08-25-2021, 07:38 PM | #1426 |
Re: Facebook Marketplace finds
I owned a 64 Vette that a PO had used a folded over metal Folgers coffee can lid to replace a missing/busted inner fender bonding strip. My only regret about that car was not saving that coffee can lid.
1971 SWB step side: Original NM Forestry and then NM Fire truck |
08-25-2021, 07:57 PM | #1427 |
https://www.facebook.com/marketplace...Anull%7D%22%7D $600. My note: How do you not put this item up on a couple of sawhorses & pix the bottom half of each fender?
08-25-2021, 08:36 PM | #1428 |
I have a 1971 C10 runs and drives great, with factory 396 BBC, built with aluminum heads and hydraulic roller cam. Has a true 450hp built th400 with shift kit motor and trans are original to truck. Factory air cab,lower kit new shocks wheels and tires and new under bed gas tank. Setup for fuel injection with in tank fuel pump truck is almost complete about 90%complete needs door panels and a few odd ends. $25,000. https://www.facebook.com/marketplace...Anull%7D%22%7D
08-26-2021, 02:32 AM | #1429 |
$6000. 1972 c10 barn find.
Runs, drives, stops Odometer reads 11833 so I'd imagine it has 118k Good Doors, hood, tailgate function well. Speedometer works Gas gauge works Lights work Newish tires 5 lug rally wheels Aftermarket ac. No belt, I've never tried it. The power steering worked until the belt broke. It goes down the road nice. Bad. Has bondo in the rocker panels (I painted it brown to match the rust) Some body rust Dash lights inop Seat ripped under cover No radio but dash is uncut Drives like a 50 year old truck. I take it on 50 mile trips but that doesn't mean you should. Ha She is 50 years old and very original. Uses little or no oil and coolant Gets more smiles and thumbs up than a exotic car. People love the look of this truck. Would be good for advertising, or an ls conversion, or drive it to work tomorrow. Pretty firm on the price. Delivery $2 per mile from 66090 I live 8 miles outside of wathena KS 66090 Not really looking to trade https://www.facebook.com/marketplace...b-80618584fa00 |
08-26-2021, 02:33 AM | #1430 |
08-26-2021, 02:36 AM | #1431 |
Original 1972 Chevy Cheyenne, Automatic, 350 V8. Been in the family since purchased new in 72. Just over 100,000 miles. It did run and drive fine but the fuel pump went out. Have the pump. Just haven’t gotten around to changing it since I’m a CDL Driver.
Has some surface rust but nothing crazy for a 49 year old truck. And yes. That is the original bench seat. It’s always been covered. 👍🏻 Looking for Best Offer. Greeley, CO https://www.facebook.com/marketplace...b-80618584fa00 |
08-26-2021, 02:38 AM | #1432 |
https://www.facebook.com/marketplace...b-80618584fa00 https://www.facebook.com/marketplace...b-80618584fa00
08-26-2021, 03:30 AM | #1433 |
1972 Chevy Suburban 4 wheel drive 3 door! Runs, drives, and stops. 350 engine and turbo 400 transmission. Runs well and shifts well. The floors are super solid and i dont see any holes. Interior is in really good shape and no tears in the seats. Body has bondo in places that is showing in the quarters, drivers fender, and passenger door. Rust in lower quarters as per usual, and a few pin sized holes in the spare tire well. Any questions feel free to ask, this is one badass looking rig and you never see them around. WALK AROUND VIDEO - https://www.youtube.com/watch?v=VfDN..._channel=Logan https://www.facebook.com/marketplace...b-80618584fa00
08-26-2021, 05:01 AM | #1434 |
1969 chevy short bed 1/2 ton 2 wheel drive truck.
Engine 350 sm block, 400 auto, PB,PS, is an A/C truck but unit was removed, This is a project truck, have clean title and it is California registered. Have box of new parts https://www.facebook.com/marketplace...7-43abbd60c933 |
08-26-2021, 05:10 AM | #1435 |
Have a 1969 Chevy C10 not a G10 lol .........this truck has an inline 6cyl manual transmission 4 speed on the floor black plates upgraded headlights replaced brakes shoes, wheels cylinders springs on all 4. New water pump Got converted to short bed done right
https://www.facebook.com/marketplace...d-e1975d2a8d13 |
08-26-2021, 05:12 AM | #1436 |
selling my 67 k20 pickup. has a 496 big block that’s an absolute beast of an engine. used as a pull truck. but can easily be a street driven truck. has a 14 bolt. sm465 and np205 tranny. 44 in the front. brand new clutch and carb. has 35in bloggers. cab is rusty and has dents. but it’s very complete. engine is worth the asking price alone. let me know if interested. asking $5500 obo. may be open to trades.
08-26-2021, 05:20 AM | #1437 |
08-26-2021, 05:32 AM | #1438 |
08-26-2021, 12:50 PM | #1439 |
08-26-2021, 01:01 PM | #1440 |
This truck has been gone through and is street ready. I drive this truck every weekend to the lake and gun range. It has an 70's 350 w 3 speed saginaw on the floor.
