Old 04-18-2014, 08:09 AM   #126
Ronw435
Ronw435's Avatar
Re: Where is my 60-66 Chevy or GMC vin number?
Well going to the DMV today to try and get this straightened out. They can do a certified history of the title on both vehicles. Will let you know what I find. Thanks for the info padresag. Once I find out then I will approach the PO and see what we can do to get this straight. I really like the truck as it is really a solid truck for 49 years old or 50 which ever it is........
Ronw435 is offline   Reply With Quote
Old 04-18-2014, 08:21 AM   #127
Ronw435
Ronw435's Avatar
Another question, if I have figured this right and the number I found on the frame is 5s203265 if I was to request a title search would the number I give them be C1445S203265? As when I submit this to a title search site it comes back as none found. Now when I submit the number on the title of 4c144s118226 it does come back as having found it? Am I submitting the number on the 65 wrong?
Old 04-18-2014, 09:26 AM   #128
padresag
according to #4 on page 1 of this thread that looks to be right
ron
padresag is offline   Reply With Quote
Old 04-18-2014, 04:49 PM   #129
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
It most likely was a truck, a "4", but here are some other options that it could be,:
"2" -- Chassis & Cowl
"3" -- Chassis & Cab
"4" -- Pickup
"5" -- Panel
"6" -- Suburban
"9" -- Platform/Stake
Old 04-18-2014, 05:20 PM   #130
padresag
Jon, I think that he had said in another thread that it was a short stepper
ron
Old 04-20-2014, 07:46 AM   #131
Ronw435
Ronw435's Avatar
Well going to the DMV on Good Friday was not a good idea................duh! Will have to go sometime next week. I was told that if I take the number off the frame and that number has not been registered in the last 10 years they will provide me with a new title and identification tag. I hope that is the case as like you say padresag I do not want to get into a problem down the line if, heaven forbid, I ever got into a bad accident with it.
Thanks again for the information padresag.
Ron
Old 04-24-2014, 09:33 PM   #132
kingsolver72
10/30/19
kingsolver72's Avatar
I'm thinking about buying a 65 lwb. Thanks for all the info here!
Fight the good fight, finish the race, keep the faith
kingsolver72 is offline   Reply With Quote
Old 08-02-2014, 12:13 PM   #133
Kenfuzed
Kenfuzed's Avatar
Maybe someone can help identify this frame? Truck VIN from the cab is C1546Zxxxxxx which is clearly a 1966 1/2 ton long bed from the Fremont plant. The truck itself is actually a short bed fleetside and there are no signs the frame has been altered to make it a short bed. I don't see any numbers on the frame in the normal places for that year. The only number on the frame I can find is on the left rail just under the door, but on the outward facing side of the rail not on top. Hard to read that whole number but here's a picture below.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 08-02-2014, 05:57 PM   #134
Straydog
Thanks for the great post.
Now I know my mutt is a 1964 1/2 ton short step side built in St Louis. Now to see if I can get a title for it.
Straydog is offline   Reply With Quote
Old 09-13-2014, 03:37 PM   #135
cartoys
Confused:
I have a C30 Flatbed that shows V.I.N. on Top Door Frame of:
C369 5Z153212
How do I decipher that?
Likely I have missed something in this older Forum, but sure appreciate any help
thanks
cartoys is offline   Reply With Quote
Old 09-13-2014, 04:48 PM   #136
Originally Posted by cartoys View Post
Confused:
C369 5Z153212
thanks
Attachment 1301199
Here is what I got for your VIN
VIN Format: 1965-1966 Chevrolet truck
Decoding: C3695Z153212
C Conventional (2WD)
36 1-Ton
9 Platform/Stake
5 1965
Z Fremont Plant
153212 Sequence Number
Old 09-14-2014, 10:32 AM   #137
cartoys
36 1-Ton
9 Platform/Stake
5 1965
Z Fremont Plant
THANK YOU very much..........
I see where I messed up, as I did not know the "C369" was part of the V.I.N.
