Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 06-17-2012, 04:14 PM   #126
ffk
ffk's Avatar
Re: Impala SS Rear Disc Brake Brackets
hey do you still have some...if so ill need your pay pal info
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604)
ffk is offline   Reply With Quote
Old 06-17-2012, 11:52 PM   #127
Captainfab
60-66 Nut
Hello. Yes I do still have these. My parts are not limited in quantities. I'll send you a PM with my PayPal info.
Old 01-09-2013, 02:44 AM   #128
Harpie
Harpie's Avatar
Interested in a set if still available.
Thanks Chad
Harpie is offline   Reply With Quote
Old 01-09-2013, 09:18 PM   #129
Styler1968
Can you send me directions for payment on the impala brackets for 1968 gm 12 bolt. Do you know if I can get inspection without an emergency brake, I'm in Texas?
Stephentyler0611@gmail.com
Styler1968 is offline   Reply With Quote
Old 01-09-2013, 11:22 PM   #130
Captainfab
60-66 Nut
A PM is coming your way with payment details.
Thanks Chad
I have no idea if Texas requires an e-brake or not. If you have to get a vehicle inspection, more than likely you will have to have an e-brake.
Old 03-17-2013, 09:26 PM   #131
blazins10
blazins10's Avatar
Hey , I think these would be a better fit since I can get different rotors so please pm me with payment info and ill PayPal it ASAP
Thanks mike
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 03-17-2013, 11:21 PM   #132
Captainfab
60-66 Nut
I'll send you a PM......
Old 03-18-2013, 11:03 AM   #133
sgaylord
Project collector
sgaylord's Avatar
Can anyone tell me how they plumbed these brakes for the rear? Do I have to use the rubber brake hose with the banjo bolt or can I add an adapter of some sort and plumb the hardline directly into the caliper?
Thanks, Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 03-18-2013, 10:56 PM   #134
Captainfab
60-66 Nut
Some of the older rear disc calipers were plumbed directly with a hard line. I prefer to use a rubber or braided stainless hose from the caliper to the hard line on the axle tube. You can use the one for the Impala with a Metric to SAE adapter.
Thanks, Steve
Old 03-19-2013, 03:40 PM   #135
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Texas requires a FUNCTIONAL E-brake on all vehicles so equipped.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-23-2013, 01:44 PM   #136
blazins10
blazins10's Avatar
parts are great !!! mounted up no issues at all (: ,
hub size on the impala rotor needs to be opened up to 79.5 mm
great product!!!! thanks
Old 03-23-2013, 11:01 PM   #137
Captainfab
60-66 Nut
Thanks for the compliment
That's strange that you had to open up the center hole of the rotors. I did not have to do that with mine. The typical hub register on a 5 x 5" axle flange is 3.06" or 77.7 mm.
Old 03-24-2013, 07:36 AM   #138
blazins10
blazins10's Avatar
ok, cool my axles had a step on them that was 79.45 so i just opened them up just oh so much ,maybe just my set ? still outstanding brackets
the pads were tight too but i machined the rotors down 003 and
its fine
Old 03-29-2013, 03:08 PM   #139
brakenit
Active Member
I'd like a set of these as well, can you PM me Payment info?
For anyone needing calipers Fedex just dropped off a pair of remanufactured Kelsey Hayes loaded Impala SS rear calipers, they came with pads and the brackets. They were on closeout for $50 shipped for the pair ($20.08/ea + $10 shipping) on Rockauto. Since they're on closeout to go along with the cheap price there is no core charge. It doesn't say how many they have left. Being able to get the calipers that cheap I think I should be able to get the swap done with zinc coated slotted rotors for around $250.
brakenit is offline   Reply With Quote
Old 03-30-2013, 12:32 AM   #140
Captainfab
60-66 Nut
PM coming your way......
Thanks for the info on the calipers
Old 04-28-2013, 06:15 PM   #141
tb8125
Hey just checking for 88-98 yet
tb8125 is offline   Reply With Quote
Old 04-28-2013, 11:48 PM   #142
Captainfab
60-66 Nut
Sorry, no time to work on those. I'll be working 80-100 hrs a week the next two weeks.
Old 05-03-2013, 02:03 AM   #143
blazins10
blazins10's Avatar
hey captain
could u email the parts list ? i lost it
and now i need the line and bolt info since i
bought the wrongs one
blazins10@msn.com
Old 05-05-2013, 12:09 AM   #144
Captainfab
60-66 Nut
Sorry for the delay, things have been crazy for me this last week. I will get that list emailed to you in a few minutes.
hey captain
blazins10@msn.com
Old 05-05-2013, 01:39 AM   #145
blazins10
blazins10's Avatar
i had a hard time finding the dorman banjo bolts
but found them in the help section part # 13912
Old 05-07-2013, 05:46 PM   #146
z71bro96
Captain Fab! I sent over a PayPal today for the 12 bolt bracket kit.
Dan
z71bro96 is offline   Reply With Quote
Old 05-07-2013, 11:27 PM   #147
Captainfab
60-66 Nut
Your payment has been received. I will try and get those shipped out on Friday. If not it will be Monday.....I am seriously backed up right now.
Dan
Old 05-21-2013, 11:05 PM   #148
z71bro96
Thanks for the great brackets Captain! Quick question..looks like the brackets mount 2 different ways. Should they mount on the bottom of the axle or the top? I think I've seen pics of Impalas calipers mounted on the bottom but I'm unsure.
Thanks for your help.
Old 05-22-2013, 02:22 AM   #149
Captainfab
60-66 Nut
When I re-designed these brackets I did so with the idea of the caliper mounting in aprox the 2 O'clock position. However you can mount them however you like. Just be sure the bleeders are on top.
Old 06-04-2013, 12:19 PM   #150
thump16
thump16's Avatar
hey Capt. I would like a set as well. pm me with info.
thump16 is offline   Reply With Quote
