Old 11-16-2011, 02:25 PM   #126
C.shows
C.shows's Avatar
Re: Tri5 55 build
Nice wheels, I have the grey ones. Does your hit the inside of the fender
When its all the way down?
C.shows is offline   Reply With Quote
Old 11-16-2011, 03:20 PM   #127
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: Tri5 55 build
It does not as far as I can tell, I'll be adding some drop spindles to the front soon, so we'll see. I have about 1/2 to 3/4" clearance.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 11-16-2011, 04:30 PM   #128
C.shows
C.shows's Avatar
Re: Tri5 55 build
I was asking about the back? I'm running 20×10's out back and 9.5's up front.
Post some pics when you get the front together.
Old 11-16-2011, 06:31 PM   #129
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
I have the same size back wheels you have, I'm running 295/35/20 tires and my rearend is 58" flange to flange which give me enough room to allow clearance, If I was to do this again using these same wheels I would make my rearend 60" flange to flange, the problem I foresee is that taking these wheels off, it's a pain in the azz. when it's all said and done I have about 1" clearance in the back using a 1" spacer now.
Tri5
Old 11-16-2011, 07:50 PM   #130
C.shows
C.shows's Avatar
Re: Tri5 55 build
I think my 8.8 is 59 or 60.. It's close maybe 1/2 inch from the fender lip.
my tires are a bit bigger 295/55/20. I have to remember i'm not building
a dragger this time.. But it has to be as low as possible! goodluck! subscribed.
Old 11-16-2011, 08:58 PM   #131
apache200
apache200's Avatar
Re: Tri5 55 build
thanks for the help. i am going to do some measuring and figure out what im going to use
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline   Reply With Quote
Old 11-21-2011, 01:52 AM   #132
blue57
blue57's Avatar
Re: Tri5 55 build
truck looks good. What headers are you running?
blue57 is offline   Reply With Quote
Old 11-21-2011, 03:04 AM   #133
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
Thanks man, they are Pace Setters long tube headers, I had to massage one a little, you need to make sure they clear the frame and K member also.
Tri5
Old 01-30-2012, 01:01 AM   #134
Roadkill58
Roadkill58's Avatar
Re: Tri5 55 build
Tri5,
I copied your step notch design, but with more of an angle (60 degrees).
Looks like you used less of an angle. How much of a notch did you end up with?
Mine is about 4 1/2". It gets a little narrow at the top but the axel should not hit.
Rust Never Sleeps
Roadkill's 58 Chevy Stepside build
Roadkill's 69 Custom C20
Roadkill58 is offline   Reply With Quote
Old 01-30-2012, 02:31 AM   #135
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
Originally Posted by Roadkill58 View Post
Tri5,
Looks like you did use more angle than I had, my notch is 6 1/2" and 8" deep from bottom of notch to bottom of frame rail but it should get you down pretty close to the ground, I'm like 2" off the ground when aired out.
Tri5
Old 01-30-2012, 03:14 AM   #136
Roadkill58
Roadkill58's Avatar
Re: Tri5 55 build
Tri5
I don't plan on baggin so it should be good.
Rust Never Sleeps
Old 01-31-2012, 04:43 PM   #137
Fat Mike
Fat Mike's Avatar
Re: Tri5 55 build
Have you installed your airbags yet? Very interested in seeing what they look like on your truck.
Fat Mike is offline   Reply With Quote
Old 02-26-2012, 01:38 AM   #138
Dads Burb
Re: Tri5 55 build
Do you have any pictures of the radiator supports? What radiator hoses are you using?
Dads Burb is offline   Reply With Quote
Old 02-26-2012, 01:20 PM   #139
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
Mike, I really don't have many good pictures of the bags now that I took the frontend apart and only found a couple of the rear that's really not showing how it looks but here you go.
Old 02-26-2012, 01:25 PM   #140
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
I'm going to use some L brackets at the bottom and on each side, I just made a couple for temporary mockups however if using the radiator I'm using one or both of the side brackets will need to be bolted on in order to put the radiator in.
I'm also using the stock host for the top and I found one at the swapmeet for the bottom. Hope that helps.
Tri5
Old 02-26-2012, 05:55 PM   #141
Shanehenrymusic
Re: Tri5 55 build
I love the stance of your truck! did you install drop spindles on the front and lowered springs? My clip was welded in the "No Limit" way and sits really high.. just wondering what I'll need to do to get her sitting down about 4 inches.
Shanehenrymusic is offline   Reply With Quote
Old 02-26-2012, 09:07 PM   #142
Tri5Nerd
Tri5Nerd's Avatar
Re: Tri5 55 build
ShaneHenryMusic,
My truck has air ride shockwaves in the front, I don't think it's low enough! I have and am going to install some drop spindles, just haven't gotten around to it. My clip was really butchered when I got it and a friend cleaned it up for me. Remember that your frontend will settle and drop some after adding engine/trans and cab to the frame.
Tri5
Old 09-28-2012, 11:09 PM   #143
apache200
apache200's Avatar
Re: Tri5 55 build
tri5 any new updates on your truck
1955 BBW Fleetside
Old 11-20-2012, 11:20 AM   #144
made2drag
made2drag's Avatar
Re: Tri5 55 build
tri5, your truck is sweet!....im a newbie at these...what year camaro subframe is it? 82-92? i just got a 56 and i was wondering if i should do a 71-72 c10 or a different frame from firewall forward. im wondering how much modification the 82-92 camaro would take.
made2drag is offline   Reply With Quote
Old 12-26-2012, 10:36 AM   #145
ZR2RICK
ZR2RICK's Avatar
Re: Tri5 55 build
Really enjoying your build Tri5, hey do you have any info and/or pics of your wishbone 3 link set up? angles, tubing used? bushings used? tubing diameter? ect... I am trying to decide the best rear suspension set up to use and would really prefer to build it myself.
Learn to deal with reality, or reality will deal with you.
ZR2RICK is offline   Reply With Quote