Makes sense now
THANK YOU again............
Old 09-29-2014, 01:25 AM   #138
SWFlyer
SWFlyer's Avatar
Found this number on the left frame rail of my 1963 C10 (in work) but it appears like some of the numbers are missing. What would the "J" mean?. The VIN tag is removed and lost.
SWFlyer is offline   Reply With Quote
Old 09-29-2014, 08:02 AM   #139
Ronw435
Ronw435's Avatar
I believe the J stands for Jainesville, Wi. the origin of manufacture. The build number is after that. or serial number.
Old 09-29-2014, 05:54 PM   #140
Attachment 1306902
Attachment 1306904
I believe that is just the frame rail part number.
The VIN is normally (from what I have seen/read) on the top of the frame rail just in front of the steering box mount or most likely on top of the frame under the driver's door area.
It is really hard to tell a lot of times. There seems to be lots of variations/discrepancies on this...especially between the plants.
Old 09-29-2014, 07:22 PM   #141
SWFlyer
SWFlyer's Avatar
Thanks, I'll keep looking when I get back up there. Unfortunately the truck is in Utah and I am in CA.
Old 09-30-2014, 01:01 PM   #142
Willie 66
Hey everyone. I've got a 66 and I've scoured the interwebs for something to "decode" my particular VIN with no luck. Everything lines up great with all the characters EXCEPT the 4th digit.
I can't figure out what that "3" means in the 4th character slot. A friend of a friend worked for Chevrolet for decades and has never seen anything like this. His best guess is that the truck was originally a chassis cab, but no decoders indicate that as an option. Anyone know what this means?
Willie 66 is offline   Reply With Quote
Old 09-30-2014, 01:22 PM   #143
60-66
60-66's Avatar
Attachment 1306902
Attachment 1306904
That is your VIN number, assuming its still the original frame. The frame "part number" is stamped on the side of the frame rail. The one in your picture is on top by the motor mount. If you need, there are people out there can reproduce a vin tag for these reasons.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-30-2014, 01:34 PM   #144
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
You are most likely correct. . It was probably purchased/built as a cab/chassis. ..
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 09-30-2014, 01:50 PM   #145
SWFlyer
SWFlyer's Avatar
I'm back to thinking there are some numbers missing then. The "J" could stand for Jainesville, Wi. The year should be in front of the "J" and the six following numbers are the serno.(?)
Old 09-30-2014, 03:09 PM   #146
60-66
60-66's Avatar
No numbers are missing from your frame stamp. Your frame IS stamped correctly. Here is my 1963 Short Fleet info. Different assembly plant but basically same thing.In 63 the year is the first "3" in the VIN tag . Last picture shows the part number stamped on the side of the frame under the door or rocker on drivers side. There will be THREE VIN numbers stamped all the same along the top of the drivers side rail.
Old 09-30-2014, 04:32 PM   #147
jonzcustomshop
1961 crewcab
60-66 is correct, also check out the #'s on post # 3 of this thread, they just put the year, assembly plant, and vin on the frame, all the other vin info was left off, apparently according to the pic of your 63, and 60-66's 63, they did not stamp the year date before the plant, like they did on the 65 and 66 that I pictured earlier in the thread,,,
as stated the "J" is for the Janesville plant.
Old 04-06-2015, 07:40 AM   #148
Zele3jiya7
Thks everyone my vin # is on the b pillar it says it's 1966 chevy long bed buts it's on a swb I guess somebody changed it through the years.....$800 dollars big back window I guess it's worth a chance away....thks
Zele3jiya7 is offline   Reply With Quote
Old 08-03-2015, 05:39 PM   #149
chevy55-77
Hi all,
Can someone please clarify what is the exact hieght/font size of VIN number on a frame? Preferably in millimeters
Thanks in advance!
chevy55-77 is offline   Reply With Quote
Old 08-03-2015, 05:40 PM   #150
chevy55-77
IF IT IS DIFFICULT TO WHAT inch sizes
