Old 05-19-2007, 11:14 PM   #126
solidaxel
solidaxel's Avatar
Re: 52 Project
Thanks, I guess I better start with some more re-worked door hinges!!!!
Then find the set of doors I am going to use, boy. I am a long way from starting on the floor after reading that article, at least I have some idea where the pieces fit!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-19-2007, 11:33 PM   #127
solidaxel
solidaxel's Avatar
Re: 52 Project
After reading that floored article I like your photography better Colored!! Did you have trouble with your doors fitting when you were finished ?
LS 3 4L70E
Old 05-20-2007, 05:44 PM   #128
pgf545
pgf545's Avatar
Re: 52 Project
I took me a while to get the doors the way I wanted them. I am still not sure they will fit perfect but at least they close and seem to have proper gaps. I only fitted them when I had the floor screwed in. I am pretty sure that they will work but it may still take a little massaging to get them the way I want them. If you need any other pictures let me know and I will see what I have. All I did today was grind welds and I am still not completely done but got tired...lol.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 05-20-2007, 11:44 PM   #129
mylow53
mylow53's Avatar
Re: 52 Project
those doors are a nightmare i had to rotate the entire door clockwize just so the body lines lined up! then grind the crap out of the edges that touch reweld them and regrind them. they now line up as close as i can get them. i probably have 20 hours in each door
good luck
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 05-21-2007, 06:39 AM   #130
pgf545
pgf545's Avatar
Re: 52 Project
Yeah the body lines don't do so well. I have looked at several of these trucks and I don't think that very many of them line up too well. It seem that the line at the rear of the door doesn't match but at the front it looks ok. I was thinking about doing the same thing you did once I get to refining the body work.
Bernie
Old 06-04-2007, 06:44 PM   #131
pgf545
pgf545's Avatar
Re: 52 Project
Ok so I finally finished grinding all the welds on the floor. I still have a few touch up areas that need welding. I have been working on it for the past couple of weeks but I didn't think you guys wanted to see pictures of me grinding...lol. Anyway here are a couple of the finished floor and one of the motor setting getting ready to go.... . We are waiting on the radiator setup to come in so that I can finish locating the motor. Once we get the done then I can box the frame and install the new crossmember. Hopefully all the frame stuff will be done then and we can get it painted and start on the body work. Enjoy.
Bernie
Old 06-04-2007, 06:55 PM   #132
GraybealGarage
GraybealGarage's Avatar
Re: 52 Project
572...
lookin good!!
Jason
1971 SWB currently reconstructing...
Dropmembers, 20/22 rushforths...
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=467329
GraybealGarage is offline   Reply With Quote
Old 06-04-2007, 07:13 PM   #133
prostreeter58
prostreeter58's Avatar
Re: 52 Project
Wow....I wanted to go 572 but I had to maintain my sanity...........I really want to see the finished product............great job
prostreeter58 is offline   Reply With Quote
Old 06-05-2007, 09:28 PM   #134
pgf545
pgf545's Avatar
Re: 52 Project
Ok I fibbed a little...lol. Those are just 572 valve covers for now. It is a 454 that we are going to be putting some Aluminum heads on and some other fun parts. I don't see where the bigger motor would hurt anything though . Maybe some day after we get it running and driveable.
Bernie
Old 06-06-2007, 04:19 AM   #135
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 52 Project
The floor pan is looking really nice Bernie! Keep up the good work.
CAL 58 GMC is offline   Reply With Quote
Old 06-06-2007, 04:46 PM   #136
pgf545
pgf545's Avatar
Re: 52 Project
Thanks Cal, It turned out better than I expected. Sometime you can even surprise yourself .
Bernie
Old 06-17-2007, 05:52 PM   #137
pgf545
pgf545's Avatar
Re: 52 Project
Hey Guys I actually got something done today...lol. Check out this brake pedal/booster mount that I got in today. I still need to build some gussets and finish welding it in but at least I got something done today. Also there is a picture of one of the seats that we are going to use and a picture of the battery box from Brothers. The seats will probably be cut down but we still have some time to decide on that. Enjoy.
