01-20-2008, 02:50 PM | #126 | |
Re: Porterbuilt 69
I will also take some pics of the mounts for you tomorrow... along with the turbos!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-20-2008, 02:51 PM | #127 |
Re: Porterbuilt 69
I am waiting for some trailing arms to arrive... then we'll get some pics!
01-20-2008, 03:04 PM | #128 |
Re: Porterbuilt 69
Hey Nathan, Heads up on doing the rest of the frame and front suspension. Still need brakes and brake pump and fuel cell. Looks more like late Feb or March. Can't pull the body till the wheels clearence is set up in the rear and the front.
01-21-2008, 03:36 AM | #129 | |
Re: Porterbuilt 69
Are you gonna be mocking up a C4 sway bar for your DM C4? I'd like to see that too so I could use that on mine if possible.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
01-21-2008, 10:19 AM | #130 |
Re: Porterbuilt 69
Man that truck is gunna be whipass..
please keep the pics comming....
Chickenhouse chopshop 81 rcsb chevy bagged LS1/4l60E(under the knife) 94 ecswb L92 headed LQ9/ 4l80E(waiting to go under the knife) 78 rcsb chevy LQ4/4L80E |
01-21-2008, 12:39 PM | #131 |
Re: Porterbuilt 69
Spent a couple more hours on the truck today...
Here's some pics of the motor mounts and how they adapt to the LS engine. Also some clearance pics... It is a tight fit around the rack and pinion... but it does clear everything.
01-21-2008, 12:45 PM | #132 |
Re: Porterbuilt 69
Shaved the pass. side fender (didn't have the time to strip the paint off it). Also set the core support and hood in place... then pulled out the cut-off wheel and sliced the hood apart. I will be sliding the whole skin back around 2 inches and then I will pie-cut it a small amount, and then lay the front edge back. I always liked the look of the 67-68 hoods... so this one will be sleek with some subtle changes. I will also be changing up the ridge that runs down the hood... and doing something that flows with my dash idea. Hopefully we'll see that take shape in the next few weeks.
01-21-2008, 12:46 PM | #133 |
Re: Porterbuilt 69
a few more of the hood... and a pair of T4's and their counterparts on the ground.
01-21-2008, 12:51 PM | #134 |
Re: Porterbuilt 69
A busy Saturday..
Looks very cool. I can't wait to see the hood. Of course I can't wait to see my truck with it's '68 hood either.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver Last edited by babyblueoval; 01-21-2008 at 12:59 PM. |
01-21-2008, 12:53 PM | #135 |
Re: Porterbuilt 69
quick question for you, hopefully you didnt already answer in previous thread, what is the size of your front wheels and tires and also the backspacing? thank you and great work really like your dropmembers and looking forward to seeing your rear dropmemeber. keep up the great work.
01-21-2008, 12:58 PM | #136 | |
Re: Porterbuilt 69
Tires are 255 35 20 Thanks for the kind words!
01-21-2008, 02:36 PM | #137 |
Re: Porterbuilt 69
Looks awesome. Cant wait to see some finished pics of the hood.
01-21-2008, 02:43 PM | #138 |
Eat My Rust
Re: Porterbuilt 69
Twin turbo? Whaoh nelly, this truck is going to scream.
01-21-2008, 10:49 PM | #139 |
Re: Porterbuilt 69
Thanks for the pics of the mounts and clearance. Now you know why i called you when i installed mine...that baby is close! Will you use the same tranny crossmember that you sent me?
01-22-2008, 12:37 AM | #140 |
Re: Porterbuilt 69
Yes...but I have a different tranny in the truck (T56)...and I had to flip the crossmember over.
01-22-2008, 08:56 AM | #141 |
Re: Porterbuilt 69
looking like fun nate... so...hows the big block dropmember coming? need a sub to use for setup on the dropmember bb and boltin rear notch? i'm only a 16 hour drive away...haha
01-23-2008, 10:48 AM | #142 |
True Addiction
Re: Porterbuilt 69
Hey Nathan, How long can you get away with leaving the fenders in bare metal? I started striping the paint off my cab and was going to leave them "bare", but wasn't sure how long before the rust. Could you get away with spraying a little clear coat, or epoxy primer? Thanks, Truck looks Great as Always.
01-23-2008, 11:59 AM | #143 | |
Re: Porterbuilt 69
01-23-2008, 12:09 PM | #144 |
A guy with a truck
Re: Porterbuilt 69
Get w/ Kevin(Rokcrln). He uses some stuff that is supposed to keep it from rusting for a looong time. He left his tube frame bare for like 2 years or something like that...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-23-2008, 12:31 PM | #145 |
True Addiction
Re: Porterbuilt 69
Thanks for the help, I love the bare metal, and just wanted to keep it like that until it's time for the body shop.
01-23-2008, 01:18 PM | #146 | |
Re: Porterbuilt 69
You'd be amazed at how many people can't resist touching something shiny!
01-23-2008, 01:38 PM | #147 |
Re: Porterbuilt 69
I did my wheel-tubs (mini-tubs) & they're still in bare steel here in DFW (in the garage). I wipe them down w/some denatured alcohol & keep them closer to the house end of the garage vs. the door end. Worked so far (since November). It's too cold/humid for now.
01-24-2008, 02:19 AM | #148 |
///Relaxed Atmosphere
Re: Porterbuilt 69
can't wait to see more progress on this. looks goods.
Now I need to get out in the garage and get my dropmember installed on my 64.
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
01-24-2008, 01:02 PM | #149 |
Happy to be here
Re: Porterbuilt 69
I assume that means you got it picked up.
01-24-2008, 01:21 PM | #150 |
chevy runs deep
Re: Porterbuilt 69
all your work is the best...
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
