Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 11-08-2010, 01:34 AM   #126
19723DR
19723DR's Avatar
Re: Project ''Second Time Around''
Originally Posted by MarKist View Post
well at least you won't have a wheel shortage..
So true. I seem to buy trucks that have 5-on-5 lug pattern so that I can swap back and forth. They say that a hobby is to own one, obsession is to try to own them all.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 11-08-2010, 01:49 AM   #127
19723DR
19723DR's Avatar
This weekend was spent welding the rear bag brackets on. From what I hear it should ride better than the bags-over-axles set up.
97 Z71 3 Door
Old 11-08-2010, 01:58 AM   #128
19723DR
19723DR's Avatar
Finished up painting with gloss black Rust-oleum and plumbing the bags in.
97 Z71 3 Door
Old 11-21-2010, 10:26 PM   #129
19723DR
19723DR's Avatar
In the last week I switched over to the interior again. Stripped everything but the door panels, those are next. I'm thinking about switching to the '95 and up. Everything plastic will be smooth and painted white. I'm going to build a custom speaker box in the rear with 2 12"subs and an amp, there will also be a custom center console down the middle, I'm in the designing process of that.
97 Z71 3 Door
Old 01-03-2011, 12:14 AM   #130
19723DR
19723DR's Avatar
Let's get this caught up to date. For the last few weeks I have been working a lot of overtime hours at work haven't had much time for the truck, but I did pick up some parts though. I picked up a 95 cab from a friend. Going to swap the dash and door panels over. I also got an elec. fan from a Taurus.
What a mess , but it's all there.
97 Z71 3 Door
Old 01-26-2011, 01:43 AM   #131
chevyndn
man i love your truck!
chevyndn is offline   Reply With Quote
Old 01-29-2011, 12:18 AM   #132
19723DR
19723DR's Avatar
Thanks. I'm glad you like it.
97 Z71 3 Door
Old 01-29-2011, 12:52 AM   #133
19723DR
19723DR's Avatar
Well for the last few months something been keeping up at night whether to keep the Super C-Notch or box the other side and make the notch deeper. Since I moved the bags to the links there no sence keeping the brackets over the axle. I hate to do things twice, make that three times now, this truck is a show truck so it had better lay frame. I made a trip to my father-in-laws shop and had him plasma cut some steal. Last weekend I cut the old pieces out and welded in the new ones. Also mounted the panhard-bar.
On a positive note my welds are getting better.
97 Z71 3 Door
Old 03-01-2011, 11:48 PM   #134
19723DR
19723DR's Avatar
The last couple of weeks I decided to tear apart the front suspension. I started with the lower control arms, the drivers side needed a ball joint so I pulled them out and while I was in there I de-humped and reinforced the lower bag bracket. I also pulled the upper arms out and clearanced them so they'd move further up. Most guys just notch them, but I decided to move the line further in and then weld it back together so you can't even tell it's been done. I also ground the frame lower pocket.
I cut out about a 1/2''
97 Z71 3 Door
Old 03-02-2011, 12:14 AM   #135
19723DR
19723DR's Avatar
I'm not going to notch the frame for the tie rods, Silver State Customs has some that are bent for this application. I'm leaning toward them. I still have to tub the cab for tire clearence, which leaves me no choice but to move the wiring harness, we'll see what I can figure out there. Right now, the front cross member sits a 1/2" off the ground, that's good enough for me. In the next couple of weekends I'm going to try and get a few more things done, so until next time....
97 Z71 3 Door
Old 03-21-2011, 12:02 AM   #136
19723DR
19723DR's Avatar
Last week I ordered the tie rods from Silver Star Customs they arrived Tues. So, I spent Saturday notching the frame for the tie rods, they are not notch-less they are less notch. I also spent some time tubbing the fire wall. I'll be spending some more time on the fire wall and mostly the wiring harness at a later date. Finally got the front end back together enough to roll it out and clean the garage floor. Found why it won't lay out, the trany is still hanging me up. I don't have any other option but to cut the tunnel and raise it up to make more room.
97 Z71 3 Door
Old 03-21-2011, 12:07 AM   #137
19723DR
19723DR's Avatar
97 Z71 3 Door
Old 03-21-2011, 12:09 AM   #138
19723DR
19723DR's Avatar
97 Z71 3 Door
Old 03-21-2011, 12:23 AM   #139
19723DR
19723DR's Avatar
The truck has been sitting for four months with out moving. It's nice to have it rolling again.
Here are some random pics.