I am in love with this truck however I am a stuck with to many projects. Please see the list below of all work done. Front Disk Conversion, cleaned painted and wrapped long tube headers w new gaskets, new HEI, plugs, oil, trans clutch, gas relocated to under the bed, frame has been cleaned and sealed from cab back, new rear and lower spring/shocks, new fuel line, new alternator, starter, rear brakes, new true dual exhaust, new tires, new ground straps all around, rear axle has new seals all around, trans seals, new battery, interior is good, bench seat has been modified to sit lower in the cab for better head height, rebuilt eldebrock 650 carb, new manual choke, new signal switch, flasher switch, new dash pad, gauge cluster has updated clock w rpm gauge Truck needs new cab corners. Rockers are good. Cleaned the patina and sprayed a clear coat to protect the paint. All surface rust has been treated prior to painting. Floor has a few small holes that have been treated, glassed and sound deadening material placed through the entire floor. Carpet is in good shape. Clean Texas Title in my name. Truck has been lowered 5 inches in the back with ride tech springs, dropped 1.5 in the front with spindles. All work has been completed by me and tested. https://www.facebook.com/marketplace...9-20903cbe3541 Safe, fun reliable truck. |
08-26-2021, 01:03 PM | #1441 |
$8900. 1970 Custom C10 LWB 350/TH350. Older original color repaint. Best described as a “Patina/Survivor”. Original Air Truck (and it works!), power steering, and 373 rear gear. Numerous new parts installed (see list below).
This truck has lived in dry west Texas it’s entire life before I bought it. (Original owner signed the SPID with date of purchase). I have well over 125 hours in clean up, paint reconditioning, reassembly and maintenance. Only major rust is in the bottom of the doors. Passenger side rocker is not terrible but will need to be replaced eventually. Small spot in cab corner as well. Rest of the truck is very solid. No rust around windows, cab mounts, core support etc. Floor is in great shape with only small clusters of surface spots. Everything works (Horn, Gauges, Lights etc.). Windshield is cracked and drivers vent window is broken at the bottom but still locks in place. Truck runs and drives fantastic. Needs very little to be perfect. Would be a great SWB conversion candidate. Pictures speak for themselves. If you want to argue price, come do it in person otherwise please move along. Located in Magnolia Texas. Clean and Clear Texas Title in my name. $8900 or best offer New Parts: Fuel Tank (used) Fuel Sending Unit (used) Holley Street Avenger Carb Plugs / Wires / Cap-Rotor Kit Brake Master Cylinder Radiator Thermostat / Thermostat Housing Battery Cable (-) Carrier Bearing Intake Manifold (used) Fuel Pump Drive Belts Upper and lower rad Hose Double Roller Timing Chain Timing Chain Gasket Set Air Cleaner Dash Pad Headlight Switch Headlight Knob Battery Temp Sensor + Wiring & More Magnolia, TX https://www.facebook.com/marketplace...9-20903cbe3541 |
08-26-2021, 01:17 PM | #1442 |
Price dropped to
$ 5000. For sale. 1970 2wd Chevrolet 3 door Suburban. 350 / 350 auto Dual A/C (dealer installed), great patina, roof rack, all glass there, windshield cracked, typical rust in rockers and lower qtrs. Does not run.. Been sitting for 20 years. Very complete truck. Missing rear seat. ( Spotlight not included) Texas title Located in Iowa Park Tx https://www.facebook.com/marketplace...9-20903cbe3541 |
08-26-2021, 01:20 PM | #1443 |
08-26-2021, 01:29 PM | #1444 |
1970 factory 4x4 and swb frame. C-10 cab and title. Straight body. 4 speed manual. AC cab but no ac. Very little rust on doors and light surface rust on bed floor. Great driver. $23,000. Will consider trades as well. https://www.facebook.com/marketplace...9-20903cbe3541
08-26-2021, 01:31 PM | #1445 |
08-26-2021, 01:34 PM | #1446 |
SERIOUS BUYERS ONLY PLEASE!
1970 CK 20 Chevrolet 3/4 ton pickup. One of a kind. Restoration in 2014. Perkins 6 cylinder diesel engine with a 5 speed international transmission. A/C, power steering, and power brakes. Gooseneck hookup. Less than 250 miles since restoration. Original bench seat. 100 gallon fuel tank. I have list from the restoration mechanic of all items replaced or rebuilt with costs. $26,000 or best offer. Please don't lowball us!!! https://www.facebook.com/marketplace...9-20903cbe3541 |
08-26-2021, 06:53 PM | #1447 |
08-26-2021, 07:35 PM | #1448 | |
Who Changed This?
08-26-2021, 07:45 PM | #1449 |
08-27-2021, 02:37 AM | #1450 |
$4200! 1972 Chevy C20 2 wheel drive. Camper special package, One owner 400 big block. This truck was special ordered from the factory. Olive green matching numbers truck. No customization, straight body, minimal rust, and all original. Factory A/C. Was parked in 1991. Price is firm and I have clear title in hand. https://www.facebook.com/marketplace...Anull%7D%22%7D
