:32 PM | #1383 |
Post Whore
Nice vent Marc ...do you have a link to it?...I've got one for mine but I'm not liking it..
10-18-2020, 08:40 AM | #1384 |
The vent looks good. Much better than the PVC one I built.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
10-18-2020, 02:00 PM | #1385 | |
Thanks Jim
https://www.ebay.com/itm/Holley-Perf...53.m1438.l2649 Thank you. I'm picky. I looked at a bunch of different ones before buying his one. Marc
10-18-2020, 02:17 PM | #1386 |
I worked on my AC condenser. You ever notice that when you move one thing, three things down the line then need to be modified. This is where we are at with mounting the condenser. Since I pushed my radiator forward for more clearance with the front of the engine my brackets that held the condenser and dryer would no longer fit.
I added to horizontal supports. I installed nutserts to bolt the condenser to. I also chopped up the Vintage Air brackets so I could repurpose it to mount the dryer to my modified core support. It all turned out great. A little touch up paint and we are in business. Thanks Marc
10-19-2020, 10:24 AM | #1387 |
Post Whore
Thanks Marc..!...for the link..
10-19-2020, 11:46 AM | #1388 |
I enjoy seeing your work, very nice and clean.
Keep it going, and thanks for sharing
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
10-21-2020, 10:12 AM | #1389 | |
Marc
11-03-2020, 09:51 AM | #1390 |
My fabricator friends made it over on Sunday to glue the broken starter tab back on the block. He ordered some special rod and it worked great on this repair. It had lower melting point so we didn't need to heat the area so much. I'm purposely not grinding the welds smooth as I want as much material as possible. I think the repair turned out great (all things considered)
Last night I re-tapped the starter bolt threads, installed the new starter, hooked up a bunch of misc. wires and pulled the plugs. I cycled the motor without any plugs to push the gas out of the #7 cylinder which caused the hydro lock. Gas shot across the garage. I was not prepared for that. Now I know why they say make sure you have no power going to the coils as it could easily cause a fire. Later this week I will attempt to test fire the motor (again) Marc
11-03-2020, 09:55 AM | #1391 |
Post Whore
that shooting gas is what got my coworkers truck burnt to the ground...glad you didn't have any sparks...
11-03-2020, 10:13 AM | #1392 |
Marc, repair looks great, hope next start will fire right up and run...Jim
11-03-2020, 10:13 AM | #1393 |
nice repair, a coat of paint and no one will ever know.
11-03-2020, 10:22 AM | #1394 | ||
Marc Quote:
Thank you... Marc
11-04-2020, 01:13 AM | #1395 |
Hi Marc. Really like your build.
Just wanted to make a comment about the hydro lock in your engine. Check your oil before you fire it up. I had that happen to me years ago while I was at work one day. Forgot to switch off electric fuel pump. Pulled the plugs and cranked the engine and gas shot out the #7 cylinder also. What I want to say is that enough gas had gotten past the rings and drained into the oil pan. It was an hour drive home so I had to get new oil and filter and change it in the parking lot at work. Made for a long day. Your oil might be ok but I would check for gas before starting. Earl
You have to have patiences or you'll be one. |
11-04-2020, 10:07 AM | #1396 | |
Thanks Marc
11-06-2020, 10:07 AM | #1397 | |
Test fire #2 coming this weekend. Marc
11-06-2020, 10:21 AM | #1398 |
Post Whore
Good luck..!!
11-06-2020, 11:28 AM | #1399 |
11-08-2020, 10:32 PM | #1400 |
I wish I had a successful test fire to report.....but I don't. I'm closer. It sounds like it wants to fire off but something is not quote right. Not sure what the deal is. I will trouble shoot and I will call BP Automotive tomorrow to make sure I have it wired correctly....
I did make some progress on a design for a tranny cover. I didn't need a really tall one but it needed to be wide enough to mount my custom shift boot billet trim ring to. I will powder coated or paint the trim ring satin black at some point. I'm happy how it turned out. I started with a paper board template. Then I transferred to metal and bent it up (by hand). I just need to bend the top to match the radius of the sides and welded it up. This piece will be bolted to the floor and firewall. I will body work and paint this the satin color that my interior is painted. I figured it would be different than most plus it will aid in laying the carpet as I wont have to go up and over this cover.. Marc
