Old 06-11-2009, 05:54 PM   #126
scotts62
One day...
scotts62's Avatar
Re: my 64
Man thats looking good! I like the fuel cell mount
And your floor is spotless compared to mine after a day of working on the truck..
Scott
93 crew cab build
Project 62
Old 06-11-2009, 05:56 PM   #127
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
it had about ten pounds of bondo
but its gone now
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 06-11-2009, 05:57 PM   #128
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
thanks
its been worse but it was pretty bad then
Gage
Old 06-12-2009, 02:07 PM   #129
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
this is what i did last night and this morning
i pulled the brake booster off
i also put a new master cylinder on it
the brake booster didnt work and the firewall was hacked up so i made an aluminum panel that covers the brake booster holes
then i polished it
the first pic is before and the others are after
Gage
Old 06-12-2009, 02:10 PM   #130
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
no i dont like primer the things in primer are whats going to get a coat of sunburst orange
more pics
Gage
Old 06-12-2009, 02:59 PM   #131
jason65
Registerd User
jason65's Avatar
Re: my 64
Nice work vato.
jason65 is offline   Reply With Quote
Old 06-12-2009, 03:27 PM   #132
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
gracias hombre
Gage
Old 06-12-2009, 04:12 PM   #133
protrash64
Resistance is Futile
protrash64's Avatar
Re: my 64
Good job on the ms/cyl. I was wondering if your fenders are solid without the inners installed?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-12-2009, 04:15 PM   #134
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
yeah theyre fine i wouldnt sit on them but good enough to hold the frontend up
i want some porterbuilt inners which consist of two mounts and a tube
i will need them because im thinking about fiberglass fenders
Gage
Old 06-15-2009, 01:29 PM   #135
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
i went to o'reillys yesterday and picked up some exhaust tips
my neighbor took me to the store and we messed with the idiot working at the counter i used to work at the real parts store down the street but oreillys is the only one who had exhaust tips
here are some pics
Gage
Old 06-15-2009, 04:00 PM   #136
1964C10
1964C10's Avatar
Re: my 64
Nice job on the M/C!
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 06-15-2009, 10:14 PM   #137
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
thanks i still have to paint it and bend the lines
Gage
Old 06-19-2009, 05:50 PM   #138
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
i made a gas pedal last night out of aluminum
should i polish this or just leave how it is
sort of a brushed look
i have to make the brake pedal pad when i get some more aluminum
i need some ideas of how to mount it
heres some pics
Gage
Old 06-19-2009, 09:49 PM   #139
1964C10
1964C10's Avatar
Re: my 64
If you have one of those little portable sand blasters then that always gives it a nice "rough" finish that leaves future scratches somewhat hidden.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-20-2009, 12:41 AM   #140
Captainfab
60-66 Nut
Re: my 64
I agree....plus you don't want the pedals too slippery.....especially the brake pedal
Might be a good place to add some flares to those holes if you have a way to do that......flared up of course.
Old 06-20-2009, 01:12 AM   #141
protrash64
protrash64's Avatar
Re: my 64
I wouldnt bother polishing your pedal, unless you wear fuzzy slippers when you drive. I'm sure your shoes will unpolish it pretty fast.
Old 06-21-2009, 12:27 PM   #142
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
i have a sandblaster do you think that would look good
so any ideas on the brake pedal
Gage
Old 06-21-2009, 04:55 PM   #143
1964C10
1964C10's Avatar
Re: my 64
I am sure you have a little piece left over from what you made the pedals from, give it a shot and see if you like the look. Or do it on the back of the pedal that way if you dont like it none will see it.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-21-2009, 06:10 PM   #144
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
thanks but no i dont have any left that is the same size peice i found laying outside
my dad has to redo the way he mounted his swamp cooler(in the window with about a 30''x15'' peice of aluminum)
im going to use that aluminum to make a switch panel gauge cluster and brake pedal
Gage
Old 06-21-2009, 07:59 PM   #145
Inverter
Inverter's Avatar
Re: my 64
Hit that pedal w/a vibrating sander and a 220 grit pad and call it done.
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 06-22-2009, 10:27 PM   #146
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
thats actually what i did at first and didnt like
thanks though
ok the person that had this truck before obviously didnt know what they were doing and instead of recessing the dished in power steering box mount in the frame they just welded a chunk of another frame onto the original flat one
im changing over to manual steering but im going to go ahead and put the power steering mount on the frame just in case i change my mind later on
i still have to weld it in
i will get the welder back that i was using,tomorrow my neighbor loaned it to me (thanks Neil)
its a little hobart 140 MIG and works great
alright now for the pics
1st pic is before and the others are after
i thought the last 2 pics looked cool
Gage
Old 06-23-2009, 03:32 PM   #147
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
alright im done
heres the pics
its got a lot of little fuzzy things in the paint
crappy towels
i just did a qiuck rattle can job on it
Gage
Old 06-23-2009, 03:59 PM   #148
Frizzle Fry
Frizzle Fry's Avatar
Re: my 64
Looks factory!
Frizzle Fry is offline   Reply With Quote
Old 06-23-2009, 04:08 PM   #149
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 64
up close you can tell its not
well i cant because i did it
and stupid me welded up the holes to the core support mount
i was trying to make it look cleaner and didnt realize what i was welding up
Gage
Old 06-23-2009, 06:52 PM   #150
joe231
joe231's Avatar
Re: my 64
what did that frame section come from?
It looks nice!!
good work!!
CHEVY ONLY