97 Z71 3 Door
Old 03-21-2011, 12:43 AM   #140
Ru5tyNut5
Ru5tyNut5's Avatar
diggin' the christmas lights in march ;-) finally just took mine down a few weeks ago.
'55 Pontiac - Project
'63 GMC - Project
'76 Chev stepside rust bucket - Bagged daily driver
Project Ru5tyNut5
Ru5tyNut5 is offline   Reply With Quote
Old 03-21-2011, 11:06 PM   #141
19723DR
19723DR's Avatar
Lol, I had totally forgotten about the Christmas lights, been bizzy working on the truck to notice. They are blue and white so I'll keep them up till march madness is over for the Jimmer.
97 Z71 3 Door
Old 03-21-2011, 11:16 PM   #142
19723DR
19723DR's Avatar
Picked up a 5 gal air tank today from my friend, Chappy. He's going to make me a bridge out of 1 1/4 tube, I should have that at the end of the week. I also cleaned up the sway bar Sunday and painted it white. Should have a lot more progress this weekend.
97 Z71 3 Door
Old 04-03-2011, 10:05 PM   #143
19723DR
19723DR's Avatar
Got the bridge back, looks awesome. Welded that in during the week. I spent some time cutting the front fenders down to fit. Built a battery box so I could have a place to set the battery on so I could start it up and move it around. Yesterday was 70* so I pulled it out and washed it, This morning we had 6'' of snow. This spring's been crazy.
97 Z71 3 Door
Old 04-10-2011, 11:53 PM   #144
19723DR
19723DR's Avatar
This weekend I pulled the dash and door panels out of the red cab. I pulled the dash apart and began sanding the texture off. I got some of the pieces primed, but I ran out of primer. Still haven't decided what color I'm going to paint the dash and door panels; leaning towards white with airbrushing. During the week I made some air tank brackets, got them all welded up. I'll post pictures later.
97 Z71 3 Door
Old 04-12-2011, 11:40 PM   #145
19723DR
19723DR's Avatar
Today I got off a little early so I spent some time on the '95 dash cluster. After cutting the '93 wiring harness off, I spliced the '95 wiring harness into the newer dash cluster. I'd have to say it's a little intimidating splicing that many wires, I got the conversion specs off another site, that was alot of help. The '95 dash cluster has a lot more wires that aren't reused, but for the most part it went really well.
Here is the wiring diagram if any one else is doing this swap.. On the back of each plug there are small numbers or letters.
93 truck / / Function / / 97 truck
A-brn / / Alternater / / 19- Brn
W-PPL / / Gas / / 16-PPL
R-Drk Grn / / Temp / / 13- DRK Grn
P-Tan / / Oil / / 15-Tan
T-white / / Tach / / 6- white
S-Li Blue / / Blk / / Speed / /14- Drk Green
N,G- Blk / / Ground / / 31, 34- Blk/white
N,G,Q / / GROUND / / 31,34,4
F,O,U / / FUSE / / 22,7
B / / ANTI LOCK / / 27
C / / CHEKENG / / 23
E / / PKBRAKE / / 28
J / / LOWCOOLANT / / ??
L / / LFTTURN / / 3
M / / HIGHBEAM / / 5
V / / ILLUMINATION / / 29
X / / SEATBELT / / 30
Z / / RIGHTTURN / / 32
?? / / DRL / / 17
?? / / SIR / / 1
97 Z71 3 Door
Old 04-13-2011, 06:13 PM   #146
69c10stepside
Large Member
69c10stepside's Avatar
Glad you did the wiring to switch them around! I was going to do that on mine at one point, but I was going to have to convert over to the drac style from the pre drac wiring I had, and talked myself out of it.
How have you decided to go forward with the steering column?
1989 GMC C1500 ECSB
1972 Gmc Jimmy
1972 Chevy C10 SWB Sold
69c10stepside is offline   Reply With Quote
Old 04-14-2011, 01:48 AM   #147
19723DR
19723DR's Avatar
That's too bad that the 88-91 can't swap in without the drac. On a good note you get a custom gauge cluster.
I'm going to use the old column. The one from the red cab was missing the plastic surround and I didn't get the key's. That's OK, I'll just make a filler piece to fill the hole.
97 Z71 3 Door
Old 04-14-2011, 07:26 PM   #148
69c10stepside
Large Member
Needing any dash parts?
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 04-18-2011, 12:06 AM   #149
19723DR
19723DR's Avatar
The only thing I need is a head light switch, so far. Why you've got some parts kicking around?
97 Z71 3 Door
Old 04-18-2011, 12:23 AM   #150
19723DR
19723DR's Avatar
next page.
97 Z71 3 Door