Bernie
Old 06-18-2007, 12:48 AM   #138
Daniel U
Daniel U's Avatar
Re: 52 Project
I've never seen that before. Clean work.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 07-05-2007, 09:59 PM   #139
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 52 Project
Along with Daniel, I've never seen that before too. I like the idea though. Was that a kit or did you come with that yourself?
Old 07-05-2007, 11:15 PM   #140
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 52 Project
Along with Daniel and Cal 58 on this one. I have never seen this before. How are you goin to plumb your brake lines? Through the lower firewall or floor? It is kind of slick though.
Kabwe is offline   Reply With Quote
Old 07-06-2007, 11:40 AM   #141
pgf545
pgf545's Avatar
Re: 52 Project
No I didn't come up with the myself...wish I had though...lol. It came from Kugel Komponents. I saw it on Webrodders and dad thought it would work good on his truck. I decided to take this week off work and it has rained every day so not much work is getting done. I did get the shop cleaned up a little and got some work done on the Camaro so it hasn't been a total waste of time. We are waiting on the radiator to come it so that I can get the motor placed in the proper position and then thing should progress a little quicker. I did get the booster mounted and braced. I am planning on building a console so the brake lines will be run under that and through the floor. The only concern I have is the A/C unit but I am guessing that I can make that work too. Here is the link to Kugel
http://www.kugelkomponents.com/
Bernie
Old 07-06-2007, 01:00 PM   #142
robin58
Re: 52 Project
Interesting method to do the m/c but I got to ask: how on earth do you check/fill the reservoir? Are you planning a remote reservoir for that?
robin58 is offline   Reply With Quote
Old 07-06-2007, 10:10 PM   #143
pgf545
pgf545's Avatar
Re: 52 Project
Originally I suggested a remote fill M/C but he went with this one. I think we can fill it no problem. I think the big opening area right in front of the M/C is a vent panel so I might be able to make that a fill panel????? If not I guess it will be mirrors and long skinny arms...LOL.
Bernie
Old 07-06-2007, 10:15 PM   #144
pgf545
pgf545's Avatar
Re: 52 Project
I found a better picture that might explain it better.
Old 07-15-2007, 08:12 PM   #145
pgf545
pgf545's Avatar
Re: 52 Project
We got the radiator in this past week and I spent today getting it installed. Man it looks great. I am really impressed with it and the quality of it. Hopefully now the progress will be a little quicker. Plan is to get the motor in it's proper place next weekend and then box the frame. Once that is done then we can paint it and start reassembly. And then onto body work. Check out these pictures.
Bernie
Old 07-15-2007, 08:38 PM   #146
prostreeter58
Re: 52 Project
That is looking real sweeeeet...................who is the radiator made by? Is that the condensor attached to the front? Really looks like a well made piece.
Old 07-16-2007, 09:10 AM   #147
pgf545
pgf545's Avatar
Re: 52 Project
It is a very nice piece. The quality is outstanding and the best customer service I have delt with in a long time. You can order it any way you want, we got it with the electric fan and shroud, the condenser and all polished plus we ordered a cap to go along with it. Here is a link for them.
http://www.prchotrod.com/
Bernie
Old 07-23-2007, 01:56 PM   #148
pgf545
pgf545's Avatar
Re: 52 Project
Update: I spent the day yesterday moving the motor only to figure out that I need to move it back about an inch . We were trying to use an HEI but it is going to be too tight. I have an MSD Distributor that is going to be pressed into service now. The only drawback is that we have an extra box to mount. We were trying to keep things simple...lol. I took a couple pictures but they are boring. I will give it a try again next weekend and if nothing else I will notch the firewall a little, I really don't want to do that but if I have to I will. Anyway just a quick note.
Bernie
Old 07-23-2007, 06:11 PM   #149
56chevy1300
56chevy1300's Avatar
Re: 52 Project
Get yourself a flexible turkey baster
56chevy1300 is offline   Reply With Quote
Old 07-23-2007, 08:43 PM   #150
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 52 Project
Man that radiator is way to sweet!
